This is right now a hypothetical question, but I'm in process of designing two Powered Up locomotives that I want to run simultaneously.
Loco 1:  white 2ch PuP hub + large PuP motor.
Loco 2: same as above.
Option 1: Most convenient would be to use the specific PuP app Lego designed for the crocodile, but is it possible to use that app for "two crocs" simultaneously?
Option 2 would be to code a custom app ..can someone please share some screenshots of your program, if you have done that?
I'm merely looking for a simple speed control so I'd guess such coding should be easy....
Thanks in advance for any suggestions.
Edited by Selander
