Showing results for tags '3-speed'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Here I present my Lego Technic Airport Refueler. Yet another airport vehicle. I wanted to build a truck with a remote controlled gear box, changing gear using a Servo motor, all wheel drive and with suspension on every axle. I started with the gearbox setup from Didumos69 used in his beautiful Rugged supercar. Ideal for use with a servo motor to change gear. But I had problems shifting down gear and slipping gears when driving. My biggest concern was the amount of space the gear box needed. The distance between the axles was to large. (I wanted to build a tractor truck and not just a big truck). After a few attempts, using other examples found on the internet, I finished with a ordinary, simple inline 3 speed gear box. I had to rebuild it several times because of slipping gears….. not robust/strong enough. Shifting gear only works well during drive. Sometimes the middle gear jams causing a bad shift of gears. Finally the distance between the axles was still big, but that gave me the idea to make my truck an airport refueler truck, seen on the airport. On top of the gearbox I could place a platform lift and on top the rear axle the 5th wheel for coupling a trailer. I hardy had bricks to build the trailer, I did not want to dismantle my Mercedes Arocs (or other vehicles) because both trucks have the same scale. Therefor I used I 125 [mm] tube to create the tank on my trailer, it also saved weight. The axles of truck and trailer have suspension. Coupling the trailer is done manually. The 4x4 truck functions are controlled by the SBrick from Vengit. SBrick: 1 Drive: 2 XL motor Platform lift: 1 L motor Steering: 1 Servo motor Shifting gear: 1 Servo motor (3 different speeds). Size: Length: 110 studs - 860 [mm] Width: 21 studs - 165 [mm] Height: 28 studs - 260 [mm] platform down (about 14 studs higher with the platform lifted) Here is movie of my Refueler, hope you like it. Click here you can find more pictures.
