Stephan Posted May 15, 2020 (edited) To keep this topic clean of comments, please request and discuss HEREAll the undesired posts will be moved to the aforementioned related thread It has been a long time since Lego Digital Designer (LDD) has been updated with new parts. For a long time the exact format of the code from the LDD parts was not exactly understood. Now, a few members of the Eurobricks community cracked the code and are able to create parts in the format LDD uses. This post shall list these new parts and contains a link to a zip/rar file with those new parts.Rules Off course we would all like to have as many new parts as soon as possible. That doesn't necessarily guarantee the highest quality standard. Therefor we have compiled some rules. Only parts that adhere to these rules will be added to the parts pack(s). Parts may only come from open sources. That means that LDraw parts are allowed, but that Mecabricks parts are strictly forbidden; A part must always have connectivity and boundary boxes; A part may include collision boxes but this is not necessary for approval. Reaching the LDD part database First things first. How to access the current parts of LDD? We need to know that before we can add new parts. Windows Download LDD LIF Extractor for 32- or 64-bit systems. The LIF file contains the LDD parts. The LIF Extractor can be found here: LINK; Unzip the LIF Extractor zip file; Navigate to: Users/[UserName]/AppData/Roaming/LEGO Company/LEGO Digital Designer. The "AppData" folder could be hidden; if so: activate "Show hidden files"; Here you'll find a file named "db.lif". Drag that file onto LIFExtractor.exe (it doesn't matter where LIFExtractor.exe is located: downloads folder, desktop or anywhere else, just drag db.lif onto the exe file); You'll now find a folder named "db" and one named "Palettes". Rename the original "db.lif" into something else (i.e. "xxdb.lif"), this is your parts back-up file! You'll find the following in the "db" folder:Folders "Assemblies": This folder contains the *.lxfml files for the assemblies. "Decorations": This folder contains all decorations. "MainGroupDividers": This folder contains the images of the part groups. " MaterialNames": This folder contains English and German names for the included color. Advise: do not open this file in a normal text editor, it will mess up the file, making it unusable! "Primitives": This folder contains the technical data for the parts. Navigate further to "LOD0", this folder contains the 3D models for the parts.Loose files "CurrentMaterials": This file list all current colors that are in LDD. "DecorationMapping": This file contains which decoration belongs to which parts. "info": Regular info about LDD. "Materials": This file contains all color RGB values. "pes": This file says something about friction which might have something to do with the old exploding animation. You'll find the following in the "Palettes" folder: Multiple *.lif files. Extract LDD.lif and LDDExtended.lif in the same way you extracted the db.lif file. Now you have two folders: LDD and LDDExtended. These folders contain *.paxml files: text files which create ready-to-use multi-colored part palettes. Here you add the 2020NewPreColoredParts folder. This gives you access to all new pre-colored multi-colored and printed new parts. iOS/Mac Download LIF-Extractor from JrMasterModelBuilder. It can be found here: LINK. Go to folder: /Users/myusername/Library/Application\ Support/LEGO\ Company/LEGO\ Digital\ Designer/ Extract the db.lif using JrMasterModelBuilder's LIF-Extractor.py Python script by using Terminal: python LIFExtractor.py /Users/myusername/Library/Application\ Support/LEGO\ Company/LEGO\ Digital\ Designer/\db.lif This will create a "db" subfolder containing the extracted contents of the db.lif file. Rename "db.lif" into something else (i.e. "xxdb.lif"), this is your parts back-up file! Enter the folder, go to "Primitives". This folder contains the technical data for the parts. Navigate further to "LOD0", this folder contains the 3D models for the parts. For information about the folder structure, see "Windows" above. Accessing the new parts Now for the real exciting part: adding parts to LDD. Lego Digital Designer should be closed for this. Download the update parts pack (*.rar file) to the location of the "db" folder from the latest post below; Unpack the folder; If asked if you want to replace files, click "Yes to all". Now you will have the latest parts and the newest part geometries. Edited May 9, 2022 by Stephan Added directions for Mac users. Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) New parts [as of 08-07-2020] In the list below you can find the newest parts. 1104 [104 on BrickLink] —— Antenna 6H - no stud receptacle 2101 [210 on BrickLink] —— Baseplate 16 x 22 2145 —— Brick, Arch 2 x 6 x 5 Ornamented 2337 —— Windscreen 4 x 4 x 2 Canopy Extender 2557 [2557c* on BrickLink] —— Boat Hull Large Bow 12 x 16 x 5 1/3, w/ Top —— is multi-colorable 2559 [2559c* on BrickLink] —— Boat Hull Large Stern 14 x 16 x 5 1/3, w/ Top —— is multi-colorable 2619 —— Monorail Motor Cover —— includes collission data 2623 —— Boat Bow Top 8 x 10 x 1 2670 —— Monorail Track Straight Short —— includes collission data 2671 —— Monorail Track Straight Long —— includes collission data 2672 —— Monorail Track Curve Long —— includes collission data 2677 —— Monorail Track Ramp Lower Part —— includes collission data 2678 —— Monorail Track Ramp Upper Part —— includes collission data 2681 —— Support 6 x 6 x 10 Stanchion —— v2 —— includes collission data 2687 —— Monorail Base 4 x 20 —— includes collission data 2711 —— Technic, Plate 1 x 5 with Toothed Ends, 2 Studs and Center Axle Hole 2891 —— Monorail Track Curve Short Right —— includes collission data 2892 —— Monorail Track Curve Short Left —— includes collission data 3144 —— Antenna with Side Spokes 3334 —— Baseplate 16 x 24 3358 —— Fence Gate 1 x 3 x 2 3359 —— Fence Gate 1 x 3 x 2 Base 3481 —— Plate, Modified 2 x 2 with Helicopter Tail Rotor Holder 3497 —— Baseplate 8 x 24 3612 —— Arm Piece Straight with 2 and 3 Fingers 3613 —— Arm Piece with Tow Ball Socket, 3 Fingers 3671 [367 on BrickLink] —— Baseplate 24 x 24 with Studs on Edges 4169 —— Bracket 2 x 3 - 1 x 3 (Train Signal Stand) 4187 —— Baseplate 8 x 32 4263 —— Technic, Plate 1 x 4 with Toothed Ends 4318 —— Boat Mast 2 x 2 x 9 2/3 Bar with Slot on Top and 2 Finger Hinge on Two Sides 4508 [251 on Bricklink] —— Turntable 2 x 2 Plate with Hinge, Base 4743 —— Brick, Arch 2 x 8 x 3 6051 [6051c* on BrickLink] —— Boat Hull Small Bow 12 x 12 x 5 1/3, w/ Top —— is multi-colorable 6053 [6053c* on BrickLink] —— Boat Hull Small Stern 12 x 12 x 5 1/3, w/ Top —— is multi-colorable 6054 —— Boat Hull Small Middle 8 x 12 6085 —— Cockpit 5 x 8 x 3 (Windscreen Bottom) 19474 (9417/9) [BrickLink bb0874] —— Pneumatic Switch with Pin Holes and Axle Hole —— v3 —— is multi-colorable; includes collission data 19475 (2944/7/9388) [BrickLink 19475c01] —— Pneumatic Cylinder V2 1 x 5 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19476 (9112/9145/21828) [BrickLink 21828c01] —— Pneumatic Cylinder V2 1 x 11 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19478 (9113/19466/21828) [BrickLink 19467c01] —— Pneumatic Cylinder V2 2 x 11 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19482 (2944/9388/99799) [BrickLink 99798c01] —— Pneumatic Pump Small (6L) —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 24855 —— Plant Flower Stem with Bottom Pin 24866 —— Plate, Round 1 x 1 with Flower Edge (5 Petals) —— v2 25059 —— Train, Track Roller Coaster Straight 16L 25061 —— Train, Track Roller Coaster Curve, 90 degrees 25195 —— Plate, Modified 2 x 6 with Pole Holder Pin 26021 —— Vehicle, Base 4 x 5 Roller Coaster Car 26022 —— Train, Track Roller Coaster Straight 8L 26073 —— Minifigure, Backpack with Bedroll Pattern —— is multi-colorable 26288 (26280/932901/2) [BrickLink 26288c01] —— Pneumatic Pump Large (11L) with 1 x 3 Liftarm —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 26559 —— Train, Track Roller Coaster Ramp Large Lower Part, 6 Bricks Elevation 26560 —— Train, Track Roller Coaster Ramp Large Upper Part, 6 Bricks Elevation 26561 —— Train, Track Roller Coaster Ramp Steep, 6 Bricks Elevation 27448 —— Tile, Modified 2 x 2 with Large Hole 28618 —— Wave Rounded with Base Rim (Castle Dragon Flame, Seaweed, Water) 28802 —— Bracket 1 x 2 - 1 x 4 with Two Rounded Corners at the Bottom —— includes collision data 28974 —— Minifigure, Neck Bracket with Back Stud - Thick Back Wall 29096 —— Cone Half 10 x 5 x 6 30010 —— Panel 1 x 2 x 1 —— [4865 on BrickLink] 30014 —— Arm Holder Brick 1 x 2 with 2 Horizontal Fingers 30034 —— Panel 3 x 5 Solar/Clip-On/Deltoid 30073 —— Door 1 x 6 x 8 Left 30074 —— Door 1 x 6 x 8 Right 30082 —— Arm Piece with Tow Ball and Clip 30219 —— Bar 16L with Open Stud, Tow Ball, and Slit (Windsurfer Mast) 30271 —— Baseplate, Raised 32 x 48 x 6 with 4 Corner Pits 30298 —— Windscreen 10 x 14 x 2 2/3 Roll Cage 30348 [30346c01 on BrickLink] —— Electric, Light Rock Raiders Laser (30346c00 / 30348) —— is multi-colorable 30371 —— Minifigure, Head Modified SW Gungan Split Eyes 30619 —— Cockpit 6 x 6 x 5 with Hinge 32606 —— Friends Accessories Flower with 7 Thick Petals and Pin —— has incorrect 3D geometry 32607 —— Plant Plate, Round 1 x 1 with 3 Leaves —— v2 32802 —— Slope, Inverted 45 4 x 1 Double 32803 —— Slope, Curved 2 x 2 Inverted 34732 —— Panel 1 x 4 x 6 Wavy 34738 —— Train, Track Roller Coaster Ramp Small, 3 Bricks Elevation 35044 —— Plate, Modified 4 x 4 with Curved Cutout 35185 —— Technic, Gear 20 Tooth Double Bevel with Clutch on Both Sides —— includes collission data 35186 —— Technic, Driving Ring Extension with 8 Teeth Inside and Outside —— v3 —— includes collission data 35188 —— Technic, Changeover Rotary Catch —— v2 —— includes collission data 35189 —— Technic, Steering Wheel Hub 3 Pin Holes Round 35366 —— Bar 2.25 x 5.25 Double Squares (BrickHeadz Glasses Square) 35442 —— Plate, Round 2 x 2 with 6 Gear Teeth / Flower Petals 35443 —— Plate, Round 4 x 4 with 10 Gear Teeth / Flower Petals 35446 —— Plate, Round 6 x 6 with 14 Gear Teeth / Flower Petals 35459 —— Tile, Modified 1 x 3 Inverted with Hole 35464 —— Slope 45 1 x 1 Double 35480 —— Plate, Modified 1 x 2 Rounded with 2 Open Studs —— v2 —— includes collission data 35485 —— Minifigure, Weapon Hoop Blade / Chakram 35563 —— Tower Roof 2 x 4 x 4 Half Cone Shaped with Roof Tiles 35574 —— Cone 2 x 2 x 1 2/3 with Stacked Rings (Beehive / Cotton Candy) 35646 —— Rock 1 1/3 x 1 1/3 x 1 35649 —— Tile, Modified 1 x 2 Diamond 35654 —— Bar 1 x 4 x 1 2/3 (Grille Guard / Push Bumper) 35660 —— Minifigure, Hair Combo, Hair with Hat, Ponytail with Ball Cap Pattern —— is multi-colorable 35700 —— Container, Box 2 x 2 x 1 - Top Opening 35787 —— Tile, Modified 2 x 2 Triangular 35789 —— Vehicle, Mudguard 4 x 2 1/2 x 2 1/3 with Arch Round, Solid Studs, and Rounded Legs 36036 —— Lower Body, Skirt 36840 —— Bracket 1 x 1 - 1 x 1 Inverted 36841 —— Bracket 1 x 1 - 1 x 1 —— v3 —— includes collission data 37195 —— Wheel Cover 28 Spoke - 18mm D. - for Wheel 56145 37352 —— Brick, Modified 1 x 2 x 1 No Studs, Curved Top 37494 —— Hinge Train Pantograph Shoe 37695 —— Plant Stem with 3 Leaves and Bottom Pin [v2] 37762 —— Minifigure, Utensil Candle 37775 —— Candle Flame 37776 —— Minifigure, Utensil Lantern 38014 —— Minifigure, Utensil Tea Cup 38320 —— Window 1 x 2 x 2 Pane Lattice Diamond —— v2 38391 —— Plate, Modified 1 x 2 with Handles - Round Ends, Mid Attachment [3839a on BrickLink] 38583 —— Brick, Arch 1 x 2 Jumper 38585 —— Brick, Arch 2 x 2 Corner 38799 —— Minifigure, Utensil Tea Saucer with Hollow Stud on Top 39262 —— Minifigure, Headgear Crown with 5 Points, Open Center Stud 39367 [39367c* on BrickLink] —— Wheel 56 x 14 Technic with Axle Hole and 8 Pin Holes with Fixed Rubber Tire —— is multi-colorable 39611 —— Plate, Round 4 x 4 x 2/3 with Star and 1 Open Stud 39739 —— Tile, Round 1 x 1 Heart 39789 —— Technic, Brick 2 x 4 with 3 Axle Holes 39790 —— Technic, Liftarm 11 x 15 Open Center Frame Thick —— v2 —— includes collission data 39793 —— Technic, Pin Connector Block, Liftarm 1 x 3 x 3 —— includes collission data 39794 —— Technic, Liftarm 7 x 11 Open Center Frame Thick —— v2 —— includes collission data 39802 —— Minifigure, Utensil Axe with Head and Blade, Pick End and Long Handle —— is multi-colorable 40811 —— Plate, Modified 1 x 1 with Clip Light - Thin Ring —— [4081a on BrickLink] 41682 —— Bracket 2 x 2 - 1 x 2 Centered —— v2 —— added collission data 41740 —— Plate, Modified 1 x 4 with 2 Studs with Groove 41812 —— Projectile Launcher 4 x 2 x 1 with Bottom Axle (Launches 1 x 1 Round Tiles) —— is missing conenctivity for 1 x 1 Round Tiles 41823 —— Fence 3 x 3 x 2 Quarter Round Ornamental with 2 Studs 41948 —— Plate, Round 8 x 8 Rounded End 42531 —— Technic, Panel Car Mudguard Arched 9 x 2 x 3 —— v2 —— includes collission data 42545 [BrickLink 42545*] —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 —— v2 —— includes collission data 42716 —— Wheel 30.4mm D. x 20mm with No Pin Holes and 5 Large Spokes —— includes collision data 42862 —— Wedge 3 x 3 Sloped Left —— v2 42918 —— Slope, Curved 8 x 2 —— v2 43045 —— Hinge Plate 2 x 4 with Pin Hole and 2 Holes - Top 43056 —— Hinge Plate 2 x 4 with Pin Hole and 2 Holes - Bottom 44709 —— Minifigure, Weapon Gun, Blaster with Studs on Sides, Bottom, and Front 45755 —— Minifigure, Headgear Head Cover —— is multi-colorable 46524 [40931 on Bricklink] —— Electric, Light & Sound Siren 2 x 6 x 1 with Lights —— is multi-colorable 47222/3 [BrickLink 4694bc01] —— Pneumatic Switch with Pin Holes —— v2 —— includes collission data 48165 —— Wedge 3 x 3 Sloped Right 48205 —— Wedge, Plate 6 x 4 Right 48208 —— Wedge, Plate 6 x 4 Left 48995 —— Tile, Modified 3 x 2 with Hole 49097 —— Vehicle, Mudguard 3 x 3 x 1 with Arch Round 49098 —— Wheel