Wurger49 Posted February 12 Posted February 12 There has been a lot of interest in my Imperial Gunship, which naturally led to my next design. This time I wanted to explore another Republic era starship that was later pressed into Imperial service, the Nu-Class Attack Shuttle, as seen in The Bad Batch and the upcoming Maul - Shadow Lord. Like the gunship, I scaled the model based on the cockpit windscreen. Using a two stud wide windscreen allowed me to incorporate 4x4 round bricks as the folding wing roots, giving the shuttle a much stronger visual presence when displayed. The Nu-Class was designed by Cygnus Spaceworks as a faster, long range supplement to the LAAT gunship. It featured heavier armour and shielding, and included a hyperdrive for extended travel. In its role as an armoured transport, it could carry up to 30 clone troopers, though it lacked the missile launchers found on the LAAT. The cockpit module features angled side walls and a sloped top panel, with the white boarding hatch positioned on the front right beneath the nose. Armament includes two cheek mounted laser cannons beneath the cockpit, along with an additional pair of laser cannons built into the wing roots. The Nu-Class has its iconic folding wings, similar in concept to the V-19 and Lambda Shuttle. The wings are mounted using clip elements and fold up and down to the correct angles seen on screen. The angled side hulls are achieved using hinge plates underneath, while the dorsal fin is constructed by stacking plates, including the black Star Wars display plate. I was especially pleased to reuse the 2x2 angled plate to achieve the correct looking engine exhausts, only the second time I have used that part since incorporating it into the Millennium Falcon cockpit. Most of the longer bricks are used internally, resulting in a very solid core structure. The folding wings are strong enough for general swooshing, although I would not recommend overly aggressive movement. Even though most of the black elements were consumed by the shuttle itself, I still managed to build a simple display stand. The Nu-Class looks right at home next to the gunship, as if both were sitting inside an Imperial hangar. Instructions are on Rebrickable: https://reb.li/m/251531 Quote
