coghilla Posted June 1, 2014 Posted June 1, 2014 (edited) Been working on these for a while but finally finished. I have recreated two fantastic models. A Robel Bullok 54.22 and a Plasser & Theurer MTW100. The bullok i first found years ago in a Kibri model train catalogue. I loved it and wanted to build in Lego. I'm no master builder, so couldnt get my head around it. Anyway found this www.brickshelf.com/cgi-bin/gallery.cgi?f=288796. Again wasnt happy or confidant about it. Finally got my backside into gear this year. It was a great experience building these, learning a tonne of building techniques, and using a tonne of reverse engineering, and trial and error. https://www.flickr.c...57644956327185/ Robel Bullok 54.22 recreation by coghilla, on Flickr Robel Bullok 54.22 recreation by coghilla, on Flickr Robel Bullok 54.22 recreation by coghilla, on Flickr The other was the MTW100 by eurobricks member Capt K. http://www.eurobricks.com/forum/index.php?showtopic=79799&hl=mtw100 My flicker album https://www.flickr.c...57644956327175/ Plasser & Theurer MTW100.083/1 by coghilla, on Flickr Plasser & Theurer MTW100.083/1 by coghilla, on Flickr Work wagons by coghilla, on Flickr Work wagons by coghilla, on Flickr Work wagons by coghilla, on Flickr Edited June 1, 2014 by coghilla Quote
rogul Posted June 1, 2014 Posted June 1, 2014 nice work mate, some nice work and nicely detailed Quote
emilstorm Posted June 1, 2014 Posted June 1, 2014 These are really great! I am actually not a great train fan, but I have always loved those maintenance ones for some reason. And I think you did these really well, very realistic and they just look good Quote
dr_spock Posted June 1, 2014 Posted June 1, 2014 Nice work. I collected a bunch of Robel pictures but never got my butt in gear to build one. Your model matches the pics. Quote
coghilla Posted June 2, 2014 Author Posted June 2, 2014 Thanks guys. While I'll accept praise for these models the real credit must go to the original builders whose work i have copied. They did the hard work of getting it to work and look right. Quote
Venturedude Posted June 14, 2014 Posted June 14, 2014 Nice work ! :D I have also made on :P Good detailed robel ;) Here is my version: http://www.brikkelauget.no/diskusjon/viewtopic.php?f=3&t=3531 and http://www.brickshelf.com/cgi-bin/gallery.cgi?m=VentureDude -Venturedude Quote
LEGO Train 12 Volts Posted June 15, 2014 Posted June 15, 2014 I love both of them! You've done a great work ...the model I like the most is the Robel Bullok: the side windows of the cab are fantastic with those yellow wedge plates. Only one question: the wagon looks really long, how does it engage corners and switches? Quote
coghilla Posted June 17, 2014 Author Posted June 17, 2014 (edited) Nice work ! :D I have also made on :P Good detailed robel ;) Here is my version: http://www.brikkelau....php?f=3&t=3531 and http://www.brickshel...i?m=VentureDude -Venturedude Great work there Venturedude. You should be happy with your creation. I love both of them! You've done a great work ...the model I like the most is the Robel Bullok: the side windows of the cab are fantastic with those yellow wedge plates. Only one question: the wagon looks really long, how does it engage corners and switches? No unfortunately it cannot traverse corners. I haven't tried any points. While some may see this a negative, I don't. Using the original creators comments i knew this couldn't do the corners. More pride in getting it to work for me. Also its now a mantle piece creation Edited June 17, 2014 by coghilla Quote
LEGO Train 12 Volts Posted June 17, 2014 Posted June 17, 2014 Thanks for your answer, you can use two turntables on the two pair of wheels and one universal joint to keep the wheels aligned after the curves! Quote
coghilla Posted June 18, 2014 Author Posted June 18, 2014 Thanks for your answer, you can use two turntables on the two pair of wheels and one universal joint to keep the wheels aligned after the curves! Thanks LT12V will have a look at that. There misght not be the strength in the sub frame especially at the rear. But still worthy of a look and see. Quote
Hrw-Amen Posted June 18, 2014 Posted June 18, 2014 Good looking trains there, always nice to have some maintenance trains around. Quote
coghilla Posted June 19, 2014 Author Posted June 19, 2014 Thanks LT12V will have a look at that. There misght not be the strength in the sub frame especially at the rear. But still worthy of a look and see. Had a good look last night. As I thought the frame is tied into the train boggie piece. It would need a complete redesign to enable it to work. Part of the problem would be the width of the unit. At some points (especially over the boggies) it is 7 studs wide. There are a few jumper bricks in there. Quote
coghilla Posted August 6, 2014 Author Posted August 6, 2014 ran the Plasser Thereur at a local expo recently. It made some of the standard 4x curves, but not others. It also was thwarted by the passenger bridge. cheers Quote