Cover 10 Spoke Recessed 49307 —— Brick, Modified 1 x 1 x 2/3 No Studs, Curved Top 49308 —— Brick, Round 3 x 3 x 1 1/3 Dome Top - Open Stud 49309 —— Cone 2 x 2 x 2 Inverted 49311 —— Brick 1 x 4 x 3 49618 —— Slope 25 8 x 1 x 3 51239 —— Window 1 x 3 x 3 Flat Front 51266 —— Glass for Window 1 x 3 x 3 Flat Front 51270 —— Pumpkin 51283 —— Minifigure, Headgear Helmet Round Fishbowl 51542 —— Baseplate, Raised 32 x 48 x 6 with Level Front 52985 —— Tire 68.7 x 27 S 53119 —— Plate, Round 1 x 1 with Horizontal Swirl / Twist 53178 —— Pneumatic Cylinder Bracket —— v2 —— includes collission data 56074 —— Windscreen 12 x 12 x 2 57915 —— Boat Hovercraft Skirt, Unitary 64570 —— Bracket 2 x 6 - 1 x 6 Inverted 65426 —— Wedge, Plate 4 x 2 Right, Pointed —— v2 65429 —— Wedge, Plate 4 x 2 Left, Pointed —— v2 65581 —— Minifigure, Utensil Lantern with Large Round Handle 65632 —— Windscreen 6 x 6 x 1 2/3 65633 —— Windscreen 6 x 6 x 1 1/3 65634 —— Vehicle, Base 6 x 12 x 1 with 5 x 4 Recessed Center and 8 Holes 65635 —— Technic, Brick 2 x 6 x 1 1/3 with Axle Holes 65734 —— Brick, Modified 1 x 4 x 2 2/3 with Curved Top 65735 —— Windscreen 1 x 10 x 4 66606 —— Cone Half 6 x 4 x 10 (Elliptic Paraboloid) 66727 —— Wheel 18mm D. x 12mm with Pin Hole and Stud, Dotted Brake Rotor Lines 71183 —— Bar 1L with 1 x 1 x 2/3 Light Holder 71184 —— Bar 4.5L with Stop Ends 74982 (2943/4/9388) [BrickLink x191c01] —— Pneumatic Pump Small (5.5L) —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 98107 —— Cylinder Hemisphere 11 x 11, Studs on Top 189781 —— Wheel Cover 5 Spoke - for Wheel 18976 —— 18978-1 189782 —— Wheel Cover 10 Spoke - for Wheel 18976—— 18978-2 189791 —— Wheel Cover 7 Spoke Y Shape - for Wheel 18976 —— 18979-1 189792 —— Wheel Cover 10 Spoke T Shape - for Wheel 18976 —— 18979-2 243081 —— Wheel Cover 10 Spoke (Spokes in Pairs) - for Wheel 18976 —— 24308-1 243082 —— Wheel Cover 10 Spoke Y Shape - for Wheel 18976 —— 24308-2 268400 (2682/3/4/5) [BrickLink 2684c01b] —— Monorail Motor 9V with Long Couplings —— v3 —— is multi-colorable; includes collission data 268600 (2686/2697) —— Monorail Bogey —— v3 —— is multi-colorable; includes collission data 277400 (2774) —— Monorail Track Monoswitch —— is multi-colorable; includes collission data 279300 (2793/2796/2806) [BrickLink 2793c0*] —— Pneumatic Cylinder with 2 Inlets Medium (48mm) with Top —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 279700 (2797/2806/279701/2) [BrickLink 2797c0*] —— Pneumatic Pump Second Version with Top —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 288900 (2880/1/2/3/4/2890/2911) [BrickLink 2889] —— Monorail Track Point Right —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 289000 (2883/4/5/6/7/2890/2911) [BrickLink 2890] —— Monorail Track Point Left —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 291171 —— Wheel Cover 5 Spoke Wide - for Wheel 18976 —— 29117-1 291172 —— Wheel Cover 5 Spoke Framed - for Wheel 18976 —— 29117-2 324960 (32495/6) [BrickLink x873c01/32495c01] —— Technic, Steering Arm with 4 Ball Joints with Wheel Hub (x872 / x873) —— v2 —— is multi-colorable; includes collission data 377201 —— Minifigure, Weapon Batarang, Shield Size with Stud on Front —— 37720-1 377202 —— Minifigure, Weapon Batarang, Very Small —— 37720-2 377203 —— Minifigure, Weapon Batarang with Bar Ends —— 37720-3 377204 —— Minifigure, Weapon Batarang with Bar Handle on Bottom —— 37720-4 377205 —— Minifigure, Weapon Batarang, Wide with Stud on Front —— 37720-5 469400 [BrickLink 4694c01] —— Pneumatic Switch with Top Studs —— v2 —— is multi-colorable; includes collission data 472240 (2796/47224) [BrickLink 47224c0*] —— Pneumatic Cylinder with 2 Inlets and Rounded End Medium (48mm) —— v2 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 500181 —— Minifigure, Weapon with 3 Mechanical Arms —— 50018-1 500182 —— Minifigure, Weapon Pistol, Bar on Front, Studs on Sides, Handle on Back and Bottom —— 50018-2 500183 —— Minifigure, Weapon, Bar on Front, Stud on Back —— 50018-3 500184 —— Minifigure, Weapon with 2 Mechanical Arms —— 50018-4 500185 —— Minifigure, Weapon with Bar and Stud —— 50018-5 500186 —— Minifigure, Weapon Bowl with 3 Reinforcements —— 50018-6 500187 —— Minifigure, Weapon Circular Saw —— 50018-7 611901 —— Minifigure, Armor Leg Anti-Blast Kama —— 61190-1 611902 —— Minifigure, Armor Pauldron Plastic —— 61190-2 611903 —— Minifigure, Visor SW Clone Trooper —— 61190-3 611906 —— Minifigure, Weapon Gun, Blaster Small DC-17 (SW) —— 61190-6 626981 —— Minifigure, Utensil Computer Laptop —— 62698 - open 626982 —— Minifigure, Utensil Computer Laptop —— 62698 - closed Edited July 17, 2020 by Stephan Added version 20200708β Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) Fixed parts [as of 22-06-2020] In the list below you can find the parts that have been fixed. 2620 —— Windscreen 4 x 4 x 3 Canopy —— location hinge attachment point fixed 2680 —— Support 4 x 4 x 5 Stanchion —— moved to "Trains" category 4151 [4151b on BrickLink] —— Plate, Modified 8 x 8 with Grille and Hole in Center —— updated collision data 6573 —— Technic, Gear Differential, 24-16 Teeth —— updated collission data 11538 —— Minifigure, Headgear Helmet SW 11946 —— Technic, Panel Fairing #21 Very Small Smooth, Side B —— fixed default orientation 14720 —— Technic, Liftarm 3 X 5 Perpendicular H-Shape Thick —— moved to "Technic Beams" category 15458 —— Technic, Panel Plate 3 x 11 x 1 —— moved to "Technic Panels" category 18450 —— Tire 81.6 x 44 R —— fixed center attachment point 18934 —— Minifigure, Head Modified SW Tusken Raider 18938 —— Technic, Turntable Large Type 3 Top, 60 Tooth —— moved to "Technic Gears" category 18939 —— Technic, Turntable Large Type 3 Base —— moved to "Technic Gears" category 18940 —— Technic, Gear Rack 1 x 14 x 2 Housing —— added ability to manualy slide gear rack 18942 —— Technic, Gear Rack 1 x 14 x 2 with Axle and Pin Holes —— added ability to manualy slide gear rack 18945 —— Technic, Panel Plate 5 x 11 x 1 Tapered —— moved to "Technic Panels" category 19917 —— Minifigure, Collar SW Darth Vader Helmet Bottom 20460/20461/21019 —— Hips and Legs 20603 —— Minifigure, Headgear Extended Head with Goggles and Messy Hair 24314 [24314c* on BrickLink] —— Wheel Wheelchair with Fixed Hard Rubber Tire (1-Piece Wheel) —— is multi-colorable 24601 —— Minifigure, Head Modified SW Maz Kanata 25214 —— Brick, Round 1 x 1 d. 90 Degree Elbow - No Stud - Type 2 - Axle Hole —— v2 —— fixed collision data 26601 —— Wedge, Plate 2 x 2 Cut Corner —— fixed collision data 27162 —— Minifigure, Head Modified Pencil Top 28501 —— Minifigure, Hair Combo, Bald Conehead with Large Ears 28925 [28533c* on BrickLink] —— Boat, Hull Unitary 16 x 8 Base with Boat Hull Unitary 16 x 8 Top (28533 / 28535) —— is now multi-colorable 30311 [bb0790 on BrickLink] —— Minifigure, Head Modified SW Protokoll Droid with Large Speckled Eyes and Breathing Mask —— is now multi-colorable 30329 —— Minifigure, Head Modified Helmet with Neck Ridges and Mask with Circle —— is now multi-colorable 30838 —— Wheel 11mm D. x 6mm with 7 Slanted — attaches to axle connections now 32235 —— Hose, Soft Axle 19L —— is now flexible 34412 —— Torso Arm Right with Robotic Blaster 41896 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 3 Pin Holes —— fixed center attachment point 45982 —— Tire 81.6 x 38 R Balloon —— fixed center attachment point; updated 3D model 48002 [BrickLink 48002a] —— Boat, Mast 2 x 2 x 20 with Holes - Side Aligned x shape Axle Hole —— fixed collission data 56908 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pin Holes —— fixed center attachment point 60483 —— Technic, Liftarm 1 x 2 Thick with Pin Hole and Axle Hole —— moved to "Technic Beams" category 61189 —— Minifigure, Headgear Helmet SW Clone Trooper with Holes 61927 —— Technic, Linear Actuator with Ends —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 64178 —— Technic, Liftarm 5 x 11 Open Center Frame Thick —— moved to "Technic Beams" category 64179 —— Technic, Liftarm 5 x 7 Open Center Frame Thick —— moved to "Technic Beams" category 64391 —— Technic, Panel Fairing # 4 Small Smooth Long, Side B —— fixed default orientation 64393 —— Technic, Panel Fairing # 6 Long Smooth, Side B —— fixed default orientation 64680 —— Technic, Panel Fairing #14 Large Short Smooth, Side B —— fixed default orientation 64682 —— Technic, Panel Fairing #18 Large Smooth, Side B —— fixed default orientation 64782 —— Technic, Panel Plate 5 x 11 x 1 —— moved to "Technic Panels" category 76537 —— Technic, Shock Absorber 6.5L - Hard Spring —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 87080 —— Technic, Panel Fairing # 1 Small Smooth Short, Side A —— fixed default orientation 87086 —— Technic, Panel Fairing # 2 Small Smooth Short, Side B —— fixed default orientation 92693/4/6/4694/5 [BrickLink 92693c01] —— Technic, Linear Actuator Mini with Head and Axle —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 93064 —— Minifigure, Head Modified Skull with Spikes 93065 —— Minifigure, Head Modified Skull with Helmet 93067 [93539 on BrickLink] —— Minifigure, Head Modified Skull with Lower Jaw 95292 —— Technic, Shock Absorber 9.5L —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly; replaces 41475, 74741, 75348 98099 —— Minifigure, Headgear Helmet SW ARC Clone Trooper Edited September 24, 2020 by Stephan Added version 20200622β Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) MAY 2020 UPDATE 05-2020 [version 0520] or GitHub [download files separate] New parts 1104 [104 on BrickLink] —— Antenna 6H - no stud receptacle 2101 [210 on BrickLink] —— Baseplate 16 x 22 2145 —— Brick, Arch 2 x 6 x 5 Ornamented 2337 —— Windscreen 4 x 4 x 2 Canopy Extender 2557 [2557c* on BrickLink] —— Boat Hull Large Bow 12 x 16 x 5 1/3, w/ Top 2559 [2559c* on BrickLink] —— Boat Hull Large Stern 14 x 16 x 5 1/3, w/ Top 2623 —— Boat Bow Top 8 x 10 x 1 2711 —— Technic, Plate 1 x 5 with Toothed Ends, 2 Studs and Center Axle Hole 3144 —— Antenna with Side Spokes 3334 —— Baseplate 16 x 24 3358 —— Fence Gate 1 x 3 x 2 3359 —— Fence Gate 1 x 3 x 2 Base 3481 —— Plate, Modified 2 x 2 with Helicopter Tail Rotor Holder 3497 —— Baseplate 8 x 24 3612 —— Arm Piece Straight with 2 and 3 Fingers 3613 —— Arm Piece with Tow Ball Socket, 3 Fingers 3671 [367 on BrickLink] —— Baseplate 24 x 24 with Studs on Edges 4169 —— Bracket 2 x 3 - 1 x 3 (Train Signal Stand) 4187 —— Baseplate 8 x 32 4263 —— Technic, Plate 1 x 4 with Toothed Ends 4318 —— Boat Mast 2 x 2 x 9 2/3 Bar with Slot on Top and 2 Finger Hinge on Two Sides 4508 [251 on Bricklink] —— Turntable 2 x 2 Plate with Hinge, Base 4743 —— Brick, Arch 2 x 8 x 3 6051 [6051c* on BrickLink] —— Boat Hull Small Bow 12 x 12 x 5 1/3, w/ Top 6053 [6053c* on BrickLink] —— Boat Hull Small Stern 12 x 12 x 5 1/3, w/ Top 6054 —— Boat Hull Small Middle 8 x 12 6085 —— Cockpit 5 x 8 x 3 (Windscreen Bottom) 24855 —— Plant Flower Stem with Bottom Pin 24866 —— Plate, Round 1 x 1 with Flower Edge (5 Petals) —— [v2] 25059 —— Train, Track Roller Coaster Straight 16L 25061 —— Train, Track Roller Coaster Curve, 90 degrees 25195 —— Plate, Modified 2 x 6 with Pole Holder Pin 26021 —— Vehicle, Base 4 x 5 Roller Coaster Car 26022 —— Train, Track Roller Coaster Straight 8L 26073 —— Minifigure, Backpack with Bedroll Pattern —— is multi-colorable 26559 —— Train, Track Roller Coaster Ramp Large Lower Part, 6 Bricks Elevation 26560 —— Train, Track Roller Coaster Ramp Large Upper Part, 6 Bricks Elevation 26561 —— Train, Track Roller Coaster Ramp Steep, 6 Bricks Elevation 27448 —— Tile, Modified 2 x 2 with Large Hole 28618 —— Wave Rounded with Base Rim (Castle Dragon Flame, Seaweed, Water) 28802 —— Bracket 1 x 2 - 1 x 4 with Two Rounded Corners at the Bottom —— includes collision data 28974 —— Minifigure, Neck Bracket with Back Stud - Thick Back Wall 29096 —— Cone Half 10 x 5 x 6 30010 —— Panel 1 x 2 x 1 —— [4865 on BrickLink] 30014 —— Arm Holder Brick 1 x 2 with 2 Horizontal Fingers 30034 —— Panel 3 x 5 Solar/Clip-On/Deltoid 30073 —— Door 1 x 6 x 8 Left 30074 —— Door 1 x 6 x 8 Right 30082 —— Arm Piece with Tow Ball and Clip 30219 —— Bar 16L with Open Stud, Tow Ball, and Slit (Windsurfer Mast) 30271 —— Baseplate, Raised 32 x 48 x 6 with 4 Corner Pits 30298 —— Windscreen 10 x 14 x 2 2/3 Roll Cage 30348 [30346c01 on BrickLink] —— Electric, Light Rock Raiders Laser (30346c00 / 30348) —— is multi-colorable 30371 —— Minifigure, Head Modified SW Gungan Split Eyes 30619 —— Cockpit 6 x 6 x 5 with Hinge 32606 —— Friends Accessories Flower with 7 Thick Petals and Pin —— has incorrect 3D geometry 32607 —— Plant Plate, Round 1 x 1 with 3 Leaves —— has incorrect 3D geometry and boundary box 32802 —— Slope, Inverted 45 4 x 1 Double 32803 —— Slope, Curved 2 x 2 Inverted 34732 —— Panel 1 x 4 x 6 Wavy 34738 —— Train, Track Roller Coaster Ramp Small, 3 Bricks Elevation 35044 —— Plate, Modified 4 x 4 with Curved Cutout 35188 —— Technic, Changeover Rotary Catch 35366 —— Bar 2.25 x 5.25 Double Squares (BrickHeadz Glasses Square) 35442 —— Plate, Round 2 x 2 with 6 Gear Teeth / Flower Petals 35443 —— Plate, Round 4 x 4 with 10 Gear Teeth / Flower Petals 35446 —— Plate, Round 6 x 6 with 14 Gear Teeth / Flower Petals 35459 —— Tile, Modified 1 x 3 Inverted with Hole 35464 —— Slope 45 1 x 1 Double 35480 —— Plate, Modified 1 x 2 Rounded with 2 Open Studs 35485 —— Minifigure, Weapon Hoop Blade / Chakram 35574 —— Cone 2 x 2 x 1 2/3 with Stacked Rings (Beehive / Cotton Candy) 35646 —— Rock 1 1/3 x 1 1/3 x 1 35649 —— Tile, Modified 1 x 2 Diamond 35654 —— Bar 1 x 4 x 1 2/3 (Grille Guard / Push Bumper) 35660 —— Minifigure, Hair Combo, Hair with Hat, Ponytail with Ball Cap Pattern —— is multi-colorable 35700 —— Container, Box 2 x 2 x 1 - Top Opening 35787 —— Tile, Modified 2 x 2 Triangular 35789 —— Vehicle, Mudguard 4 x 2 1/2 x 2 1/3 with Arch Round, Solid Studs, and Rounded Legs 36036 —— Lower Body, Skirt 36840 —— Bracket 1 x 1 - 1 x 1 Inverted 36841 —— Bracket 1 x 1 - 1 x 1 —— includes collision data 37195 —— Wheel Cover 28 Spoke - 18mm D. - for Wheel 56145 37352 —— Brick, Modified 1 x 2 x 1 No Studs, Curved Top 37494 —— Hinge Train Pantograph Shoe 37695 —— Plant Stem with 3 Leaves and Bottom Pin [v2] 37762 —— Minifigure, Utensil Candle 37775 —— Candle Flame 37776 —— Minifigure, Utensil Lantern 38014 —— Minifigure, Utensil Tea Cup 38320 —— Window 1 x 2 x 2 Pane Lattice Diamond —— v2 38391 —— Plate, Modified 1 x 2 with Handles - Round Ends, Mid Attachment [3839a on BrickLink] 38583 —— Brick, Arch 1 x 2 Jumper 38585 —— Brick, Arch 2 x 2 Corner 38799 —— Minifigure, Utensil Tea Saucer with Hollow Stud on Top 39262 —— Minifigure, Headgear Crown with 5 Points, Open Center Stud 39611 —— Plate, Round 4 x 4 x 2/3 with Star and 1 Open Stud 39739 —— Tile, Round 1 x 1 Heart 39789 —— Technic, Brick 2 x 4 with 3 Axle Holes 39802 —— Minifigure, Utensil Axe with Head and Blade, Pick End and Long Handle —— is multi-colorable 40811 —— Plate, Modified 1 x 1 with Clip Light - Thin Ring —— [4081a on BrickLink] 41682 —— Bracket 2 x 2 - 1 x 2 Centered 41740 —— Plate, Modified 1 x 4 with 2 Studs with Groove 41812 —— Projectile Launcher 4 x 2 x 1 with Bottom Axle (Launches 1 x 1 Round Tiles) —— is missing conenctivity for 1 x 1 Round Tiles 41823 —— Fence 3 x 3 x 2 Quarter Round Ornamental with 2 Studs 41948 —— Plate, Round 8 x 8 Rounded End 42716 —— Wheel 30.4mm D. x 20mm with No Pin Holes and 5 Large Spokes —— includes collision data 42862 —— Wedge 3 x 3 Sloped Left 42918 —— Slope, Curved 8 x 2 43045 —— Hinge Plate 2 x 4 with Pin Hole and 2 Holes - Top 43056 —— Hinge Plate 2 x 4 with Pin Hole and 2 Holes - Bottom 44709 —— Minifigure, Weapon Gun, Blaster with Studs on Sides, Bottom, and Front 45755 —— Minifigure, Headgear Head Cover —— is multi-colorable 46524 [40931 on Bricklink] —— Electric, Light & Sound Siren 2 x 6 x 1 with Lights —— is multi-colorable 48165 —— Wedge 3 x 3 Sloped Right 48205 —— Wedge, Plate 6 x 4 Right 48208 —— Wedge, Plate 6 x 4 Left 48995 —— Tile, Modified 3 x 2 with Hole 49097 —— Vehicle, Mudguard 3 x 3 x 1 with Arch Round 49098 —— Wheel Cover 10 Spoke Recessed 49307 —— Brick, Modified 1 x 1 x 2/3 No Studs, Curved Top 49308 —— Brick, Round 3 x 3 x 1 1/3 Dome Top - Open Stud 49309 —— Cone 2 x 2 x 2 Inverted 49311 —— Brick 1 x 4 x 3 49618 —— Slope 25 8 x 1 x 3 51239 —— Window 1 x 3 x 3 Flat Front 51266 —— Glass for Window 1 x 3 x 3 Flat Front 51270 —— Pumpkin 51283 —— Minifigure, Headgear Helmet Round Fishbowl 51542 —— Baseplate, Raised 32 x 48 x 6 with Level Front 52985 —— Tire 68.7 x 27 S 53119 —— Plate, Round 1 x 1 with Horizontal Swirl / Twist 66727 —— Wheel 18mm D. x 12mm with Pin Hole and Stud, Dotted Brake Rotor Lines 56074 —— Windscreen 12 x 12 x 2 57915 —— Boat Hovercraft Skirt, Unitary 64570 —— Bracket 2 x 6 - 1 x 6 Inverted 65426 —— Wedge, Plate 4 x 2 Right, Pointed —— v2 65429 —— Wedge, Plate 4 x 2 Left, Pointed —— v2 65581 —— Minifigure, Utensil Lantern with Large Round Handle 65632 —— Windscreen 6 x 6 x 1 2/3 65633 —— Windscreen 6 x 6 x 1 1/3 65634 —— Vehicle, Base 6 x 12 x 1 with 5 x 4 Recessed Center and 8 Holes 65635 —— Technic, Brick 2 x 6 x 1 1/3 with Axle Holes 65734 —— Brick, Modified 1 x 4 x 2 2/3 with Curved Top 65735 —— Windscreen 1 x 10 x 4 71183 —— Bar 1L with 1 x 1 x 2/3 Light Holder 71184 —— Bar 4.5L with Stop Ends 98107 —— Cylinder Hemisphere 11 x 11, Studs on Top 189781 —— Wheel Cover 5 Spoke - for Wheel 18976 —— 18978-1 189782 —— Wheel Cover 10 Spoke - for Wheel 18976—— 18978-2 189791 —— Wheel Cover 7 Spoke Y Shape - for Wheel 18976 —— 18979-1 189792 —— Wheel Cover 10 Spoke T Shape - for Wheel 18976 —— 18979-2 243081 —— Wheel Cover 10 Spoke (Spokes in Pairs) - for Wheel 18976 —— 24308-1 243082 —— Wheel Cover 10 Spoke Y Shape - for Wheel 18976 —— 24308-2 291171 —— Wheel Cover 5 Spoke Wide - for Wheel 18976 —— 29117-1 291172 —— Wheel Cover 5 Spoke Framed - for Wheel 18976 —— 29117-2 377201 —— Minifigure, Weapon Batarang, Shield Size with Stud on Front —— 37720-1 377202 —— Minifigure, Weapon Batarang, Very Small —— 37720-2 377203 —— Minifigure, Weapon Batarang with Bar Ends —— 37720-3 377204 —— Minifigure, Weapon Batarang with Bar Handle on Bottom —— 37720-4 377205 —— Minifigure, Weapon Batarang, Wide with Stud on Front —— 37720-5 500181 —— Minifigure, Weapon with 3 Mechanical Arms —— 50018-1 500182 —— Minifigure, Weapon Pistol, Bar on Front, Studs on Sides, Handle on Back and Bottom —— 50018-2 500183 —— Minifigure, Weapon, Bar on Front, Stud on Back —— 50018-3 500184 —— Minifigure, Weapon with 2 Mechanical Arms —— 50018-4 500185 —— Minifigure, Weapon with Bar and Stud —— 50018-5 500186 —— Minifigure, Weapon Bowl with 3 Reinforcements —— 50018-6 500187 —— Minifigure, Weapon Circular Saw —— 50018-7 611901 —— Minifigure, Armor Leg Anti-Blast Kama —— 61190-1 611902 —— Minifigure, Armor Pauldron Plastic —— 61190-2 611903 —— Minifigure, Visor SW Clone Trooper —— 61190-3 611906 —— Minifigure, Weapon Gun, Blaster Small DC-17 (SW) —— 61190-6 626981 —— Minifigure, Utensil Computer Laptop —— 62698 - open 626982 —— Minifigure, Utensil Computer Laptop —— 62698 - closed Corrected parts 30838 — attaches to axle connections now 2452 — has connection points on its bottom now 24201 — studs are now hollow 35660 — is now multi-colorable [select the correct base color and re-color the cap] 19917 — updated connection point 34412 — is an assembly now — place in "Assemblies" folder 11538 — is multi-colorable 18934 — is multi-colorable 20460/2046121019 — is multi-colorable 20603 — is multi-colorable 24601 — is multi-colorable 27162 — is multi-colorable 28501 — is multi-colorable 30311 — is multi-colorable 30329 — is multi-colorable 38320 — updated connection points 98099 — updated connection points 93064 — is now multi-colorable 69065 — is now multi-colorable 93067 — is now multi-colorable Edited October 29, 2023 by Stephan Merged into version α0520. Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) JUNE 2020 UPDATE 06-2020 [version 200517] or GitHub [download files separate] New parts 35186 —— Technic, Driving Ring Extension with 8 Teeth Inside and Outside 35189 —— Technic, Steering Wheel Hub 3 Pin Holes Round 39367 [39367c* on BrickLink] —— Wheel 56 x 14 Technic with Axle Hole and 8 Pin Holes with Fixed Rubber Tire —— is multi-colorable 66606 —— Cone Half 6 x 4 x 10 (Elliptic Paraboloid) 2619 —— Monorail Motor Cover —— includes collission data 2670 —— Monorail Track Straight Short —— includes collission data 2671 —— Monorail Track Straight Long —— includes collission data 2672 —— Monorail Track Curve Long —— includes collission data 2677 —— Monorail Track Ramp Lower Part —— includes collission data 2678 —— Monorail Track Ramp Upper Part —— includes collission data 2681 —— Support 6 x 6 x 10 Stanchion —— v2 —— includes collission data 268400 (2682/3/4/5) [BrickLink 2684c01b] —— Monorail Motor 9V with Long Couplings —— v3 —— is multi-colorable; includes collission data 268600 (2686/2697) —— Monorail Bogey —— v3 —— is multi-colorable; includes collission data 2687 —— Monorail Base 4 x 20 —— v2 —— includes collission data 277400 (2774) —— Monorail Track Monoswitch —— is multi-colorable; includes collission data 279300 (2793/2796/2806) [BrickLink 2793c0*] —— Pneumatic Cylinder with 2 Inlets Medium (48mm) with Top —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 472240 (2796/47224) [BrickLink 47224c0*] —— Pneumatic Cylinder with 2 Inlets and Rounded End Medium (48mm) —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 279700 (2797/2806/279701/2) [BrickLink 2797c0*] —— Pneumatic Pump Second Version with Top —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 288900 (2880/1/2/3/4/2890/2911) [BrickLink 2889] —— Monorail Track Point Right —— v2 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 289000 (2883/4/5/6/7/2890/2911) [BrickLink 2890] —— Monorail Track Point Left —— v2 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 2891 —— Monorail Track Curve Short Right —— includes collission data 2892 —— Monorail Track Curve Short Left —— includes collission data 74982 (2943/4/9388) [BrickLink x191c01] —— Pneumatic Pump Small (5.5L) —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19482 (2944/9388/99799) [BrickLink 99798c01] —— Pneumatic Pump Small (6L) —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19475 (2944/7/9388) [BrickLink 19475c01] —— Pneumatic Cylinder V2 1 x 5 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19476 (9112/9145/21828) [BrickLink 21828c01] —— Pneumatic Cylinder V2 1 x 11 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19478 (9113/19466/21828) [BrickLink 19467c01] —— Pneumatic Cylinder V2 2 x 11 —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 19474 (9417/9) [BrickLink bb0874] —— Pneumatic Switch with Pin Holes and Axle Hole —— v3 —— is multi-colorable; includes collission data 26288 (26280/932901/2) [BrickLink 26288c01] —— Pneumatic Pump Large (11L) with 1 x 3 Liftarm —— v3 —— is multi-colorable; includes collission data; NOTE: when moving the parts: select entire assembly 324960 (32495/6) [BrickLink x873c01/32495c01] —— Technic, Steering Arm with 4 Ball Joints with Wheel Hub (x872 / x873) —— v2 —— is multi-colorable; includes collission data 42531 —— Technic, Panel Car Mudguard Arched 9 x 2 x 3 —— v2 —— includes collission data 42545 [BrickLink 42545*] —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 —— v2 —— includes collission data 47222/3 [BrickLink 4694bc01] —— Pneumatic Switch with Pin Holes —— v3 —— includes collission data 469400 [BrickLink 4694c01] —— Pneumatic Switch with Top Studs —— v3 —— includes collission data 53178 —— Pneumatic Cylinder Bracket —— v2 —— includes collission data 35185 —— Technic, Gear 20 Tooth Double Bevel with Clutch on Both Sides —— includes collission data 35563 —— Tower Roof 2 x 4 x 4 Half Cone Shaped with Roof Tiles 39790 —— Technic, Liftarm 11 x 15 Open Center Frame Thick 39794 —— Technic, Liftarm 7 x 11 Open Center Frame Thick Fixed parts 24314 [24314c* on BrickLink] —— Wheel Wheelchair with Fixed Hard Rubber Tire (1-Piece Wheel) —— is multi-colorable 32235 —— Hose, Soft Axle 19L —— is now flexible 32607 —— Plant Plate, Round 1 x 1 with 3 Leaves —— updated boundary box 4151 [4151b on BrickLink] —— Plate, Modified 8 x 8 with Grille and Hole in Center —— updated collision data 42862 —— Wedge 3 x 3 Sloped Left —— updated boundary box 48165 —— Wedge 3 x 3 Sloped Right —— updated boundary box 28925 [28533c* on BrickLink] —— Boat, Hull Unitary 16 x 8 Base with Boat Hull Unitary 16 x 8 Top (28533 / 28535) —— is now multi-colorable 30010 —— Panel 1 x 2 x 1 —— updated xml 2620 —— Windscreen 4 x 4 x 3 Canopy —— location hinge attachment point fixed 2680 —— Support 4 x 4 x 5 Stanchion —— moved to "Trains" category 6573 —— Technic, Gear Differential, 24-16 Teeth —— updated collission data 11946 —— Technic, Panel Fairing #21 Very Small Smooth, Side B —— fixed default orientation 14720 —— Technic, Liftarm 3 X 5 Perpendicular H-Shape Thick —— moved to "Technic Beams" category 15458 —— Technic, Panel Plate 3 x 11 x 1 —— moved to "Technic Panels" category 18450 —— Tire 81.6 x 44 R —— fixed center attachment point 18938 —— Technic, Turntable Large Type 3 Top, 60 Tooth —— moved to "Technic Gears" category 18939 —— Technic, Turntable Large Type 3 Base —— moved to "Technic Gears" category 18940 —— Technic, Gear Rack 1 x 14 x 2 Housing —— added ability to manualy slide gear rack 18942 —— Technic, Gear Rack 1 x 14 x 2 with Axle and Pin Holes —— added ability to manualy slide gear rack 18945 —— Technic, Panel Plate 5 x 11 x 1 Tapered —— moved to "Technic Panels" category 25214 —— Brick, Round 1 x 1 d. 90 Degree Elbow - No Stud - Type 2 - Axle Hole —— v2 —— moved to "Technic Connectors" category 41896 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 3 Pin Holes —— fixed center attachment point 45982 —— Tire 81.6 x 38 R Balloon —— fixed center attachment point; updated 3D model 48002 [BrickLink 48002a] —— Boat, Mast 2 x 2 x 20 with Holes - Side Aligned x shape Axle Hole —— fixed collission data 56908 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pin Holes —— fixed center attachment point 60483 —— Technic, Liftarm 1 x 2 Thick with Pin Hole and Axle Hole —— moved to "Technic Beams" category 64178 —— Technic, Liftarm 5 x 11 Open Center Frame Thick —— moved to "Technic Beams" category 64179 —— Technic, Liftarm 5 x 7 Open Center Frame Thick —— moved to "Technic Beams" category 64391 —— Technic, Panel Fairing # 4 Small Smooth Long, Side B —— fixed default orientation 64393 —— Technic, Panel Fairing # 6 Long Smooth, Side B —— fixed default orientation 64680 —— Technic, Panel Fairing #14 Large Short Smooth, Side B —— fixed default orientation 64682 —— Technic, Panel Fairing #18 Large Smooth, Side B —— fixed default orientation 64782 —— Technic, Panel Plate 5 x 11 x 1 —— moved to "Technic Panels" category 87080 —— Technic, Panel Fairing # 1 Small Smooth Short, Side A —— fixed default orientation 87086 —— Technic, Panel Fairing # 2 Small Smooth Short, Side B —— fixed default orientation 92693/4/6/4694/5 [BrickLink 92693c01] —— Technic, Linear Actuator Mini with Head and Axle —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 76537 —— Technic, Shock Absorber 6.5L - Hard Spring —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 95292 —— Technic, Shock Absorber 9.5L —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly; replaces 41475, 74741, 75348 61927 —— Technic, Linear Actuator with Ends —— added ability to manualy adjust extension; NOTE: when moving the parts: select entire assembly 35186 —— Technic, Driving Ring Extension with 8 Teeth Inside and Outside —— v3 —— added collission data 35188 —— Technic, Changeover Rotary Catch —— v2 —— added collission data 35480 —— Plate, Modified 1 x 2 Rounded with 2 Open Studs —— v2 —— added collission data 36841 —— Bracket 1 x 1 - 1 x 1 —— v3 —— added collission data 41682 —— Bracket 2 x 2 - 1 x 2 Centered —— v2 —— added collission data Edited October 29, 2023 by Stephan Merged version 202006α Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) JULY 08 2020 UPDATE 08-07-2020 [version 200708] or GitHub [download files separate] and LXF file with new parts New parts 39793 —— Technic, Pin Connector Block, Liftarm 1 x 3 x 3 Updated parts 268400 (2682/3/4/5) [BrickLink 2684c01b] —— Monorail Motor 9V with Long Couplings —— v3 268600 (2686/2697) —— Monorail Bogey —— v3 279300 (2793/2796/2806) [BrickLink 2793c0*] —— Pneumatic Cylinder with 2 Inlets Medium (48mm) with Top —— v3 472240 (2796/47224) [BrickLink 47224c0*] —— Pneumatic Cylinder with 2 Inlets and Rounded End Medium (48mm) —— v3 279700 (2797/2806/279701/2) [BrickLink 2797c0*] —— Pneumatic Pump Second Version with Top —— v3 74982 (2943/4/9388) [BrickLink x191c01] —— Pneumatic Pump Small (5.5L) —— v3 19482 (2944/9388/99799) [BrickLink 99798c01] —— Pneumatic Pump Small (6L) —— v3 19475 (2944/7/9388) [BrickLink 19475c01] —— Pneumatic Cylinder V2 1 x 5 —— v3 19476 (9112/9145/21828) [BrickLink 21828c01] —— Pneumatic Cylinder V2 1 x 11 —— v3 19478 (9113/19466/21828) [BrickLink 19467c01] —— Pneumatic Cylinder V2 2 x 11 —— v3 26288 (26280/932901/2) [BrickLink 26288c01] —— Pneumatic Pump Large (11L) with 1 x 3 Liftarm —— v3 324960 (32495/6) [BrickLink x873c01/32495c01] —— Technic, Steering Arm with 4 Ball Joints with Wheel Hub (x872 / x873) —— v3 39790 —— Technic, Liftarm 11 x 15 Open Center Frame Thick —— v2 39794 —— Technic, Liftarm 7 x 11 Open Center Frame Thick —— v2 53178 —— Pneumatic Cylinder Bracket —— v2 42531 —— Technic, Panel Car Mudguard Arched 9 x 2 x 3 —— v2 42545 —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 —— v2 36841 —— Bracket 1 x 1 - 1 x 1 —— v3 35186 —— Technic, Driving Ring Extension with 8 Teeth Inside and Outside —— v3 19474 (9417/9) [BrickLink bb0874] —— Pneumatic Switch with Pin Holes and Axle Hole —— v2 47222/3 [BrickLink 4694bc01] —— Pneumatic Switch with Pin Holes —— includes collission data —— v2 469400 [BrickLink 4694c01] —— Pneumatic Switch with Top Studs —— v2 2681 —— Support 6 x 6 x 10 Stanchion —— v2 268400 (2682/3/4/5) [BrickLink 2684c01b] —— Monorail Motor 9V with Long Couplings —— v3 268600 (2686/2697) —— Monorail Bogey —— v3 Edited October 29, 2023 by Stephan Moved 20200708β Share this post Link to post Share on other sites
Stephan Posted May 15, 2020 (edited) JULY 16 2020 UPDATE 16-07-2020 [version 200716] or GitHub [download files separate] and LXF file with new parts IMPORTANT Quote Delete from Primitives: • 41865.xml Place the png files from the Decorations folder in the Decorations folder in the db folder! Replace the DecorationMapping.xml with the included version! New parts 19303 —— Minifigure, Headgear Helmet Mask 24021 [BrickLink 20923c01pb*] —— Minifigure, Headgear Helmet Space with Visor —— multi-colorable and decoratable 32593 [BrickLink 28985pb*] —— Minifigure, Hair Female Long Wavy with Center Part and Antennae —— multi-colorable 32823 —— Minifigure, Armor Neck 34390 [BrickLink 30979pb*] —— Minifigure, Headgear Mask with Spider Leg Horns —— decoratable 48177 [BrickLink 34706c01pb*] —— Minifigure, Armor Breastplate with Rubber Tire Treads —— multi-colorable and decoratable 50044 [BrickLink 35179pb*] —— Minifigure, Hair Combo, Hair and Beard with Top Hat Large with Band with Goggles —— multi-colorable and decoratable 65416 —— Technic, Brake Disc 6 x 6 67329 —— Brick, Modified 1 x 2 x 1 2/3 with Studs on 3 Sides 67810 —— Brick, Modified 2 x 2 x 1 1/3 with Curved Top 68297 —— Wedge, Plate 4 x 8 Cut Corners 405983 [BrickLink 40598c] —— Minifigure, Weapon Larger Blunt Grenade Tip 405984 [BrickLink 40598d] —— Minifigure, Weapon Smaller Tapered Grenade Tip Updated parts 26051 [BrickLink 27456pb*] —— Minifigure, Head Modified Sonic the Hedgehog —— multi-colorable and decoratable • 188 bricks previously added by @jester now have outlines Edited October 29, 2023 by Stephan Added version β20200716 Share this post Link to post Share on other sites
Stephan Posted May 16, 2020 (edited) Version 20200803 Version 20200803 or GitHub [download files separate] and LXF file with new parts New parts 15522 —— Minifigure, Head Modified Simpsons Marge Simpson 15523 —— Minifigure, Head Modified Simpsons Bart Simpson 15524 —— Minifigure, Head Modified Simpsons Lisa Simpson 15525 —— Minifigure, Head Modified Simpsons Maggie Simpson 15527 —— Minifigure, Head Modified Simpsons Homer Simpson 22969 —— Wheel 62mm D. x 46mm Technic Racing Large 32296 —— Tire 81.8 x 50 Technic Straight Tread 32298 —— Tire Technic Power Puller 37598 —— Minifigure, Head Modified Groot —— decoratable 38394 —— Minifigure, Costume Race Car —— decoratable 46334 —— Wheel 75mm D. x 15.8mm Motorcycle 46335 —— Tire 94.3mm D. x 38mm Motorcycle Racing Tread 65617 —— Brick, Round Corner 3 x 3 x 1 without Studs 67140 —— Tire 94.3mm D. Motorcycle Racing Tread Narrow Updated parts 10124 —— Arm Giant, Right —— decoratable 10154 —— Arm Giant, Left —— decoratable 18807 [BrickLink 18662c01pb*] —— Body Giant, Darkseid —— multi-colorable and decoratable 30978 —— Arm Giant, Left with Plate Armor —— multi-colorable 33749 [BrickLink 10121c04pb*] —— Body Giant, Hulk with Helmet with Plume —— multi-colorable and decoratable 33827 [BrickLink 33827c01pb*] —— Body Giant, Bane —— multi-colorable and decoratable 76382 [BrickLink 973pb3059c01] —— Torso Reddish Brown Bark Plates and Dark Green Underneath Pattern —— new decoration Edited October 29, 2023 by Stephan Added version 20200803 Share this post Link to post Share on other sites
Stephan Posted May 19, 2020 (edited) Version 20200805 Version 20200805 or GitHub [download files separate] and LXF file with new parts New parts 40918 —— Technic, Linear Actuator Long —— select assembly when moving 46834 —— Technic, Clutch Connector Female / Outside 46835 —— Technic, Clutch Connector Male / Inside 46882 —— Technic, Panel Car Mudguard 15 x 2 x 7 65413 —— Technic, Gear 28 Tooth Double Bevel with Pin Hole 65414 —— Technic, Gear Differential Housing —— has connection points for the three inside gears Updated parts 22969 —— Wheel 62mm D. x 46mm Technic Racing Large —— collisions updated 47996 —— Boat, Mast Rigging Long 28 x 3.5 —— is now flexible Edited October 29, 2023 by Stephan Added version 20200805 Share this post Link to post Share on other sites
Stephan Posted May 20, 2020 (edited) Version 20200820 Version 20200820 or GitHub [download files separate] and LXF file with new parts New parts 22127 [BrickLink bb0961c01] —— Electric Battery Box Powered Up Bluetooth Hub with Bottom —— multi-colorable 22169 [BrickLink bb0959c01] —— Electric, Motor - Powered Up, L —— multi-colorable 22172 [BrickLink bb0960c01] —— Electric, Motor - Powered Up, XL —— multi-colorable 22169 [BrickLink 54675c01] —— Electric, Motor Large Angular - Spike Prime —— multi-colorable Updated parts 18923 —— Vehicle, Base 8 x 16 x 2 1/2 with Mudguards and 14 x 4 Recessed Center with 3 Holes —— connections updated 18926 —— Vehicle, Tipper Bed 12 x 8 x 5 —— connections updated 32187 —— Technic, Driving Ring Extension —— connections updated 46882 [BrickLink 46882pb01] —— Technic, Panel Car Mudguard 15 x 2 x 7 with Black Stripe Pattern —— 6316344 Other changes • Created a custom Template in the Mindstorms Theme: 2020 New Pre-Colored Parts. Place in the Palettes folder. • Updated MaterialNames: added 353 'Vibrant Coral', added "Silver Ink.," to 298. • Updated CurrentMaterials.xml: added 353 'Vibrant Coral', moved 107 'Bright Bluish Green' and 298 'Silver Ink., Cool silver, drum lacq' to Current colors. • Updated Materials.xml: added 353 'Vibrant Coral'. • Unzipped the LDDExtended.lif, add the included 'LDDExtended' folder to the Templates folder, removed LDDExtended.lif. Edited October 29, 2023 by Stephan Added version 20200820. Share this post Link to post Share on other sites
Stephan Posted May 21, 2020 (edited) Version 20200821 Version 20200821 or GitHub [download files separate] and LXF file with all colors Other changes • Added new colors: 341 'Tr. Bright Orange Glitter', 351 'Tr. Bright Green Glitter', 360 'Tr. Clear Opal', 362 'Tr. Blue Opal' and 364 'Tr. Med. Red. Violet Opal'; • Named more obscure colors. Edited October 29, 2023 by Stephan Added version 20200821 Share this post Link to post Share on other sites
Stephan Posted May 22, 2020 (edited) Version 20200906 Version 20200906 or GitHub [download files separate] and LXF file with new parts New parts 6594 —— Tire 49.6 x 28 VR 22253 —— Wheel 36.8mm D. x 26mm VR with X Axle Hole 30116 —— Panel 14 x 14 x 2 2/3 Quarter Saucer Top 30118 —— Wing Plate Bi-level 8 x 4 and 2 x 3 1/3 Up 30119 —— Wing Plate Bi-level 8 x 4 and 2 x 3 1/3 Down 30320 —— Panel 10 x 10 x 2 1/3 Quarter Saucer Top 32057 —— Wheel 70 x 14 mm Futuristic 32076 —— Tire 70 x 14 mm Futuristic 32077 —— Wheel 70 x 28 mm Futuristic 32078 —— Tire 70 x 28 mm Futuristic 32180 —— Tire 56 x 30 R Balloon 32195 [32195b on BrickLink] —— Technic, Steering Arm 6.5 x 2 with Tow Ball Socket Rounded, Chamfered 32196 —— Tire 81.6 x 34 ZR Technic Thin Sporty Tread 32197 —— Wheel 81.6 x 34 ZR Three Spoke Swirl 37383 —— Wheel 62.3mm D. x 42mm Technic Racing Large —— is multi-colorable 37452 —— Brick, Modified 1 x 2 x 2 with Paper / Photo Holder —— no outlines 42529 —— Technic Tread Sprocket Wheel Extra Large 49294 —— Wheel 56mm D. x 34mm Technic Racing Medium, 6 Pin Holes, Axle Hole, Open Spokes 52629 —— Ball, Hard Plastic 19mm D. (Spike Prime) 56907 —— Tire 81.6 x 36 R Technic Straight Tread 65092 —— Tile, Modified 1 x 1 Octagonal Jewel —— no outlines New decorations/prints 29096 [BrickLink 29096pb01] —— Cone Half 10 x 5 x 6 with SW Millennium Falcon Cockpit Pattern —— [6205311] 30116 [BrickLink 30116pb01] —— Panel 14 x 14 x 2 2/3 Quarter Saucer Top with UFO Pattern Left 30116 [BrickLink 30116pb02] —— Panel 14 x 14 x 2 2/3 Quarter Saucer Top with UFO Pattern Right 30116 [BrickLink 30116pb03] —— Panel 14 x 14 x 2 2/3 Quarter Saucer Top with Millennium Falcon Pattern 30320 [BrickLink 30117pb01] —— Panel 10 x 10 x 2 1/3 Quarter Saucer Top with UFO Pattern Left 30320 [BrickLink 30117pb05] —— Panel 10 x 10 x 2 1/3 Quarter Saucer Top with UFO Pattern Right 30118 [BrickLink 30118pb01] —— Wing Plate Bi-level 8 x 4 and 2 x 3 1/3 Up with Silver/Orange/Black UFO Pattern 30118 [BrickLink 30118pb03] —— Wing Plate Bi-level 8 x 4 and 2 x 3 1/3 Up with Silver/Orange/Black UFO Logo Pattern 30119 [BrickLink 30119pb01] —— Wing Plate Bi-level 8 x 4 and 2 x 3 1/3 Down with Silver/Orange/Black UFO Logo Pattern Updated parts 3144 —— Antenna with Side Spokes —— added colissions 3334 —— Baseplate 16 x 24 —— added colissions 3358 —— Fence Gate 1 x 3 x 2 —— added colissions 3359 —— Fence Gate 1 x 3 x 2 Base —— added colissions 3481 —— Plate, Modified 2 x 2 with Helicopter Tail Rotor Holder —— added colissions 49311 —— Brick 1 x 4 x 3 —— added colissions 51266 —— Glass for Window 1 x 3 x 3 Flat Front —— added colissions 64570 —— Bracket 2 x 6 - 1 x 6 Inverted —— added colissions 67329 —— Brick, Modified 1 x 2 x 1 2/3 with Studs on 3 Sides —— added colissions 37775 —— Wave Rounded Small with Pin (Candle Flame) —— added colissions 28802 —— Bracket 1 x 2 - 1 x 4 with Two Rounded Corners at the Bottom —— updated 3D model, added outlines 64782 —— Technic, Panel Plate 5 x 11 x 1 —— updated 3D model 3031 —— Plate 4 x 4 —— updated collision data 88292 —— Brick, Arch 1 x 3 x 2 —— updated collision data 26603 —— Tile 2 x 3 —— updated collision data 29096 —— Cone Half 10 x 5 x 6 —— updated collision data, is now decoratable 2995 —— Tire 68.8 x 40 Balloon Large —— changed default orientation 2996 —— Wheel 68.8 x 40 Balloon Large —— changed default orientation, fixed collision error 41896 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 3 Pin Holes —— changed default orientation 45982 —— Tire 81.6 x 38 R Balloon —— improved 3D model 56908 —— Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pin Holes —— changed default orientation, improved 3D model, improved collision 54690 —— Electric, Converter Cable, Mindstorms NXT 35cm —— moved to Electric parts category 41896 —— Wheel 56mm D. x 34mm Technic Racing Medium, 6 Pin Holes —— is multi-colorable Other changes • Updated image '274' for the Rails category, folder: MainGroupDividers. • Updated 2020NewPreColoredParts palette with 15038pb01 [6062522], 35187pb01 [6217976], 29096pb01 [6205311], 30116pb01, 30116pb02, 30116pb03, 30117pb01, 30117pb05, 30118pb01, 30118pb03. Edited October 29, 2023 by Stephan Started on version 20200906 Share this post Link to post Share on other sites
Stephan Posted May 22, 2020 (edited) Version 20200924 Version 20200924 or GitHub [download files separate] and LXF file with new parts New parts 464900 —— Technic, Steering Axle with 2 Pin Holes, 2 Axle Holes and 2 Ball Joint Arms with Wheel Hub (46490 / 92909) 46372 —— Technic, Gear 28 Tooth Double Bevel 49283 —— Technic, Axle and Wire Connector 52730 —— Technic, Steering CV Joint Axle, Wide 52731 —— Technic, Steering CV Joint, Large Ball 44861 —— Plate, Modified 1 x 2 with Open O Clip on Top —— outlines need improving 999992 —— BuWizz 2.0 Ludicrous —— multi-colorable —— outlines need improving Updated parts 6594 —— Tire 49.6 x 28 VR —— updated 3D model 22253 —— Wheel 36.8mm D. x 26mm VR with X Axle Hole —— updated 3D model 32180 —— Tire 56 x 30 R Balloon —— updated 3D model 32077 —— Wheel 70 x 28 mm Futuristic —— improved outlines 45982 —— Tire 81.6 x 38 R Balloon —— improved 3D model —— updated collision data 37452 —— Brick, Modified 1 x 2 x 2 with Paper / Photo Holder —— updated outlines 37383 —— Wheel 62.3mm D. x 42mm Technic Racing Large —— updated collision data Other changes • Updated 2020NewPreColoredParts palette with 464900 [6275902], 999992 (BuWizz 2.0) [9999920]. Edited October 29, 2023 by Stephan Added version 20200924. Share this post Link to post Share on other sites
