Hi,
I'm trying to build a garage door in LDD - the type that can also be found on fire stations, etc.
I've found two parts called "lamella for rolling gate" and "stop lamella for rolling gate".
I can see that these fit together but I'm not sure on how to use them to make a working door.
Any help greatfully appreciated.
Many thanks.
Simple: you click together as many of the former as you need, and add one 'stop lamella' at the end. This end will be the bottom of the door, touching the floor when closed.
Good luck!
Many thanks for the replies - I have something but I must be going wrong somewhere as I'm struggling to line up both the front and top lamellas with grooved bricks - if that makes sense.
Also, is it possible to open and close the door in LDD?
Thanks again.
Nope, not really. Apart from opening doors and rotating axles, LDD isn't very good at part movement.
