WOW!!!Check out the digging depth of that italian guy, see how the boom is almost parallel with the superstucture?..I could see he moved the mounting point on the grey beam one hole to the front. Can anybody tell what else he did to achieve such digging depth just by seeing his video?
Edited by Out of Sight
Another one from italy took my idea i think the movie is from 3 januari
The digging speed is really good, but the slewing speed is WAY faster than scale. The whole superstructure jerks and recoils every time is stops. This must be another 11.1V LiPo model.
Yes li-po it is
He's verry happy he had seen my vid on you tube :thumbup:
That fast slewing speed is purposeful ...if...the owner removed the bucket and swap it with a wrecking ball to demolish buildings, usually attach to the end of the dipper arm on an excavator. :laugh:
If someone have the engineering and tools to modify the 2 left drive M motors faster, maybe close to 2000rpm while keeping the rest stock, we could have faster moving boom and dipper while still retaining a manageable slewing speed with a stock 9v battery box! Rien, can you do that? You seem the only one around here with enough 'guts' to hack Lego parts :classic:
Thats no problem :run it on li-po than add resistance to all wires to recivers to 9 volt exept the drive give him 11,1v
Thanx for the idea.
Thanx for the idea.
If you're going to do that, use diodes (0.7V drop per diode), not resistors
  • 7 months later...
Someone could take a PF-M motor and run it on 11 volts for a few days to see how fast it burns out :)
I might volunteer actually :P
Hahaha youre so funny.
If you can read i did that for a while know an no burning so if you dont try than dont whine!
Stil works fine and fast after a lot of months.