Stephan Posted May 25, 2020 (edited) Version 20201017 Version 20201017 or GitHub [download files separate] and LXF file with new parts New parts [all need outline improvements] 1023 [BrickLink bb0133d] —— Plastic Mars Rover Solar Panel, Rear Trapezoid 1024 [BrickLink bb0133c] —— Plastic Mars Rover Solar Panel, Middle Triangular 1025 [BrickLink bb0133a] —— Plastic Mars Rover Solar Panel, Front Quadrilateral 1026 [BrickLink bb0133b] —— Plastic Mars Rover Solar Panel, Side Quadrilateral 2698 [BrickLink tech0*] —— Technic Figure 2738 —— Technic, Steering Arm 6.5 x 2 with Tow Ball Socket Squared, Un-Chamfered 2999 —— Technic, Steering Wheel Hub Large 5292 —— Electric, Motor RC Race Buggy 6272 —— Electric, RC Race Buggy Battery / Receiver Unit with Auxiliary Output 6282 —— Electric, RC Race Buggy Steering Unit 9062 —— Pullback Motor 9 x 4 x 2 1/3 with Base, Axle Holes, Studs on Front Top Surface 30037 —— Wing Plate Bi-level 12 x 9 x 2 1/3 32079 —— Technic, Liftarm 1 x 9 Offset Crossover 32137 —— Technic, Modular Connector 32166 —— Technic, Gearbox Half 32283 —— Pullback Motor 9 x 4 x 2 1/3 with Base, Axle Holes, No Studs on Front Top Surface 37191 —— Torso, 2 x 3 Brick Costume / Arms / Hands 66909 —— Minifigure, Weapon Hilt Smooth Extended Updated parts 3020 —— Plate 2 x 4 —— updated collision data 3033 —— Plate 6 x 10 —— updated collision data 3958 —— Plate 6 x 6 —— updated collision data Other changes • Updated 2020NewPreColoredParts palette with: 5292, 3x 37191, 2x 9062, 32283, 6282, 6272, 24x 2698. Edited October 29, 2023 by Stephan Added version 20201017 Share this post Link to post Share on other sites
Stephan Posted May 25, 2020 (edited) Version 20201120 Version 20201120 or GitHub [download files separate] and LXF file with new and updated parts New parts 2712 —— Technic, Plate Rotor 3 Blade with Toothed Ends and 3 Studs (Propeller) 2719 —— Technic, Plate 1 x 10 with Toothed Ends 2737 —— Technic, Steering Arm Large 2792 —— Technic, Steering Rack Top 2900 —— Technic, Flex Cable End, Pin Connection (Square End) 2901 —— Technic, Flex Cable End, Ball Connection 2908 —— Technic, Helicopter Rotor Holder 2989 —— Technic, Brick 1 x 4 with Bumper Holder 2997 —— Tire 81.6 x 34 ZR Technic Straight Tread 2998 —— Wheel 81.6 x 34 Six Spoke 3651 —— Technic, Axle and Pin Connector 4261 —— Technic, Steering Arm 4262 —— Technic, Plate 1 x 6 with Toothed Ends 4273 —— Technic, Axle and Pin Connector Toggle Joint Toothed 4442 —— Technic, Plate 1 x 8 with Toothed Ends 4504 —— Hinge Plate 1 x 6 with 2 and 3 Fingers On Ends 4587 —— Horse Hitching with Hinge 4745 —— Propeller 2 Blade Twisted 6543 —— Technic, Stick Shift Plate 6549 —— Technic, Stick Shift 6642 —— Technic, Flex Cable End Double, Pin Connection 6643 —— Technic, Flex Cable End, Pin Connection 6644 —— Technic, Flex Cable End, Ball Connection with Cage 9244 [BrickLink 9244c01] —— Technic, Universal Joint 4L 16530 —— Tail, Mini Doll Friends Mermaid Hips and Tail Assembly 24108 —— Minifigure, Weapon Sword, Long with Angular Crossguard 25750 —— Minifigure, Hair Mid-Length Tousled, Top Knot Bun with Headband 27055 —— KEY RING AND CHAIN 28125 —— Minifigure, Headgear Bald Head High 29575 —— Minifigure, Headgear Head Cover, Costume Corn Cob Suit 32181 [BrickLink 32181c0*] —— Technic, Shock Absorber 10L Damped 32627 —— Tile, Round 4 x 4 with 2 Hollow Studs 32643 —— Wave Rounded Energy (Power Blast) with Bar Handle 35033 —— Dog Body with Raised Left Front Paw (Krypto the Superdog / Ace the Bat-Hound) 35037 —— Dog Head (Krypto the Superdog) 35039 —— Spider Head and Legs 35180 —— SURF BOARD, W/ KNOB, NO. 3 35494 —— Minifigure, Hair Mid-Length Wavy with Center Part and Sidelocks 35633 —— Large Figure Sword, Small with 3 Bar Holes 35827 —— Minifigure, Headgear Head Cover, Costume Tree Trunk 37829 —— Dinosaur, Baby Standing 39613 —— Plate, Round 3 x 3 Heart 39742 —— Cat, Standing with Spiky Mohawk and Collar 39796 —— Minifigure, Breathing Apparatus, Aviator Oxygen Mask 40933 —— Dragon Head (Ninjago) Upper Jaw with Teeth 40934 —— Dragon Head (Ninjago) Lower Jaw with Teeth 41894 [BrickLink 41894c01] —— Technic, Steering Arm (RC Vehicles) 41805 —— Minifigure, Visor Flight Helmet 65401 [BrickLink 6540a] —— Technic, Steering Arm Large with Wheel Hub Holder - Axle Connection 65402 [BrickLink 6540b] —— Technic, Steering Arm Large with Wheel Hub Holder - Pin Connection 65421 —— Technic, Tipper Drum 6.5 x 13 x 26 Half with 4 Pin Holes and 3L Liftarm Thick 65422 —— Technic, Rotor Blade Large Straight with 3L Liftarm Thick 65509 —— Plate, Modified 2 x 4 with 2 Studs (Double Jumper) 67141—— Technic, Panel Car Mudguard Arched 15 x 2 x 5 Rounded Top 67142—— Technic, Panel Curved #50 5 x 13 Tapered Left 68196—— Technic, Panel Curved #51 5 x 13 Tapered Right 75815 [BrickLink 6637] —— Electric, Fiber Optics Element 299101 [BrickLink 2991] —— Technic, Brick 1 x 2 - 1 x 2 Angled with Bumper Holder 342004-342033 [BrickLink bb0008c04L-bb0008c33L] —— Technic, Flex Cable (Stud Measure) 4L-33L 426502 [BrickLink 4265b] —— Technic, Bush 1/2 Toothed Type II Updated parts 2420 —— Plate 2 x 2 Corner —— v2 —— updated collision data 2698 [BrickLink tech0*] —— Technic Figure —— v2 —— updated collision data 2711 —— Technic, Plate 1 x 5 with Toothed Ends, 2 Studs and Center Axle Hole —— v2 —— added collision data 4263 —— Technic, Plate 1 x 4 with Toothed Ends —— v2 —— added collision data 4727 —— Plant Flower 2 x 2 Leaves - Angular —— v2 —— updated collision data 6272 —— Electric, RC Race Buggy Battery / Receiver Unit with Auxiliary Output —— v2 —— updated collision data 13965 —— Brick, Arch 1 x 3 x 3 —— v2 —— updated collision data 18944 —— Technic, Panel Curved 3 x 13 —— v2 —— updated 3D model 24118 —— Technic, Panel Car Mudguard Arched 15 x 2 x 5 Straight Top —— v2 —— updated 3D model 32079 —— Technic, Liftarm 1 x 9 Offset Crossover —— v2 —— updated collision data & connectivity 35044 —— Plate, Modified 4 x 4 with Curved Cutout —— v2 —— added collision data 42531 —— Technic, Panel Car Mudguard Arched 9 x 2 x 3 —— v3 —— updated 3D model 42545 [BrickLink 42545*] —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 —— v3 —— updated 3D model 46882 —— Technic, Panel Car Mudguard 15 x 2 x 7 —— v2 —— updated 3D model 58856 [BrickLink 21761] —— Hose, Pneumatic 4mm D. V2 Precut 24 mm —— v2 —— fixed flex data 92760 —— Minifigure, Headgear Headdress SW Zabrak Front Skull Spikes and Hair —— v2 —— updated color info 289000 (2883/4/5/6/7/2890/2911) [BrickLink 2890] —— Monorail Track Point Left —— v2 —— updated 3D model Other changes • Updated collisions and connectivity of 4 bricks released in Version 20201017. • Added missing 6282.xml. • Updated 2020NewPreColoredParts palette with: 2x 32181, 2x 92760 [4651406 & 4622292], 3x 16530 [6254070, 6061814 & 6099472], 2x 39742 [6296351 & 6256522], 2x 29575 [6185609 & 6323980], 3x 25750 [6199428, 6228370 & 6258492] • Updated DecorationMapping.xml with preparation for 6302622 on 65421, 6187472 on 32627. Edited October 29, 2023 by Stephan Added version 20201120 Share this post Link to post Share on other sites
Stephan Posted June 17, 2020 (edited) Version 20201222 Version 20201120 or GitHub [download files separate] and LXF file with new and updated parts New parts 20193 —— Foam, Plastic Mirror Front and White Paper Backing 35035 —— Minifigure, Shield Pentagonal with Spikes 35042 —— Minifigure, Helmet Wing 35051 —— DESIGN PLATE 3X4, NO. 1 35473 —— Plant Flower 4 x 4 Rounded Petals 35565 —— Panel 2 x 6 x 6 with Gothic Arch 35578 —— Tire 37 x 14 38317 —— Cone Half 4 x 2 x 3 38551 —— Torso Mini Doll Friends Male [Boy] 40066 —— Door Frame 1 x 6 x 7 Rounded Pillars with Top Arch and Notches 43979 —— Vehicle, Base 12 x 12 x 1 1/3 with 8 x 4 Recessed Center and 8 Holes 46342 —— Plate, Round 6 x 6 Heart 46534 —— Minifigure, Headgear Helmet with Ear Antennae 60373 —— Cylinder Quarter 3 x 3 x 5 with 2 Arch Tops 71708 —— Technic Beam 2 x 3 Liftarm Bent 90 Quarter Ellipse 73831 —— Plate 2 x 3 with 1 x 1 Cutout 92198 —— Mini Doll, Head Friends [Female] 92240 —— Mini Doll, Head Friends Male 92241 —— Torso Mini Doll Friends [Girl] 92242 —— Torso Mini Doll Friends [Man] 107400 —— BBB Train Wheel Medium Blind Driver 24.0 mm 107500 —— BBB Train Wheel Blind Driver 30.4 mm 654681 —— Minifigure, Utensil Trolls Mandolin / Lute 654682 —— Minifigure, Utensil Trolls Treble Clef 654683 —— Minifigure, Utensil Trolls Eighth Note (Quaver) 654684 —— Minifigure, Utensil Trolls Cupcake 654685 —— Minifigure, Utensil Trolls Flower, 7 Petals and Pin 654686 —— Minifigure, Utensil Trolls Glasses, Angled Hearts with Pin 654687 —— Minifigure, Utensil Trolls Heart with Pin 999993 —— BuWizz 3.0 New Duplo parts 2162 —— Top Hat (Circus Ringmaster) 2292 —— Duplo Wheelbarrow 2302 —— Duplo, Brick 2 x 3 with Curved Top 23065 —— Ball, Hard Plastic 52mm D. (Duplo Ball for Ball Tube) Updated parts 2420 —— Minifigure, Head Modified SW Nautolan —— v2 —— updated color data 35494 —— Minifigure, Hair Mid-Length Wavy with Center Part and Sidelocks —— v2 —— updated collision data Other changes • Updated 2020NewPreColoredParts palette with: 1x 20193 [6103793], 1x 999993 [BuWizz 3.0], 1x 24314 [6334175] • Updated MainGroupDividers with 101.png and MainGroups.xml Edited October 29, 2023 by Stephan Version 20201222 Share this post Link to post Share on other sites
Stephan Posted October 10, 2020 (edited) Version 20210116 Version 20210116 or GitHub [download files separate] and LXF file with new and updated parts New parts 35182 —— Mini Doll, Hair Friends Long, Hole on Top and Side 35183 —— Minifigure, Ear Protectors / Headphones / Headset - Thin Arms 35463 —— Tile, Modified 1 x 1 with Tooth / Ear Vertical, Triangular 35586 —— Mini Doll, Hair Friends Long and Layered, Parted in Front 35598 —— Mini Doll, Hair Long and Wavy with Side Bangs 35692 —— Minifigure, Utensil Balloon Dog 35709 —— Minifigure, Costume Flowerpot 35857 —— Minifigure, Headgear Head Cover, Costume Mask Elephant 36017 —— Minifigure, Weapon Sword Hilt with Dragon Head 36452 —— Minifigure, Neck Bracket with 4 Angled Handles 36654 —— Dinosaur Head Indoraptor with Pin 36752 —— Minifigure, Utensil Wand 36762 —— Minifigure, Hair Thick and Messy 36806 —— Minifigure, Hair Long, Parted in Center 37493 —— Train Front 6 x 9 x 7 37680 —— Minifigure, Weapon Sword, Blade with Bar and Spike on Top 37696 —— Minifigure, Beard, Long Tied 37779 —— Arm Large with Pin, Left with Hand 37783 —— Arm Large with Pin, Right with Hand 38502 —— Cat, Large (Saber-Toothed Tiger) 38831 —— MINI HAT, NO. 81 38910 —— Dinosaur Head Carnotaurus with Pin 39369 —— Technic, Panel Plate 11 x 19 x 1 42859 —— Cat Tail with Spikes 44666 —— Plate, Modified 14 x 18 x 1, Hexagonal with Raised 2 x 4 Bottom with 3 Pin Holes 49577 —— Plant Thallus, Seaweed, Coral 49588 —— Minifigure, Head Modified Snake, Cobra with Closed Mouth 49656 —— Rock 1 x 1 Geode 52494 —— Plate, Round 1 x 1 with Binoculars (Robot / Droid Head) 53054 —— Minifigure, Head Modified Dog 65473 —— Brick, Round 2 x 2 d. 135 Degree Elbow 65578 —— Minifigure, Utensil Posing Stand, Bar with Hollow Stud 66961 —— Brick, Modified 2 x 2 with Bar Handle on Four Sides 67095 —— Tile, Round 3 x 3 67139 —— Technic, Pin Connector Block, Liftarm 1 x 3 x 5 with Cutout 67440 —— Slope, Inverted 60 4 x 1 x 3 67446 —— Technic, Brick 2 x 4 x 1 1/3 with Axle Holes 67811 —— Vehicle, Steering Wheel with 2 x 2 Center 68013 —— Cylinder Half 1 x 2 x 1 68382 —— Plate, Modified 1 x 4 with Pins on Bottom 68495 —— Minifigure, Utensil Stein / Cup 68504 —— Minifigure, Utensil Sherbet / Sundae Dish 68568 —— Plate, Round Corner 3 x 3 with 2 x 2 Cutout 68869 —— Tile, Modified 4 x 4 with Rounded Corners and 4 Feet 69066 —— Container, Trunk 1 x 3 x 1 —— Has connectivity for 36752 69906 —— Bracket 3 x 2 - 2 x 2 69909 —— TYRE OFF ROAD, WIDE, DIA. 75.1X28, NO. 1 69911 —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 Rounded Top 69963 —— Vehicle, Base 2 x 4 with Suspension 69964 —— Vehicle, Axle Flattened with Cutout and Wheels Holders 70671 —— Wolf, Lloyd's (Akita in Wolf Form) 70695 —— Tire 56 x 26 Tractor 71682 —— Technic, Panel Curved 2 x 3 x 1 71689 —— Technic, Panel Car Mudguard Arched 13 x 2 x 5 Half Circle 71709 —— Technic, Panel Plate 3 x 7 x 1 71710 —— Technic, Liftarm 1 x 15 Thick, Perpendicular Holes 98169 —— Dinosaur Head Triceratops with Pin 98170 —— Dinosaur Leg Small (Front) Triceratops with Pin - Left 98171 —— Dinosaur Leg Small (Front) Triceratops with Pin - Right 98172 —— Dinosaur Leg Large (Rear) Triceratops with Pin - Left 98173 —— Dinosaur Leg Large (Rear) Triceratops with Pin - Right 609000 —— Fabuland Brick, Modified 1 x 4 x 2 Bell Shape with Headlights [fabaj3] New parts — honourable mentions 67095 —— Tile, Round 3 x 3 with Green Eye Pattern —— [6303539] 67095 —— Tile, Round 3 x 3 with Brown Eye Pattern —— [6303537] 68869 —— Tile, Modified 4 x 4 with Rounded Corners and 4 Feet with Super Mario Scanner Code 2 Arrows Cycle Pattern (Sticker) - Set 71360 —— [6315523] Updated parts — honourable mentions 3298 —— Slope 33 3 x 2 —— made decorable 24630 —— Minifigure, Head Modified Duck 30363 —— Slope 18 4 x 2 —— made decorable 34140 —— Cat, Large —— created assembly from loose parts 63864 —— Tile 1 x 3 —— made decorable 93224 —— Minifigure, Headgear Hood Hazard Suit with Face Shield —— updated 3D model and improved the decoration 95342 —— Chicken —— is now multi-colorable and decorable Updated parts • Updated 93224 (Updated 3D model, made decorations possible) • Created assembly for 29243, 29241 and 29238 [34140] • Updated 95342 (Updated colorable areas, made decorations possible) • Updated flex behaviour 32235 • Added flex to 14224, 14225, 14226, 30104, 32201, 32202, 63140, 63142 • Added collisions: 6064, 24085, 24866, 49308, 43056, 43045, 39789, 36036, 56074, 51239, 51266, 38320, 35649, 53119, 40811, 37695, 38391, 28618, 52985, 44709, 39739, 39802, 35787, 41812, 35446, 35443, 35442, 41823, 34732, 35660, 45755, 35485, 39262, 35189, 66606 • Updated connections: 3815, 16709, 19859, 36036, 38394, 41879, 51345, 87749, 95351, 98376, 99778 • Updated collisions and connections: 24855, 42409 • Made decorable: 3298, 30363, 50746, 63864 Other notes: • Updated 2020NewPreColoredParts palette with: 3x 3298 [3298000, 3298001, 3298002], 3x 24630 [6143555, 6143630, 2463300], 1x 30363 [6254680], 2x 49588 [6263972, 6268119], 3x 49656 [6259944, 6264268, 6264092], 1x 53064 [6266998],1x 54968 [6266180], 1x 68495 [6306748], 1x 68869 [6315523], 3x 93566 [4619311, 6081998, 6151895], 1x 35857 [6224268], 3x 95342 [6063275, 4624282, 6275200], 3x 37783 [6287335, 6284640, 6237868], 3x 37779 [6287336, 6284642, 6237864], 2x 98169 [6018320, 6278956], 2x 67095 [6303539, 6303537] • Updated DecorationMapping.xml with 3298, 30363, 35857, 54968, 67095, 68869, 93566, 95342. • Updated decoration 95217. • Added decoration 16723, 38354, 54978, 68368, 68370, 69433. • Added new version of MaterialNames.xml: added 365 'Tr. Violet Opal', 363 'Tr. Brown Opal', 302 'Tr. Lt. Blue w/ Glitter', 339 'Tr. Fluorescent Green w/ Glitter', and 'Tr. Pink Glitter/Tr. Med. Reddish Violet Glitter'. • Added new version of Materials.xml: added 365 'Tr. Violet Opal', 363 'Tr. Brown Opal', 302 'Tr. Lt. Blue w/ Glitter', 339 'Tr. Fluorescent Green w/ Glitter', and 114 'Tr. Pink Glitter/Tr. Med. Reddish Violet Glitter'. • Added new version of CurrentMaterials.xml: added 365 'Tr. Violet Opal', 363 'Tr. Brown Opal', 302 'Tr. Lt. Blue w/ Glitter', 339 'Tr. Fluorescent Green w/ Glitter', and 114 'Tr. Pink Glitter/Tr. Med. Reddish Violet Glitter'. Edited October 29, 2023 by Stephan Prepared version 20210116 Share this post Link to post Share on other sites
