Short Maintenance (13.07.2026, 09:00 AM UTC, ~30 minutes) ×
Are you trying to choose between getting a particular lego or megabloks set? If so, you need to state which ones. If you mean the lines in general, it is kind of a silly question to ask on a lego forum...
Well, if you're planning on mocing something original using your own creativity, Lego.
If there's a Megablocks set that has a ton of detailed, but pre-molded pieces, I guess you should get that.
But remember... advanced building = Lego. Period.
More parts, more colors, better quality, bigger fan support, parts availability...
Well, whatever you do, keep them in separate bins. You will inevitably kick yourself if you don't.
I'm curious too... what set(s) got your fancy over in MBland?
Edited by JINZONINGEN 73
  • 4 weeks later...
