Hi all,
I just can't get my head around what I need to do to get LDD2POV-Ray to actually render a model for me - every turn seems to lead to another error
First I get this:
line 10: Parse Error: No */ closing comment found.
Line 10 has this: #include "ldd_default_colors.inc"
So I added a /* to the start and a */ to the end of the section so it looks like this:
#include "ldd_default_materials.inc"
#include "ldd_part_materials.inc"
#include "ldd_part_bevels.inc"
#include "ldd_part_position_variances.inc"
#include "ldd_main.bin"
That seems to sort that out. But I then get this:
line 26: Parse Error: Cannot assign uninitialized identifier
Line 26 says: #declare ldd_camera_location = ldd_vtransform(<0, 0, 0>, ldd_camera_transformation);
If I remove all the camera declares, I get this:
line 28 Parse Error: Illegal character in input file, value is 80
Line 28 says this: #include "ldd_3828.bin"
If I then remove each include one by one, I just get that same error message each time.
Pulling my hair out here
Edited by Brockhenhaus
Error
/* … */ is a block comment: everything between the markers is ignored.  That means your “fix” prevents all the definition files to be included.
And, no, sorry, I’ve no idea what the real fix is.
10 hours ago, M2m said:
I would put Line 28 into a comment block....
Not really sure what that is, plus if I remove each ldd_.bin one by one, I just get the same error on the next piece.
However, my main issue is why are there all these errors? Are LDD2POV-Ray and LDD no longer compatible? I never used to have these problems a couple of years ago but now it seems LDD2POV-Ray is bust and no-one seems to know what's going on.
Then I guess the error might be really somewhere up ? Maybe try to convert the file to a ANSI ASCII file (using notepadd++). Might be some Unicode character somewhere which misses it up ?
As a sidenote afaik LDD2POV-Rays source code isn't available, is it ?
