We are applying further DNS changes Γ—
Hi everyone, my next project will be a minifig scale ARC 170. I want it to have SNOT wings, and every detail possible. Does anyone know of/have blueprint pics?
I'm also wondering what a stable connection is for those wide SNOT wings is? I'm thinking 65 studs wide, and 39 long (When I did the math I was like *huh* ). It's gonna be big!
Let's see, I know I found a couple somewhere...
Front
Side view, from Cato Nemoidia
Top, from Coruscant
I don't know where that second one is from, but the dimensions look about right.
For larger models I would advise you not to go with canon dimensions, as those can be quite off (no way Vader's TIE Advanced x1 is actually longer than a TIE/ln).
I'm certain that the proportions on Pepa's model are more accurate than those of Reto's - the difference in size of the noses of the two models should be a good indication.
EDIT: For SNOT wings, you'd have to use Technic the way they did on 10212... or not, looking at the MOC Brickdoctor linked to.
Edited by fallenangel327
Hello!
It's not directly a blueprint, but a schematic drawing where you can spot all of the desired details.
ARC-170 Schematic Drawing
Although the wings are not SNOT, there are two fantastic UCS ARC-170 starfighters, by Reto Geiger and Pepa Quin. I am sure you can find some useful inspiration there. :classic:
Good luck with your project and have fun!
~ Christopher
Thanks, I need to buy that cross section book.
Front
Top, from Coruscant
Thanks for those, Pics. I think I'll make it a bit smaller. Yeah, I wish there was a better way to connect those wings, though. Technic looks so ugly.
Ok guys, here's my progress so far. I've done the body, yet I'm not so sure about dimensions. it's 41 studs long and 10 studs wide. I've left the Technic there to leave open possibilities for wing/engine attachment.
And the nose:
snip
And the piloting cockpit:
snip
C&C Requested! :classic:
EDIT:Sorry those last two weren't resized, I'll put 'em up later.
Edited by brickartist
The printed or stickered piece sticks out like a sore thumb. but I like it, especially the nose. Are you going to complete the Astromech socket
Yeah, the print has faded through 5 years of bins. I may have to use the new stickered piece.
As soon as I find some more cheese it'll be complete. :classic:
The area surrounding the astromech droid socket should be as tall as the neighboring cockpits, and the rear cannons could be beefed up a bit.
I would agree with Masked Builder about the LEGO cockpits - surely there must be another way?
Also, Pepa Quin appears to have come across some decent reference:
Rear
Side
Top
Length-width ratio of the middle section according to the third picture is roughly 18/95, so I think it could be a lot longer.
Rear
Side
Top
I've been thinking about the cockpits alot, and yes they aren't satisfactory. I may brick build them in the end. For The tale gunners cockpit, I'm lost. does anybody know if Tlg has made a quarter dome cockpit?
I think you may be better off just making brickbuilt cockpits with black bricks.
Trans black, correct? :wink:
I suppose I will give brick-builts a go.
So I'm starting to think more about engine structure, design and my method of attachment. Right now I'm thinking about simply putting some Technic beams going through the width of the ship. Then attaching the wings tho that same beam.
That's a nice start brickartist, modifying the official Lego ARC-170 is a good approach. However, the first thing I've noticed is the slight blockiness and visible gaps of the nose. I actually think the official one can be modified in such a way wherein you could capture the smooth curved sloping finish of the real one, like what I did with mine:
I think you should remove the plates on the top of the nose and retain the curved slopes, as this provides a continuous smooth curved finish for the nose. And the astromech head should be placed at the same level as the top surface of the cockpit pieces, like in the Side view, from Cato Nemoidia image provided by fallenangel. Those are the only things I could suggest so far. Looking forward for the progress of this one.
Thanks KDm, the only thing I despise about TLGs is the green section of the nose goes about half the distance it should. What i think I'll do is apply the stickers to the rounded section of the nose, then continue with more green behind it. I think I will buy that set for the parts. :laugh:
Upon closer examination, isn't TLGs waayyy to long,linky.
It appears that the nose should be about twice the length of the cockpit, maybe it looks disproportionate because of the cockpit.