Stephan Posted May 8, 2021 (edited) Development Version 20210501 Version 20210501 or GitHub [download files separate] and LXF file with new and updated parts New parts 19062 —— Bionicle Mask of Water [no connections] 20477 —— Bionicle Mask of Creation [no connections] 21562 —— Large Figure Armor, Leg Shin Guard with Ball Joint Socket 21987 —— Large Figure Weapon Lightsaber Blade 15L with Axle Hole 24104 —— Arm Armored, Right with Shoulder and Pin (Nexo Knights Axl) [24104c*] 24128 —— Torso, Modified Oversized with Armor with Pin Holes [23763c01pb*] 24531 —— Brick 1 x 1 x 5 - Solid Stud [2453b] 32172 —— Technic, Pin Connector Block 3 x 3 x 1 35470 —— Tile, Modified 3 x 5 Cloud 35477 —— Brick, Modified 1 x 3 with Round Ends 36293 —— Mini Doll, Hair Combo, Hat with Hair, Racing Helmet with Flexible Hair Ponytail [36293c01pb*] 37704 —— Sports Ball, Winged, Harry Potter Quidditch Golden Snitch 39028 —— Dinosaur Jaw Lower Indoraptor [39028pb*] 41660 —— Bionicle Weapon 5 x 5 Shield with Saw Blades Circular 41835 —— Bird, Small [41835*] 42205 —— Window 1 x 6 x 6 Flat Front 42509 —— Glass for Window 1 x 6 x 6 Flat Front 42924 —— Technic Pin Long with Friction Ridges Lengthwise, 1 Center Slot 43559 —— Bionicle Shoulder Armor 46891 —— Technic Digger Bucket 10 x 19 47326 —— Technic, Axle Connector 2 x 3 with Ball Joint Socket and Axle Socket with Rubber Insert [x1192px*] 47335 —— Bionicle Weapon Vahki Staff of Confusion (Keerakh) 49972 —— Dinosaur Jaw Lower Baryonyx [49972pb*] 50665 —— Minifigure, Headgear Helmet Space / Town with Thick Chin Strap - with Visor Dimples (Reissue with Top Dimple) 51377 —— Wheel 18mm D. x 14mm Spoked 53075 —— Dog, Dachshund [53075pb*] 53309 —— Dinosaur Head Baryonyx with Pin [53309c01pb*] 53564 —— Bionicle Piraka Torso with 2 Ball Joint 54661 —— Hinge Brick 1 x 4 Locking with 1 Finger Vertical End and 2 Fingers Vertical End, 7 Teeth 55532 —— Minifigure, Hair Smooth Mop Top 55889 —— Wheel 18 x 14 Smooth 57702 —— Bionicle Mask Inner Glass (for Faxon, Tryna, Volitak) 58665 —— Minifigure Wings Ghost with Cutouts 61332 —— Technic Pin with Friction Ridges Lengthwise with No Center Slots 64454 —— Container, Box 3 x 8 x 6 2/3 Half Back 64462 —— Container, Box 3 x 8 x 6 2/3 Half Front 65128 —— Container, Box Vidiyo Window [no connections] 65132 —— Container, Box Vidiyo Back Base 65140 —— Plate, Round 8 x 8 with Rounded Corners 65183 —— Minifigure Armor Shoulder Pads with Scabbard for Two Katanas and Bar Hole 65304 —— Technic Pin Long with Friction Ridges Lengthwise and Stop Bush [No Ridge Near Rim] 65417 —— Boat, Hull Unitary 36 x 7 x 5, Base (Catamaran Half) 65418 —— Boat, Hull Unitary 36 x 7 x 4, Top (Catamaran Half) 65676 —— Road Sign 2 x 2 Triangle with Open O Clip 65753 —— Minifigure Skirt Plastic Straight, Short 66155 —— Wheel 30.4mm D. x 20mm with Center Axle Holes Motorcycle 66252 —— Tile, Modified 4 x 4 with Studs on Edge and 2 Open O Clips 66787 —— Cylinder Warp Pipe 6 x 6 x 4 66789 —— Plate, Modified 6 x 6 with Rounded Corners and 4 Feet 66790 —— Plate, Modified 8 x 8 with Rounded Corners and 4 Feet 66792 —— Plate, Modified 4 x 4 with Rounded Corners and 4 Feet 66855 —— Brick, Modified Cube, 4 Studs on Top [66855pb*] 66858 —— Legs with Plate Round 2 x 2 and Axle Hole 66859 —— Legs with Plate Round 2 x 3 66956 —— Wedge 2 x 2 Pointed with Stud Notches 67013 —— Shell, 4 Studs Inside and Hole [67013pb*] 67931 —— Shell with Spikes, 4 Studs Inside and Hole [67931pb*] 68211 —— Bar 1L with 3 Prongs 69729 —— Tile 2 x 6 69900 —— Technic, Link Chain, Large with Panel and Center Divider 69944 —— Minifigure, Weapon Macuahuitl, Club with Handle and Blades [69944pb*] 69958 —— Brick, Modified 16 x 16 x 2/3 with 1 x 4 and 2 x 4 Indentations 70681 —— Arch 1 x 3 Inverted 71752 —— Brick, Modified 2 x 2 x 2/3 Ribbed 71771 —— Slope, Curved 5 x 8 x 2/3 71772 —— Brick, Modified 8 x 16 x 2/3 with 1 x 4 and 2 x 4 Indentations 72078 —— Tile, Modified 1 x 1 x 2/3 with Groove with Raised Diamond [72078pb*] 72869 —— Bar Holder with Clip Angled 73109 —— Technic, Brick Modified 1 x 2 with Hole and 1 x 2 Plate 73230 —— Technic, Brick 1 x 1 with Axle Hole 73682 —— Slope, Curved 3 x 3 Double 73825 —— Bracket 1 x 1 - 1 x 2 Inverted 74132 —— Dinosaur Middle Triceratops [TriBodyc*]] 76798 —— Panel 4 x 8 x 4 Quarter Circle with Pin Holes 78267 —— Solar Panel 445671 —— Hinge Plate 1 x 2 Locking with 1 Finger on Side with Bottom Groove [44567a] 949001 —— Minifigure Cape Cloth, Tattered and Pixelated (Minecraft) - Starched Fabric [bb0846] 983930 —— Friends Accessories Medical Pen [98393j] 983932 —— Friends Accessories Medical Clipboard [98393b] 983933 —— Friends Accessories Medical Otoscope [98393c] 983935 —— Friends Accessories Medical Spoon [98393e] 983936 —— Friends Accessories Medical Feeding Bottle [98393f] 983937 —— Friends Accessories Medical Ice Pack [98393g] 983938 —— Friends Accessories Medical Nurse Hat [98393h] 999994 —— BuWizz Motor New parts — honourable mentions A lot of printed and stickered parts! Updated parts • Updated collision data: 2449, 2454, 3022, 3036, 3633, 3795, 6111, 6553, 14769, 24599, 25061, 26603, 32802, 32803, 33183, 33492, 37762, 38583, 38585, 39611, 39739, 40389, 42716, 47397, 47398, 47759, 49307, 60599, 60621, 63864, 66727, 69911, 87693, 87751, 98834, 99206 • Updated connectivity: 3633, 3814*, 4083, 4738**, 4739**, 6542, 20308, 24119, 25061, 30035, 32187, 33183, 35480, 39611, 44302, 50254, 60115, 60471, 66727, 500182, 500183, 500184 • Made decorable: 2723, 3023, 3623, 6256, 14716, 15068, 24093, 24630, 34103, 39739, 48288, 57895, 60601, 87552, 87580, 90498 • Corrected decoration surface: 25269, 32523 • Changed default orientation: 50746, 85984 • Updated 3D data: 32802, 39739 • Made multi-colorable: 24101 * Created extra level of head-connectivity for capes. ** Updated hinge type from 48/49 to 82/83 as to fit 60603. Other notes: • Added decoration: 13088, 13093, 13541, 15826, 16592, 18123, 18327, 19181, 20432, 21060, 21247, 21248, 21249, 23082, 24369, 24370, 25078, 25078, 25313, 25619, 25808, 25870, 28984, 29198, 29839, 29983, 30011, 30013, 30014, 30016, 30017, 30049, 30391, 30671, 30672, 30674, 30675, 30680, 30690, 30691, 30692, 30723, 30783, 31468, 31906, 31911, 31912, 31914, 31915, 32647, 33380, 33613, 34075, 34802, 34887, 34957, 35330, 36089, 36959, 37097, 37590, 38275, 38617, 38995, 39088, 39346, 39486, 39550, 39700, 39849, 41268, 41781, 44368, 45329, 45331, 45356, 47144, 48272, 48277, 49118, 49610, 51582, 52100, 52652, 60186, 62688, 63774, 66069, 66171, 66251, 66273, 66420, 66509, 66761, 66894, 67532, 68203, 68384, 68399, 68411, 68967, 69085, 69172, 69193, 69533, 72399, 73675, 73688, 73774, 73777, 73778, 73779, 73784, 74095, 76889, 76892, 76893, 76901, 76907, 76993, 78249, 78267, 78280, 78281, 78282, 78283, 78284, 78286, 93871, 94875, 99187, 782521, 782525, 782526, 782531, 239311, 300111, 300119, 300123, 300422, 303701, 303702, 303712, 303901, 344991, 649831, 672221, 733271, 773980, 773981, 773982, 773983, 773984, 773985, 773986, 773987, 773988, 773989, 773991, 773992. • Updated DecorationMapping.xml with 3001, 3004, 3005, 3023, 3623, 3068, 3070, 24630, 41835, 50746, 69729, 90498, 98138. • Updated 2020NewPreColoredParts palette with: 1x 2431 [6343015], 1x 2723 [6304895], 11x 3001 [3001001, 3001002, 3001003, 3001004, 3001007, 3001006, 3001011, 3001012, 3001019, 3001023, 4649488], 1x 3003 [6334674], 11x 3004 [6334677, 6334676, 6334673, 3004009, 6253517, 6188722, 6230554, 6112816, 6334678, 6097029, 3004022], 6x 3005 [6329591, 6122960, 6334693, 6079045, 6065604, 6022625], 1x 3023 [6311491], 6x 3037 [3037001, 3037002, 3037003, 3037004, 3037005, 3037012], 8x 3039 [3039001, 6271990, 6316961, 3039002, 3039003, 3039004, 3039005, 3039006], 5x 3068 [6302568, 6142949, 6132324, 3068001, 3068000], 17x 3069 [6291791, 6329575, 6343001, 6304837, 2132603, 6329585, 6176770, 4617046, 6259378, 6081644, 3069000, 3069001, 3069002, 3069003, 6181556, 6242566, 6251607], 6x 3070 [6253176, 6253837, 6253635, 6254609, 6329583, 6329584], 9x 3623 [6137057, 6137060, 6223864, 6237005, 6253639, 6311490, 6311492, 6261968, 6253938], 1x 3070 [6286223], 1x 4162 [6342995], 1x 6256 [6233916], 1x 14716 [2132608], 2x 14769 [2132604, 6182435], 5x 15068 [6258166, 6132565, 6342999, 6342998, 2132606], 1x 24093 [2132657], 2x 24101 [6138741, 6134601], 2x 24104 [6138744, 6134602], 1x 24128 [6171039], 1x 24531 [2130201], 1x 24630 [6143555], 12x 26603 [6177290, 6275600, 6215342, 6258380, 6289849, 6199330, 6214626, 6226450, 6192782, 6198008, 2132612, 2132601], 2x 32523 [6170737, 6335195], 1x 34103 [6334686], 1x 35700 [2132609], 2x 35787 [6236402, 2132602], 6x 36296 [6224120, 6224154, 6224173, 6224105, 6224162, 6224170], 1x 42918 [6258674], 5x 47326 [4235786, 4227779, 4223771, 4227783, 4227781], 2x 41835 [6253309, 6287960], 1x 42198 [6258674], 1x 49972 [6267951], 2x 50746 [6186782, 6261667], 1x 53309 [6267942], 1x 57895 [6257539], 2x 60601 [6275973, 6254555], 4x 66855 [6310501, 6323867, 6334692, 6309077], 1x 66857 [2132611], 1x 66858 [6308953], 3x 67013 [6299928, 6294717, 6315380], 3x 67931 [6341867, 6315223, 6302720], 1x 69729 [2132410], 1x 69944 [6994400***], 1x 71772 [6328358], 1x 72078 [6322171], 2x 74132 [6278977, 6018330], 3x 76798 [1028307, 1028305, 1028306], 1x 78267 [6342963], 1x 85984 [6329152], 27x 87079 [6238261, 6287324, 6258071, 4612857, 6023301, 6023282, 6115326, 6115328, 6115331, 6062410, 6132325, 6175893, 6254086, 6181557, 6181553, 6218943, 6329624, 6303642, 6106079, 6316462, 6181554, 6312725, 6342997, 6349278, 6228904, 6287364, 6122997], 1x 87580 [6288364], 2x 87552 [6343853, 6343002], 3x 90498 [7519212, 7525201, 1028301], 24x 98138 [6298993, 6030333, 6236036, 6178627, 6245198, 6212100, 6215601, 6322964, 6177074, 6177076, 6177075, 6177077, 6138964, 6177548, 6181538, 6141970, 6284073, 6324417, 6287844, 6322943, 6285620, 6299968, 6329581, 63091911]. • Updated MaterialSelector with 114 'Tr. Pink Glitter/Tr. Med. Reddish Violet Glitter' and 336 'Silver Ink'. *** ElementID unclear as of 05-04-2021. Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
Stephan Posted July 10, 2021 (edited) Development Version 20210710 Version 20210710 or GitHub [download files separate] and LXF file with new and updated parts New parts 2451 —— Train Wheel with 2 x 2 Stud Center, Beveled Tread and Cam Axle for Motor [wheel1b] — Multi-colorable 3500 —— Wheel Spoked Large [35] — Multi-colorable 4143 —— Technic, Gear 14 Tooth Bevel 4470 —— Train Wheel with 2 x 2 Stud Center, Traction Teeth [wheel1a] — Multi-colorable 5690 —— Technic, Gear Expert Builder 9 Tooth [g9] — Multi-colorable — attaches to 5740 5740 —— Tire 17 x 43 for Gear 9 Tooth [3634b] — attaches to 5690 7039 —— Wheel with 4 Studs and Axle — Multi-colorable 7049 —— Brick, Modified 2 x 4 with Wheels Holder — Multi-colorable 9237 —— Wheel with 12 Studs [715] — Multi-colorable 24300 —— Train Wheel Spoked for Wagon [wheel2b] — Multi-colorable 24400 —— Train Wheel Spoked for Motor [wheel2a] — Multi-colorable 28738 —— Electric 9V Battery Box Powered Up Bluetooth HUB [bb0892c01] — Multi-colorable 34337 —— Wheel 8mm D. x 6mm with Slot 35394 —— Dish 4 x 4 Inverted (Radar) with Open Stud — Decoratable 37091 —— Brick, Modified 2 x 4 with Top/Side/End Holes [3709a] 37092 —— Brick, Modified 2 x 4 with Top/Side/End Holes with Solid Studs [3709c] 38339 —— Train Wheel RC, Holder with Pin Slots 38340 —— Train Wheel RC with Pins 40341 —— Bionicle Weapon Long Axle Circular Saw Staff with Pin Hole 45800 —— Train Rim for 4.5V & 12V Locomotive Wheels [trainrim] 45801 —— Train Rim for 4.5V & 12V Locomotive Wheels, formed [trainrim] 49612 —— Brick, Round Corner 4 x 4 x 2 2/3 Dome Top 50340 —— Hinge Plate 1 x 2 Locking with 2 Fingers on Side and 7 Teeth 65138 —— Dish 4 x 4 Inverted (Radar) with 4 Solid Studs and Pin Hole 65151 —— Technic, Shock Absorber 11L with Internal Spring — Multi-colorable 65803 —— Technic, Brick 16 x 16 x 1 1/3 with Holes 65817 —— Panel 11 x 15 w/ PCB Holes 67759 —— Windscreen 6 x 14 x 4 68325 —— Brick, Round 4 x 4 with Recessed Center and Hole 68888 —— Technic, Axle Connector Hub with 4 Bars 70644 —— Technic Hook Large Metal 72008 —— Technic, Liftarm, Modified Fork 2 x 2 with Axle Holes 72206 —— Wheel 24 x 12 with Pin Hole with Fixed Black Rubber Tire [72206c*] — Multi-colorable 73111 —— Brick, Round 3 x 3 x 2 with Recessed Center and Axle Hole 76795 —— Brick, Round Corner 5 x 5 with Slope 45 Edge without Studs 76796 —— Windscreen 4 x 6 x 1 1/3 Round — Decoratable 76797 —— Slope, Curved 3 x 3 Corner 77180 —— Wedge 10 x 2 x 2 Left 77182 —— Wedge 10 x 2 x 2 Right 78256 —— Plate, Modified 1 x 2 with Clip on End (Vertical Grip) 78258 —— Bar 2L with Stop Ring 78329 —— Plate 1 x 5 78443 —— Wedge, Plate 6 x 2 Left 78444 —— Wedge, Plate 6 x 2 Right 78886 —— Roof Tile 2x2x2, deg. 60 79389 —— Bracket 1 x 1 - 1 x 2 87857 —— Hips and Long Legs [970clg*] — Multi-colorable 373411 —— Minifigure, Weapon Sword Curved Blade with Bar 373412 —— Minifigure, Weapon Knife with Flat Hilt End and Curved Blade, Cross Hatched Grip 373413 —— Minifigure, Weapon Sword Blade with Bar, Square Crossguard 373414 —— Minifigure, Weapon Hook with Bar 373415 —— Minifigure, Weapon Hook with Double Blades 722101 —— Wheel Cover 5 Spoke and 9 for Wheel 72206c01New parts — honourable mentions A lot of printed parts! Updated original parts • Created extra decoration surface: 22371, 22375, 23945, 24067, 90393 • Updated collisions: 3660, 15068, 20482, 41530, 53454, 92903, 98138 • Created decoration surface: 6213, 17485, 24067, 24246, 24541, 25296, 28631, 30151 • Updated connections: 18976, 22483, 35578 Updated custom parts • Updated 3D model: 24593 • Created decoration surface: 24541, 24593 • Updated colission data: 69729 Other notes: • Added decoration: 12441, 14800-14806, 14808-14811, 14813-14822, 14824, 14825, 14827-14837, 14840-14855, 14857, 14858, 14861, 14864-14867, 14870, 14873, 14877, 14878, 14882, 14884, 14887, 14885, 14890, 14892, 14895, 14912, 14919, 14921, 14924, 14933, 14935, 14936, 14938, 14941, 14985, 14988, 15076, 15077, 15078, 15089, 18044, 18279, 18949, 18952, 18953, 18965, 18966-18968, 23842, 24228, 29819, 34047, 34452, 35329, 37096, 49115, 49116, 50097, 65754, 68933, 68945, 69092, 69094, 69883, 69904, 69920, 69921, 72294, 78840, 79112, 79113, 79282, 79374-79383, 79390, 79391, 79394-79412, 97623, 97627, 97629, 97631, 97633, 148261, 240671, 245401-245406, 245931, 396002, 621300, 686698, 878711-878716, 878721-878724, 911361-911363, 976251, 976252 • Updated decoration 23194, 28984, 36785 • Updated DecorationMapping.xml with 6213, 87775, 87776, 3815, 24593 • Updated 2020NewPreColoredParts palette with: 1x 2431 [6215341], 1x 2451 [2451000], 38x 3003, 1x 3004 [6351980], 7x 3006, 13x 3024 [6093236, 6093238, 6093244, 6093263, 6093264, 6093266, 6093267, 6192729, 6195336, 6202501, 6253609, 6253610, 6323889], 1x 3068 [6319302], 1x 3069 [6016161], 44x 3070 [6016004, 6016007, 6016013, 6016015, 6016017, 6016018, 6016022-6016024, 6016026, 6016029, 6016030, 6016032, 6016033, 6016034, 6016035, 6016037-6016039, 6016041, 6016042, 6016047, 6016048, 6016050, 6016051, 6016108, 6016111, 6016114, 6016115, 6016117, 6016118, 6016120, 6016126, 6016132, 6016134, 6016139, 6016144, 6016145, 6016147, 6016149, 6213705, 6322991, 6322999, 6350449], 1x 3500 [3500000], 1x 3960 [3960002], 1x 5690 [5690000], 1x 6213 [6213000], 1x 7039 [7039000], 5x 7049 [7049001-7049005], 1x 7740 [7740000], 1x 9237 [9237000], 29x 14769 [typewriter], 1x 15068 [6350448], 2x 17485 [6081211, 6258807], 1x 22371 [6124315], 1x 22375 [6123895], 3x 24067 [6284504, 6131197, 2406700], 1x 24300 [2430000], 1x 24400 [2440000], 8x 24541 [2454001-2454008], 1x 24593 [6256748], 1x 28631 [6175784], 1x 28738 [6262033], 1x 30151 [6078477], 1x 63864 [6319303], 1x 65151 [6302623], 2x 67095 [6353007, 6353008], 1x 70644 [70644], 1x 76796 [6347788], 3x 87857 [4562523, 4562524, 4586483], 1x 98138 [6322998] • Updated MaterialSelector, MaterialNames, Materials and CurrentMaterials with 335 'Gold Ink'. Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
Stephan Posted July 12, 2021 (edited) Development Version 20210712 Version 20210712 or GitHub [download files separate] and LXF file with new and updated parts Updated original parts • Updated location: 70644 Updated custom parts • Updated collision data: 15068, 30082, 41740, 67759, 72206, 78258 • Updated connections: 72206, 7825 Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
SylvainLS Posted July 12, 2021 70644 is still not placed the same as the original. Share this post Link to post Share on other sites
Stephan Posted July 13, 2021 22 hours ago, SylvainLS said: 70644 is still not placed the same as the original. Fixed now; downloadable in the same parts pack correction. Share this post Link to post Share on other sites
Stephan Posted September 11, 2021 (edited) Development Version 20210828 Version 20210828 or GitHub [download files separate] and LXF file with new and updated parts New parts 2630 —— Plate, Modified 1 x 2 with Steam Engine Cylinder, Flat Surfaces [263] 2641 —— Support Crane Stand Single 3600 —— Tire Smooth - Large Solid [36] 9131 —— Tire Smooth - Small Solid [132old] 22678 —— Hose, Ribbed 7mm D. 31L / 24.8cm [78c31] — Flexible 24772 —— Body Giant, Thanos [37838*] — Multi-colorable + decorable 27017 —— Body Giant, Killer Croc [bb0737c01*] — Multi-colorable + decorable 28230 —— Arm Giant, Right with Stud on Wrist — Multi-colorable + decorable 28232 —— Arm Giant, Left with Stud on Wrist — Multi-colorable + decorable 29580 —— Minifigure, Headgear Head Cover, Costume Rocket — Multi-colorable 29936 —— Body Giant, Hulk with Messy Hair [bb0646c01*] — Multi-colorable + decorable 30489 —— Sports Field Section 8 x 16 — Decorable 30492 —— Sports Field Section 8 x 8 30493 —— Sports Soccer Goalie Stick 35685 —— Minifigure, Hair Combo, Tiara — Multi-colorable 36451 —— Rock Infinity Stone [36451a] 36470 —— Hand Large Minifigure Left, Infinity Gauntlet 37364 —— Hips and Medium Legs — Multi-colorable + decorable 38086 —— Body Giant, Cull Obsidian [bb0840c01*] — Multi-colorable + decorable 41672 —— Bionicle Bohrok Shoulder, Liftarm 1 x 3 x 7 41732 —— Technic, Pin Connector Round with Slot, Bar Lengthwise & Bars Out (Soccer Goalie Stick Holder Pivot) [x383] 41733 —— Sports Soccer Goalie Stick Holder Base 41819 —— Sports Field Section 8 x 16 with Horizontal Slot 41991 —— Black Sports Minifigure Stand Basketball, Sliding Holder 42073 —— Windup Motor 2 x 6 x 2 1/3 without Raised Shaft Base - Short Axle (Sports) — Multi-colorable 43370 —— Torso Plain (NBA) / Yellow NBA Arms with Hands [973b*] — Multi-colorable + decorable 43373 —— Sports Hoop with 2 Studs and Axle 43374 —— Sports Basketball Net 43743 —— Hips and Legs - Spring Legs [x494] — Multi-colorable 44773 —— Track System Y-shaped Track 24 x 16 x 2 45522 —— Tile, Modified 6 x 6 x 2/3 with 4 Studs and Embossed 'SPORTS' 48289 —— Sports Minifigure Stand Hockey Shooter, Middle 48290 —— Sports Minifigure Stand Hockey Shooter, Bottom 48291 —— Sports Minifigure Stand Hockey Shooter, Top 48298 —— Net, Plastic 6 x 1 x 5 Lattice Curved 53126 —— Minifigure, Hair Female Coiled with Large High Bun 53475 —— Hose, Rigid 3mm D. 25L / 20.0cm [75c25] — Flexible 64865 —— Bar 8L with Stop Rings and Pin (Technic, Figure Accessory Ski Pole) - Flat End 65249 —— Technic, Axle 2L with Pin without Friction Ridges Lengthwise 65826 —— Technic, Pin 1/2 with Stud Receptacle 66405 —— Hand Large Minifigure Right, Infinity Gauntlet — Decorable 66639 —— Body Giant, Hulk [bb1114*] — Multi-colorable + decorable 66955 —— Wedge 4 x 3 No Studs Stepped 67644 —— Lower Body, Rounded, Short Legs [67644*] — Multi-colorable + decorable 67650 —— Minifigure, Head, Modified Minion, Extra Tall with Goggles [67650*] — Multi-colorable + decorable 67887 —— Minifigure, Head, Modified Pig — Decorable 67908 —— Arm with Technic Pin with Hand [67906*] — Multi-colorable + decorable 67950 —— Cylinder Half 3 x 6 x 6 Closed on Top with 2 Studs 68881 —— Brick, Round 5 x 10 x 1 2/3 Dome Half [68881*] — Multi-colorable + decorable 68986 —— Minifigure, Head, Modified Minion, Short with Goggles [68986*] — Multi-colorable + decorable 69073 —— Minifigure, Head, Modified Minion, Tall with Single Lens Goggles [69073*] — Multi-colorable + decorable 70688 —— Hose, Rigid 3mm D. 27L / 21.6cm — Flexible 73210 —— Mario, Pixelated [mar0036] — Decorable 73507 —— Technic, Liftarm, Modified Perpendicular Holes Thick 1 x 11 74169 —— Brick, Round 2 x 2 x 2/3 No Studs with 2 Tile, Round 1 x 1 (Mickey Mouse Head) 74611 —— Plate, Round 8 x 8 with Hole 76776 —— Brick Round Corner 5 x 5 x 3 1/3 Dome Top — Decorable 77237 —— Body Giant, Thanos without Head — Multi-colorable + decorable 77765 —— Technic, Pin 3L without Friction Ridges Lengthwise with Stop 78257 —— Plate, Modified 1 x 1 with Handles on Ends - Closed Ends 78522 —— Slope, Curved 6 x 4 Double — Decorable 78594 —— Panel 2 x 2 x 5 Corner Wall 79001 —— Minifig Head Special, Raccoon — Decorable 79393 —— Tile 3 x 3 with Bow 79435 —— Minifigure, Head, Modified Giant — Decorable 304881 —— Sports Minifigure Stand Soccer [30488] 420731 —— Windup Motor 2 x 6 x 2 1/3 with Raised Shaft Base - Long Axle (Sports) [42073c02] — Multi-colorableOriginal parts — updated parts Custom parts — updated parts Original / Custom parts — decorated parts Updated original parts• Created extra decoration surfaces: 4744, 10304, 10305, 11217, 11219, 11331, 14397, 15511, 17012, 17013, 19017, 22385, 24076, 24779, 25113, 25114, 25266, 25741, 25743, 26078, 28240, 28710, 28782, 29602, 29685, 30370, 30380, 33862, 43702, 46203, 48494, 50950, 50995, 59349, 62576, 64803, 64806, 69214, 72824, 87557, 87561, 87556, 87566-87568, 87610, 92474, 92742, 92762, 93057, 93060, 93066, 93604, 98099, 98101, 98117, 98118 • Updated decoration surface: 4740, 48288, 61189, 63864 • Added collision data: 28782, 65426, 65429 • Updated collision data: 3832, 3957, 4079, 59443 • Made flexible: 48294 • Updated connections: 36017, 87693 Updated custom parts • Created extra decoration surfaces: 9441, 9442, 24108, 24630, 27956, 29353, 35037, 46534, 53075 • Updated connections: 35578, 65138, 65426, 65429, 78258 • Updated collision data: 67095 • Updated 3D model: 48177 • Updated UV map: 69729 Other notes: • Added decoration: 10128, 10378, 10967, 11766, 11781, 11782, 11790, 11791, 11809, 11991-11993, 11995, 12747, 12762, 12781, 12942, 13363, 13830, 14037, 14122, 14330, 14344, 14499, 14535, 16386, 16704, 16841, 17228, 17468, 17469, 18205, 19017, 19186, 19188, 19514, 19619, 19831, 19988, 20156, 20198, 21261, 21281, 21610, 23092, 24053, 24057, 24231, 24633, 24772, 26010, 26011, 27017, 27981, 28301, 28522, 28627, 29179, 29228, 29936, 29949, 29952, 29959, 32759, 32782, 32809, 32892, 32912, 33026, 33493, 34002, 34120, 34617, 34620, 34625, 34632, 35874, 36014, 36405, 36643, 36800, 37136, 37138, 37838, 38086, 38557, 39141, 45181, 45184, 45776, 45809, 45816, 45817, 45846, 47180, 47215, 49399, 50095, 50099, 50355, 52733-52735, 53116, 55641, 58651, 61502, 63150, 63151, 63578, 63580, 64220, 64250, 65139, 66440, 66465, 66492, 66548, 66554, 66639, 67062, 67671, 68137, 68236-68239, 68362, 68366, 68379, 68443, 68986, 68987, 68989, 68995, 69036, 69042, 69061, 69065, 69069-69074, 69076, 69098, 69099, 69101, 69214, 69239, 73210, 73613, 73904, 74389, 74820, 75111, 75491, 76231, 76306, 76309, 76313-76315, 76328, 76999, 77237, 77858, 78747, 78755, 78989, 79001, 79235, 79236, 79241, 79678, 79679, 79711, 79747, 79912, 81780, 81781, 83784, 83786, 84139, 85039, 86408, 88103-88105, 88497, 88699, 88768, 90749, 91841, 93053, 93174, 93271, 93761, 93763, 93764, 94089, 94147, 94203, 96521, 96738, 96894, 96896, 99039, 117821, 117811, 117901, 127621, 174681, 199881, 199882, 212811, 247721, 260781, 299361, 303703, 303704, 303801-303803, 3048901-3048903, 327821, 329121, 340021, 368001, 373641, 373642, 378381-378383, 380861, 457761, 458091-458093, 462031-462036, 474400, 482881-482884, 484941-484946, 493991, 509951-509955, 530751, 666391, 676711, 681371, 751111, 769991, 876101, 931741 • Updated decorations: 54978, 69921 • Updated DecorationMapping.xml with 10304, 10305, 11217, 11219, 11331, 14397, 17012, 17013, 24076, 25113, 25114, 25266, 25741, 25743, 28230, 28232, 28240, 28710, 28716, 28782, 29602, 29936, 30370, 30380, 38086, 46534, 48494, 50950, 50995, 59349, 61189, 64225, 64803, 67644, 67671, 67887, 68379, 68881, 69061, 73210, 76776, 78522, 87556, 87557, 87566-87568, 87610, 92474, 92742, 93060, 93066, 93604, 96121, 98099, 98101, 98117 • Updated 2020NewPreColoredParts palette with: 1x 3068 [6333985], 3x 4744 [81780, 81781, 474400], 2x 10124 [6093854, 6259894], 3x 10128 [6176445, 6069191, 6016965], 2x 10154 [6093856, 6259886], 1x 10305 [6017008], 2x 10304 [6005578, 6123711], 16x 11217 [6022756, 6031207, 6031607, 6040487, 6055062, 6062947, 6064447, 6064462, 6065605, 6066043, 6103851, 6187302, 6252411, 6308055, 6308124, 8308130], 1x 11219 [6022637], 1x 11331 [6016804], 1x 14397 [6212960], 3x 15511 [6070912, 6070606, 6070774], 2x 17012 [6183729, 6071646], 4x 17013 [6089205, 6071647, 6071647, 6184813], 1x 18807 [6093858], 1x 19017 [6115562], 1x 24021 [6128926], 2x 24076 [6131233, 6172677], 4x 24108 [6131162, 6146848, 6212191, 6190039], 3x 24772 [6135010, 6221781, 6259897], 1x 24779 [6274766], 3x 25113 [6196870, 6213629, 6193868], 1x 25114 [6192605], 1x 25266 [6207748], 2x 25741 [6196890, 6226929], 2x 25743 [6196892, 6211930], 1x 26051 [6164670], 3x 26078 [6256414, 6160293, 2607801], 2x 26603 [6333986, 6333987], 1x 27017 [6154268], 1x 27956 [6162571], 1x 28230 [6154268], 1x 28232 [6176598], 2x 28710 [6185497, 6183790], 2x 28716 [6192707, 6196872], 1x 28782 [6354882], 1x 29353 [6173940], 1x 29580 [6189048], 2x 29602 [6185395, 6275740], 2x 29685 [6186286, 6331386], 4x 29936 [6176484, 6302257, 6258797, 6102910], 1x 29959 [6176618], 27x 30370 [6062974, 6097111, 6100025, 6129320, 6129330, 6144685, 6144688, 6163692, 6173065, 6187547, 6209733, 6215467, 6215470, 6231961, 4587276, 6258801, 6259873, 4500958, 6288130, 4655753, 4656631, 4514344, 4499946, 4569352, 4630108, 4502069, 3037000], 3x 30380 [3038000-3038001], 3x 30489 [3048901-3048903], 1x 33749 [6195991], 1x 