Eurobricks Forums
Just a question...
What does this have to do with Pirates? :pir-sceptic::pir_laugh2:
:jollyroger:
They're line infantry.
I think it's OK. The Torsos are the best for this in LDD, but all in all, they aren't that appropriate. The uniform is too... uniform. The hats on all of them should be white. Also, the office doesn't really match. Maybe give him the same torso but some sort of distinguishing feature.
Probably the best you could do in LDD, but it's not really good.
The current LDD needs more torsos, weapons (at least spears and/or pistols)and other minifigparts at once ! If they did add some, people would start using it more often and they might even buy more.
I only used LDD once because it scared me away having so little minifig choice.
If i'd have to order bricks only it is better suited.
  • Governor
Just a question...
You may laugh now but just wait till LDD has proper Imperial Guard torsos!
Which most likley would be stickers...
Um... Can I use those torsos in the PTV contest entry?
Fire away! :cannon:
You can use whatever the hell you like in the Pillage the Village contest. So long as it doesn't breach the rules. I would say use it for a rich merchant or something along those lines.
And as for the army, wait till there are proper soldier torsos in LDD.
