So i got oday used rc motor but i want to open it beacuse it doesent work. Does anyone have pictore of the opened motor or any tips how to poen it.
Edited by Rufus
Clarified topic title
when i finally got it opened with a flat screwdriver, the plastic was so destroyed, that it could not hold together properbly, and it is quite hard to get all the gears into place and hold them there while putting it together. :classic:
do you have the correct cable? if so, try putting the end that fits onto the motor at different angles (vertically/horizontally) because one of my motors doesnt work when you have it on a certain way, I'm guessing it has to do with polarity...
Please take your time when posting: this is almost unintelligible. Thanks.
Also - to everyone - please make every effort to ensure your topic titles are informative, and specific to the question you're asking. This makes it much easier for other members to find the answers to similar questions without having to start another thread, and keeps the forum readable for everyone.
Thanks!
Can you hear the motor trying to move or is it just completely lifeless? I use these motors more often than any other and found them to be very reliable. The only problrms i've had have been caused by slight corrosion on the electrical contact. So make sure these are nice and clean.
I have had a few issues like this with various 9V system parts, what allanp says is most likely the cause, the 4 stud connections have a habit of getting dirty and then no power can get through. it ma be worth going the motor a sniff as well, if there is a smell of burning then you may have a burnt out motor. Even if the brushes were well worn you would expect the motor to try and turn a little
Problem solved! I opened the motor cleaned all the gears, putted it back together(plastic wasnt so much destroyed), bought new wire(8886), also i took the micro motor out to clean it after tinned new wire at the back of the motor and everything works perfectly!
Sorry about bad english.
