mmcb Posted July 18, 2012 Posted July 18, 2012 I've created a few models in LDD (Version 4.2) and was wondering if I can get a parts list from it so that I can order the pieces? Unless I'm going blind, I can't find anything in the menus or in the generated instructions. Cheers, MMCB Quote
DLuders Posted July 19, 2012 Posted July 19, 2012 You need to use Superkalle's LDD Manager to generate an Excel spreadsheet containing the parts in your LDD model. Quote
Calabar Posted July 19, 2012 Posted July 19, 2012 LDD allows to generate an HTML part list too. The list is the last page of the HTML instructions. Which one is the best solution depends on what you have to do with the part list. Quote
Whiteagle Posted July 20, 2012 Posted July 20, 2012 (edited) Uh... I've actually had the same problem today... and the HTML list is worthless in helping... You see, I'm trying to buy the parts for an IFV for my Brikwars army, but it didn't help point out that the piece I want to use doesn't actually come in the color I wanted or that it has a nearly identical older verson that could replace it. Would this LDD Manager be able to spot something like this, or at least give me a semi-coherant parts-list for Bricklink? Droid IFV (recolor).lxf Edited July 20, 2012 by Whiteagle Quote
Lego Otaku Posted July 20, 2012 Posted July 20, 2012 Uh... I've actually had the same problem today... and the HTML list is worthless in helping... You see, I'm trying to buy the parts for an IFV for my Brikwars army, but it didn't help point out that the piece I want to use doesn't actually come in the color I wanted or that it has a nearly identical older verson that could replace it. Would this LDD Manager be able to spot something like this, or at least give me a semi-coherant parts-list for Bricklink? LDD Manager can warn you of rare color or nonexistent color. After you import a model in and while you're on part summary tab, you'll see a column under color warning. There's also a checkbox for show only color warnings. See SS below: Quote
