Hi
Is there some brick/way I can make a corner for a half pipe, something like this but with no railingscorner-Ramp.gif
I have the normal straight bits for the ramps but I'm stuck on the corners, i'm using these for the straight ramps or maybe something like it which has a curve better suited to the corner (if I can make a corner)
I cant seem to find anything in LDD/Bricklink
Regards, S
I'll try that, thanks
Edit: Sorry, looks like its too big as there is two even bigger ramps as well that will be needed, maybe this is too hard to replicate in lego
Edited by SNIPE
If I recall correctly, this piece is from Sports (2002-2003) and was part of mainly snowboarding sets, so I don't know if it has other colors than blue, but the ramp pieces that attach to either side are in several colors such as old grey, beige, white, and blue. Old grey was in Island Extreme Stunts, one set, two pieces like this.
There are very few other smooth pieces that could create a corner ramp effect like this. This one is your best shot for a smooth surface unless you have expert MOC building skills. Good luck making it!
Play well,
Maniac4Bricks :)
