I have finished my car.
Youtube video:
My car's body inspired the Ford Ranger scale 1:8 The original project near 2 year old. The original chassis have 6 speed gearbox and brakes. I need this replace because no more free space. I have only the half completed body used. Get new chassis and weapons.
This car have a three version. The Street version have no weapons only plasma tv (tablet) in rear section. The Army Edition have weapons. This is the normal Bandit. The BIG BOSS have grille and this can not only attacking but also protect yourself.
Electric functions: IR: Driving XL motor, Steering Servo motor, Lights 3 Led lights with switch. Automatic compressor with pressure switch.
Pneumatic Functions: open the rear section, open the spike tank, shooting with bow, the suspensions make harder and higher.
Manual functions: openable doors with locks openable hood, openable rear door, extendible front spikes, and shooting with cannons ( one on the hood and one on the rear door).
Edited by GaBika
hy i really like this moc but:
- i don't think there is suffient transformation
- you can't detach anything and replace elsewhere (arrows)
- also the grills on the windows can't be attached afterwards. they should pop up from the door.
-the trunk and the window grills should be in another topic
also if you begin begin your topic [TC7] Bandits-Ford Ranger A.K.A The Beast more people will look at this
Edited by TheNextLegoDesinger
True, you cant remove pieces and reattach them.
I am also not sure is this enough of transformation, basically there is no change in the bodywork or onto the chassis.
Otherwise, good looking body, no gaps and true proportions. This vehicle would be much better looking with bigger tires.
Hi,
Nice MOC!
I'm not sure this will qualify for the TC7 contest though. I don't see any transformation to the body or chassis? Your vehicle is not changing. This feels like "only guns popping out", which is not allowed.
Can you show us clear pictures of Normal mode and Battle mode, so I can make a proper judgement.
I like this MOC. Would it be possible to have the front rocket launcher be pulled up from side pf the hood. From the video it seemed like there would be enough space there. Having one each side would be even better :)
I mean if the flat panel at the side of the hood would open and the missile would turn out from there...
Just a thought, Good luck!
That's a great moc. Its a good idea from LegoCube, I have one suggestion. Off road 4x4s tend to have heavy duty roof racks so my thought was the front window mesh could be the disguised roof rack then simply fold down over the front window for battle. Just my 2 cents worth. Awesome car and hope to see it in the comp.
Are you still aiming this moc for a competition? It looks like there is no other transformation then black glass for the windows and different tires. Also it seems you remove and attachpieces, which is forbiden.
Plus, badits should not have so much black color. Try to put mgrey instead of the black.
I'm still hoping for this vehicle to do something we all didn't expect.
Otherwise it won't be enough. Milan is perfectly right in his judgement.
There's indeed too much black, but that's something that worries me the least.
