FGMatt Posted May 5 Posted May 5 Yeah, I think modern power supplies generally use a linear regulator to keep the voltage steady. Quote
Toastie Posted May 5 Posted May 5 On 5/5/2025 at 8:30 PM, FGMatt said: use a linear regulator to keep the voltage steady Expand Yeap, and as @XG BC said, the modern switching power supplies are even better; efficiency (= heat generation) wise. It's simply a matter of taste. I simply like the hum of, e.g., the original LEGO power supply for 9750 (or that of my 99er which sits on a 230/110 voltage converter, again I chose a transformer - transforming 230 to 110 to transform 110 to whatever the TI needs ...) It will all work out. Best Thorsten Quote
cozzie4d Posted May 6 Author Posted May 6 Thanks, this is super useful. I might grab an additional transformer and check the connectors (spread the out slightly for better connection). Replacing cables is a last resort for now, as I've nicely hidden most of them with light gray 2x3 + 1x2's along side the tracks Quote
