The Undo Posted January 4, 2012 Posted January 4, 2012 (edited) Hi, i have a problem regarding LGEO parts library. I don't use Ldraw directly so i'm not that familiar with stuff related to it. What i want is to present my LDD mocs through POV-Ray renderings. To do that i need to convert my .lxf file to .ldr file, and then convert .ldr file to .pov file. For this last conversion i use L3P with L3PAO. Now, this can be done without the LGEO parts, but the final result is not as good as with LGEO. So i downloaded LGEO parts (from http://www.digitalbricks.org/ ) , put the LGEO folder into my LDRAW folder, opened L3PAO and shown it the location of lg folder, but then i got the message: "Certain .TAB files needed for LGEO substitution appear to be missing. L3PAdd-On will function properly, but LGEO library substitution may not be available. You may want to check your LGEO install." I went to LGEO folder and those .TAB files really aren't in it (and there not hidden either). Looking on the internet i found out the names of those files (l2p.tab, l2p_ELMT.tab, and l2p_ptrn.tab), but nothing more on where i can download them or something (and the digitalbricks is the only place where LGEO can be downloaded). I used LGEO parts on my older computer (with the same operating system as i have now) and never had this problem. PS: This kind of thread already exists on eurobricks (where the problem isn't solved) but i didn't want to write in it since it is in the „wrong“ subforum (http://www.eurobricks.com/forum/index.php?showtopic=37343) Maybe the easiest solution would be if someone can send me those .TAB files via mail (omerajo@hotmail.com), if that would work. Any help is appreciated. Edited January 4, 2012 by omerai Quote
Alasdair Ryan Posted January 4, 2012 Posted January 4, 2012 Hello Omerai Your link does not work,here is the working one: Digitalbricks From Digitalbricks: Depending on your OS, you might need to check for upper or lower case in the folder name. By default, it is all lower case. Have you tried this? I have never used this application before,perhaps a file converter could change it to a pov file? Quote
The Undo Posted January 4, 2012 Author Posted January 4, 2012 (edited) Thank you Alasdair for the quick reply, but the casing didn't help. The problem is that those files are missing (i even used the LGEO folder from LDraw all-in-one installer and it also misses the .tab files). The digitalbricks link i provided is now fixed. Thank you for noting that. The LGEO folder is a parts library like ldraw, and the parts it contains are pov versions of ldraw parts so the renderings look much smoother. Now i read in the Lars Hassing's (creator of L3P) page (http://www.hassings.dk/l3/l3p.html) that the files lg_elements.lst and lg_colors.lst (which are in the LGEO folder) replace the .tab files. So this problem which i have shouldn't exist, like it didn't exist on my older computer when i was using L3P. EDIT: PROBLEM SOLVED (partly) I found the newer wersion of L3PAO (http://news.lugnet.com/announce/?n=3860&t=i&v=a), which doesn't need the .tab files, but it still won't make pov file using lgeo parts. I'll try to see what i'm doing wrong. Edited January 4, 2012 by omerai Quote
Palathadric Posted January 5, 2012 Posted January 5, 2012 If you can solve the problem then please let me know how you did, because I encountered this same problem and have not yet found a solution, although I really could use the LGEO Library working properly. Quote
legolijntje Posted June 25, 2015 Posted June 25, 2015 I would recommend to export the ldr to pov using LDview. L3P and stuff is really outdated... You can try if it works with LDview Quote
Darats Posted June 25, 2015 Posted June 25, 2015 The current LGEO library you can find around, is not compatible anymore with L3PAdd-On. Try ldview. Quote
