Hello, This is my first MOC post here on Eurobricks so forgive me if I make newbee mistakes. :classic:
Here's my fancy little diagram that's shows you how it works!!
This is a an idea I am hoping to expand in the future to do some actually cool stuff ( :
Firstly you need to enter the infomation you want to move the motor on the Raspberry Pi (the direction and the amount of degrees).
Here is a little 3d render of it. The motor rotates the amount you specify and the color sensor on the right side senses if the Rasberry Pi's LED.
For the instructions, more infomation and all of the things you need to set this up and build it for yourself come to my website:
http://bostonsbrickcloset.blogspot.com/
Video:
[media]http://www.youtube.com/watch?v=T85PzIO5GSk[/media]
Not sure why the vid does not work ) :
 Links for the images: (for Creative Commons)
https://commons.wikimedia.org/wiki/File:Lego-mindstorms-ev3.jpg
https://en.wikipedia.org/wiki/File:Raspberry-Pi-3-Flat-
Top.jpghttps://en.wikipedia.org/wiki/File:Raspberry_Pi_Logo.svg
Edited by Bostons Brick Closet
Changed Version to 0.5 and a few little cleanup things
2 hours ago, JopieK said:
Nice idea ;) now that the Pi Zero also has WiFi / Bluetooth it will be great for LEGO applications I think.
The Pi 3 model B has buit in WiFi so I am working on making It hosting a website. I am going to use that then to collect data for a real project and not just an demonstration.
Also do you know why my video does not work?? Thanks
9 hours ago, Bostons Brick Closet said:
I'm not sure why the tags aren't working either (and now I can't remove the quote or post outside of it), but this looks interesting. I look forward to seeing what you can do with this.
Edited by Jay Psi
Thanks I have an interesting robot that I am almost done with, It can take infomation from a hosted website to then send the infomation to the mindstorm brick
Well, but isn't the Pi 3 a little bit an overkill for 'embedded' applications?!
There is always the Pi Zero W ... footprint of the zero, with wireless capability.
I am aware that there are positives and negitives of the different pi's but this one is the only one I have!
Of course, I never 'assumed/implied' availability was the point. Though i agree, I find it much easier to work with the RPI3 than with the Zero. The RPI3 has full-size USB connectors, whereas the Zero does not and you need special cabling and a USB hub.
Back to your point. A while back in a related thread, I 'speculated/hoped' that in the future, we might see some merging/integration/adoption of either/both Arduino/RPI platforms into the MindStorms theme. Mindstorms requires heavy investing/development (both hardware and software) wherea Arduino/RPI rely on 'open' architectures an a very large hobbyist base. I think (maybe) it'll be more 'economical' for both TLG AND the lego community (us AFOLs) to merge lego components (motors/sensors) to 'standard' electronic boards (Arduino/RPI). There are some 'attempts' out there, but those rely on both the lego brick AND an RPI. But then again, TLG has never really adopted/absorber/bought another company and they prefer to develop everything themselves, or pseudo-joint-ventures as in LabView+MindStorms.
Last question: Are you from the Boston area? I went to school for several years in Cambridge, on the Hudson.
Edited by DrJB
^ not sure if the "intelligent brick" is needed in all solutions... this interface here afaik works straight on the RPI: http://www.mindsensors.com/content/78-pistorms-lego-interface
(stumbled over it a bit ago, thats why i immediately remembered)
That is what I said in my initial reaction ;)
You're right ... lol. Somehow I did not see your post ...
Better yet: I was merely emphasizing YOUR point :)
Indeed ;) I haven't had a lot of experience with the new Zero but I have one already at home and new one coming...
