DLuders Posted May 19, 2010 Posted May 19, 2010 A77 posted his 13-SPEED truck transmission on his Brickshelf folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=418096 . I recall seeing a recent Supercar MOC with 7 speeds, but 13 SPEEDS can really get you down the road! He wrote, "13-speed truck transmission. Original version is used in my Lego 4WD Vehicle and Alternative Setup, containing _alter_ in file name, is for normal truck use with front-mounted engine and rear wheel drive." Long-haul truckers should be sure to check out the larger versions of these Bricklink pictures: Quote
Jurgen Krooshoop Posted May 19, 2010 Posted May 19, 2010 Looks quite impressive. It seems to be a combination of 2 gearboxes (main & auxialary), quite smart. Quote
Alasdair Ryan Posted May 19, 2010 Posted May 19, 2010 nice what you need now is a pf setup for vehicles , to change gears easy enough to do how ever it might be challenging to make a gear box that can side left to right as well as up and down Quote
