The list of parts needed would help the most. I mean all parts needed that are not included in the original set. Can you list those?
  • 4 months later...
Took a while to do it, but I finished the Stud.io file for my PoweredUp modded 42209: https://www.dropbox.com/scl/fi/21n7a9za4qd1z113nrhur/42209-Complete.io?rlkey=v34usx3elijzz6bj532gskd3z&st=sznimknd&dl=0
42209 Complete
The front is 95% identical to the set. Main difference is that I added my mod for the boom. The RC mod works with the original boom, but you will have to adjust bucket tilt and boom while going up and down like you would with the set. That's not an issue with the movement mod. I decided to have the file show some sub builds to make it easier to build it from just the file (since instructions might never happen :look:) and a completed model for reference besides it.
Another thing for reference is the wiring, it's tightly packed, so I hope these photos help:
20251228_214208
The 2 wires closest to the wheel are the L-motor wires. One goes to the top of the hub and 1 at the bottom. And obviously the same for the M-motors:
20251229_205541
L-motor wires need to be tucked away like this to not touch any gears and then route them towards the rear under the L-motors and above the M-motors:
20251229_204830
20251229_204730
The tile above the gears from the M-motors is to protect the wires
20251229_204757
Placing the wires like this will avoid them touching the tyres even when the pendular axle is tilted.
Or you can just have them hang at the top over the hood (L-motors) at the rear as a quick method. Your call :classic:
If anybody decides to build it: enjoy :classic:
Edited by Appie
This is such a stunning model, you've donea great job. I really wish i had those smaller motors so i could build this.
Well done! 👏
Thank you Appie for sharing the studio file.
Can you tell us more about which motors you used as the small motors (you call them m-motors)? Is this a Lego part or a different manufacturer‘s make?
I found the motors and could buy them + also the other parts needed.
We will build the Mod.
Appie, could you upload the Pybricks code?