33827 [6191569], 1x 33862 [6199189], 1x 34390 [6195163], 1x 35037 [6213897], 2x 35685 [6210358, 6217945], 1x 37364 [3736400], 1x 37598 [6219053], 1x 38086 [6222824], 1x 38394 [6224478], 1x 42073 [4162159], 18x 43370 [4337000-4337017], 1x 43702 [4186831], 11x 43743 [4374300-4374310], 6x 46203 [462031-462036], 1x 46534 [6253622], 1x 46882 [6316344], 1x 48177 [6253757], 4x 48288 [4828800-4828803], 6x 48494 [4849400-4849406], 1x 50044 [6256955], 1x 50940 [6357975], 7x 50995 [4267427, 4252376, 4252375, 5099500, 5099501, 4265653, 4501371], 1x 53054 [6266998], 2x 53075 [6274984, 5307501], 1x 59349 [6351623], 18x 61189 [6021251, 6021630, 6036204, 6038384, 6038434, 6103819, 4528048, 4528049, 4529206, 4529207, 4534355, 4659197, 6360604, 4542434, 4613510, 4613706, 4631309, 4631310], 1x 62576 [6302713], 1x 63864 [6329820], 1x 64225 [6313650], 3x 64803 [6109676, 6164371, 6019788], 3x 64806 [4550037, 4588046, 6103635], 1x 66639 [6288633], 1x 66405 [6294041], 4x 67644 [6309169, 6309208, 6309272, 6313954], 2x 67650 [6310330, 6303561], 2x 67671 [6298839, 6335469], 1x 67887 [6305193], 1x 67908 [6309175], 2x 68881 [6309135, 6309138], 1x 68986 [6309132], 4x 69073 [6310355, 6310455, 6310551, 6310573], 2x 69729 [6333988, 6333990], 1x 72824 [6151574], 1x 73210 [6326919], 2x 75822 [6351608, 6360707], 2x 76407 [4142815, 4142816], 2x 76776 [6333991, 6354881], 1x 77237 [6336836], 1x 79001 [6350241], 1x 79435 [6350076], 11x 87556 [6029223, 6058961, 6079763, 6100691, 6102367, 6225711, 6252881, 6258617, 6339232, 4565884, 4565891], 1x 87561 [6034982], 1x 87566 [4583182], 5x 87557 [4590285, 6097106, 4565893, 4567556, 4613853], 2x 87567 [4583184, 6057904], 4x 87568 [4583186, 4583475, 6058077, 6058110], 17x 87610 [6009135, 6032942, 6039912, 6040293, 6115457, 6328206, 6279726, 6288096, 6288336, 6288493, 6288500, 6346787, 6346795, 6374327, 4584441, 4598788, 6119249], 2x 90498 [6302710, 6302711], 2x 92474 [6333984, 6356899], 3x 92742 [4659376, 4600172, 9274200], 2x 92762 [6119496, 4630337], 2x 93057 [4624209, 4626659], 1x 93066 [4626630], 1x 93604 [6302712], 1x 98099 [4648446], 1x 98101 [6016943], 2x 98117 [6016945, 6021487], 1x 98118 [6016964], 10x 98138 [6322904, 6303528, 6303535, 6310396, 6310404, 6310411, 6310414, 6310460, 6310475, 6310556], 2x 420731 [4162159, 4245797] • Updated LDD palette. Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
Stephan Posted February 26, 2022 (edited) Development Version 20220226 Version 20220226 or GitHub [download files separate] and LXF file with new and updated parts New parts 22167 —— Electric 9V Battery Box Powered Up with 2 Switches and Bottom — Multi-colorable 24634 —— Minifigure, Bow Large with Pin Attachment — Decorable 27965 —— Hose, Flexible 22L with 2 Connector Ends (Zipline) — Not flexible (yet) 30211 —— Support Leg Small (Insectoids) 30635 —— String Reel 1 x 4 x 2 Drum with Friction Spokes 30636 —— String Reel 1 x 4 x 2 Holder with 2 Technic Pins 30680 —— Tile 2 x 2 without Groove [3068a] — Decorable 30690 —— Tile 1 x 2 without Groove [3069a] 30700 —— Tile 1 x 1 without Groove [3070a] — Decorable 31794 —— Technic, Steering Arm 5 x 1 with Tow Ball Socket Rounded, Chamfered (Type 2) 32577 —— Bionicle Tohunga Torso 35699 —— Minifigure, Hair Male, Smooth with Spiked Bangs 41612 —— Minifigure, Hair Female Long and Straight, Parted in the Middle 41893 —— Tire 68.8 x 36 H 42090 —— Monkey Tail, Curled — Multi-colorable 43097 —— Technic Linear Actuator with Dark Bluish Gray Ends, Type 2 [43097*] — Multi-colorable + extendable 44553 —— Minifigure, Hat with Pin Attachment, Tall Hat with Small Brim [44553*] — Multi-colorable 44740 —— Minifigure, Plume Ribbon / Tassel / Streamer 45275 —— Bionicle Weapon 5 x 5 Shield with Saw Blade Studded 46189 —— Technic Pin Connector 3L with 2 Pins and Center Hole [Pin Ridges Across Part] 46224 —— Technic, Gearbox 4 x 2 x 4 (Worm to 24-tooth) [46220] 46537 —— Projectile Arrow, Solid Shaft with Black Cross Shaped Rubber End [46537*] — Multi-colorable 47592 —— Electric, 3 x 3 Color Light Matrix - SPIKE Prime — Multi-colorable 49492 —— Minifigure, Utensil Shepherd Staff 49661 —— Duckling — Multi-colorable (not decarable (yet)) 49743 —— Projectile Launcher, Large Spring Shooter [49743*] — Multi-colorable 53118 —— Minifigure, Utensil Video Game Controller — Decorable 53500 —— Bionicle Head Connector Block Eye/Brain Stalk (Piraka) - Light-Up [54359] — Multi-colorable 53923 —— Hinge Cylinder 1 x 2 Locking with 1 Finger and Axle Hole on Ends without Slots 57360 —— Hinge Cylinder 1 x 2 Locking with 2 Fingers, 7 Teeth and Axle Hole on Ends without Slots 57697 —— Hinge Cylinder 1 x 3 Locking with 1 Finger and Pin with Squared Pin Hole and Friction Ridges on Ends 62233 —— Projectile Launcher, Bionicle Weapon Midak (Zamor) Skyblaster with Black Housing [60932c*] — Multi-colorable (holds 4 Zamor spheres) 65184 —— Propeller 1 Blade 14L with Axle Hole 65489 —— Technic Pin Connector Hub Perpendicular 3L with 4 Pins (Squared Holes) 65579 —— Minifigure, Hair Female, Parted in Middle with 2 Buns on Top 65768 —— Propeller 3 Blade 3 Diameter with Pin Hole 65783 —— Panel 10 x 4 x 13 Curved Tapered with Handle at Each End, 4 Studs On Side 65834 —— Wheel 43 with 4 Spokes with1 Holes and Integral Tire — Multi-colorable 67338 —— Croissant with Flat Ends 67351 —— Hub, Programmable, SPIKE 2-Port (Small) — Multi-colorable 67498 —— Technic Shock Absorber L with Internal Spring — Multi-colorable 67928 —— Minifigure Wing Small Feathered 69778 —— [[GEAR WHEEL Z12]] 69779 —— [[GEAR WHEEL Z20]] 69819 —— Technic, Axle and Pin Connector Perpendicular Double Split, Reinforced Sides 69858 —— Wave Rounded Single with Pin 69910 —— Technic, Link Tread Extra Wide with 2 Pin Holes 70490 —— Tire 49.5 x 14 71711 —— Brake Disc 8 x 8 — Multi-colorable 71720 —— Wheel Motorcycle 71721 —— Tyre Motorcycle Racing Tread, Narrow 71722 —— Tyre Motorcycle Racing Tread 72024 —— Container, Cupcake / Muffin Cup 8 x 8 x 3 73110 —— Plate, Modified 6 x 6 with 5 Pin Holes 73117 —— Minifigure, Utensil Candlestick / Candelabra 73878 —— Window 3 x 3 x 2 Round Corner 74880 —— Electric, Light Brick 1 x 2 with Single Side Light (6034 / 6035) 75538 —— Stuntz Ramp 75539 —— Slope, 5 x 8 x 2/3 with 12 Studs 75544 —— Windscreen, Curved with White Edges Print — Multi-colorable + decorable 75972 —— Code Pilot [32021c01] — Multi-colorable + decorable 76110 —— Projectile Arrow, Liftarm Shaft with Solid Rubber End [32133c01] — Multi-colorable 77590 —— Technic, Steering CV Joint, Large Ball, Long 77808 —— Brick, Round 1 x 2 with Hollow Studs and Open Center with Bars 77813 —— Tile, Round 1 x 1 with Loop 78442 —— Technic, Gear Rack 6 x 6 Curved 78666 —— Arch 1 x 2 Inverted 79387 —— Plate, Modified 4 x 4 x 2/3 with Rounded Corners, 4 Feet and 2 x 2 Cutout 79491 —— Plate, Round Corner 2 x 2 with 1 x 1 Cutout 79505 —— Technic Rotation Joint Disk with Pin and 2 Small Rotation Joints 79730 —— Door 1 x 4 x 6 with 6 Panes, Stud Handle and Hole for Pet Flap 79743 —— Minifigure, Utensil Cupcake Liner - Flat Top 79756 —— Slope, Curved 1 x 4 x 2/3 Double 79846 —— Plate, Modified 2 x 6 x 2/3 Bent 79850 —— Brick, Round 4 x 4 Dome Top with 2 x 2 Recessed Center 79851 —— Ring 7 x 7 with Axle Connectors 1L 79987 —— Plate, Modified 1 x 3 with 2 Open O Clips on Top 80267 —— Technic Panel Curved 5 x 7 Parallelogram Left 80268 —— Technic Panel Curved 5 x 7 Parallelogram Right 80286 —— Technic, Liftarm, Modified L-Shape Quarter Ellipse Thick 2 x 5 80796 —— Brick Special 1 x 2 x 1 2/3 with Four Studs on 2 Sides 86876 —— Brick, Modified 1 x 2 with Stud on Side 86996 —— Brick, Modified 1 x 1 x 2/3 with Open Stud 89678 —— Technic, Pin 1/2 with Friction Ridges 89681 —— Plate 6 x 6 Half Circle with 2 x 2 Cutout and 2 x 6 RaisedOriginal parts — updated parts Custom parts — updated parts Original / Custom parts — decorated parts New colors Updated original parts• Created extra decoration surfaces: 4744, 10304, 10305, 11217, 11219, 11331, 14397, 15511, 17012, 17013, 19017, 22385, 24076, 24779, 25113, 25114, 25266, 25741, 25743, 26078, 28240, 28710, 28782, 29602, 29685, 30370, 30380, 33862, 43702, 46203, 48494, 50950, 50995, 59349, 62576, 64803, 64806, 69214, 72824, 87557, 87561, 87556, 87566-87568, 87610, 92474, 92742, 92762, 93057, 93060, 93066, 93604, 98099, 98101, 98117, 98118 • Updated decoration surface: 4740, 48288, 61189, 63864 • Added collision data: 28782, 65426, 65429 • Updated collision data: 3832, 3957, 4079, 59443 • Made flexible: 48294 • Updated connections: 36017, 87693 Updated custom parts • Created extra decoration surfaces: 9441, 9442, 24108, 24630, 27956, 29353, 35037, 46534, 53075 • Updated connections: 35578, 65138, 65426, 65429, 78258 • Updated collision data: 67095 • Updated 3D model: 48177 • Updated UV map: 69729 Other notes: Updated original parts: • Updated decoration surfaces: 3009, 13196, 19859, 22385, 30375, 30401, 58148, 92744, 92754, 92755, 98103 • Updated collision data: 2357, 2431, 3003, 3832, 3958, 11476, 22388, 22888, 24246, 26007, 60623, 63868, 87609 • Updated connections: 24119, 61927, 92694, 92696 • Updated decoration: 55513, 56756, 58858, 60382 • Updated assemblies: 61927 • Updated 3D model: 32476 Updated custom parts: • Updated collision data: 2688, 2805, 2806, 2880, 2884, 2885, 2890, 2911, 9075, 9112, 9113, 9338, 9390, 9391, 24849, 24853, 25561, 29096, 34745, 35044, 35789, 37195, 37352, 37695, 42545, 49311, 67810, 69729, 70834, 71682, 71689, 73507, 238160, 426502, 932901 • Updated connections: 2682, 2683, 2684, 2686, 2688, 2772, 2774, 2880, 2881, 2883, 2884, 2886, 2890, 2911, 9075, 9320, 9367, 9368, 9390, 9391, 9479, 9485, 9486, 24849, 24853, 25560, 25561, 34745, 35789, 37195, 41014, 41041, 41089, 49308, 65138, 65578, 92694, 92696, 238160 • Updated outlines: 9014, 9015 • Updated 3D model: 28974, 43461, 44861, 67887, 71708 • Updated subMaterialRedirectLookupTable: 39739 • Updated assemblies: 40918 • Updated decoration: 733271 Other notes: • Added decoration: 10196, 12170, 13396, 13828, 13829, 14305, 14875, 21605, 23349, 24075, 24594, 26395, 31904, 32734, 32736, 32737, 33501, 38938, 38940, 39551, 40214, 61668, 63671, 66747, 66750, 70250, 72189, 72190, 73174, 73873, 74459, 75972, 76885, 79289, 79425, 80129, 91128, 93695, 94401, 97060, 121701, 300901, 301001, 304010, 306803, 329701, 329702, 329703, 343401, 362201 • Updated DecorationMapping.xml with 10202, 15535, 22385, 30375, 30401, 75972, 92744 • Updated 2020NewPreColoredParts palette with: 2x 3009 [3009001, 6181532], 4x 3010 [6352006, 301001-301003], 1x 3068 [6044242], 2x 3069 [6129504, 6329662], 1x 3245 [6236403], 3x 3297 [3297001, 3297002, 3297003], 6x 3622 [3622001, 6182794, 6182795, 6182796, 6187583, 6334670], 2x 10202 [6326765, 6289431], 1x 13196 [6032933], 5x 15535 [6323422, 6228439, 6228441, 6117346, 6323423], 14x 19859 [6236394, 6250233, 6129138, 6268116, 6133092, 6122023, 1985900, 6323037, 6136699, 6144545, 6129135, 6125834, 6132358, 6125831], 1x 22167 [6214082], 1x 22385 [6133525], 2x 24634 [6275807, 6143290], 8x 30375 [6006068, 6038363, 3037501, 4143919, 4657351, 6067930, 4614789, 4631875], 1x 30401 [3040100], 1x 30700 [3070001], 1x 37352 [6380350], 1x 42090 [4209000], 1x 43097 [6368625], 2x 44553 [6259208, 6273916], 1x 46224 [4622400], 1x 46537 [6307940], 1x 47592 [6275773], 1x 49743 [6296378], 1x 53118 [6275176], 1x 53500 [4288205], 2x 62233 [4521177, 4609600], 1x 66855 [6353881], 1x 66858 [6360244], 1x 67351 [6296321], 1x 67498 [6328490], 2x 72046 [6339182, 6374432], 1x 74880 [74880], 1x 75544 [6361895], 1x 75972 [7579200], 7x 76110 [4114419, 4118818, 4140376, 4225060, 4262398, 4266085, 4281254], 1x 90498 [6289448], 1x 92744 [6019634], 1x 92754 [6044718], 1x 92755 [6044717], 1x 93273 [6352819], 3x 98103 [4653821, 6029655, 6032924] • Updated MaterialNames EN + DE with 17 new colors (144, 155/175, 156, 173, 174, 293, 295, 300, 332, 333, 334, 335, 337, 340, 342, 343, 344, 345, 346, 348, 349, 350, 352, 355, 357, 358, 366, 367, 368, 369). • Updated CurrentMaterials and MaterialSelector with 3 new colors (366, 367, 368). • Updated Materials with 17 new colors (132 [Black Glitter], 144 [Dark Army Green], 155/175 [Tr. Green with Glitter], 156 [Tr. Deep Blue], 173 [Tr. Red with Glitter], 174 [Tr. Blue with Glitter], 293 [Tr. Light Royal Blue], 295 [Flamingo Pink], 300 [Copper, Drum Lacquered], 304 [Cool Silver, Diffuse], 306 [Copper, Diffuse], 334 [Copper Ink], 335 [Gold Ink], 340 [Tr. Blue with Glitter], 342 [Conductive Black], 343 [Diffuse White], 346 [Copper Metallic], 348 [Tr. Yellow with Glitter], 349 [Tr. Brown with Glitter], 350 [Tr. Fluorescent Blue with Glitter], 352 [Tr. Fluore. Redd. Orange with Glitter], 355 [Tr. Black IR], 358 [Translucent White], 366 [Transparent Blue Opal], 367 [Transparent Green Opal], 368 [Vibrant Yellow], 369 [Light Block. White]). Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
Stephan Posted February 28, 2022 (edited) Fix Version 20220302 Version 20220302 or GitHub [download files separate] and LXF file with updated parts (This version includes all previously added and updated parts.) Updated original parts: • Updated decoration surface: 3297, 32523 • Updated collision data: 6190 • Updated assembly: 61927, 92693 • Reverted to original orientation: 29602 Updated custom parts: • Updated category: 19086, 39369, 67139, 70644, 71708, 80286 • Updated collision data: 71708, 78267, 80267, 80268, 80286, 426502 • Updated outlines: 27448, 73109, 73507, 73682, 80267, 80268 • Updated 3D model: 80286, 426502 • Added collision data: 27448, 98107 • Updated connections: 62233, 426502 • Updated assembly: 40918, 43097 • Reverted to original orientation: 69729 Added missing files: • 3297, 9488, 9489, 9559, 19859, 37091, 37092, 47157, 62271, 62273, 62274, 62275, 65834, 69729, 76110, 30680, 86876 Other notes: • Added decoration: 301002 • Updated 2020NewPreColoredParts palette with: 1x 3010 [3010001] Edited October 29, 2023 by Stephan Share this post Link to post Share on other sites
