VeniVediLego Posted October 21, 2023 Posted October 21, 2023 This is my fourth prototype and I'm quite happy with it. It is designed for real rigging made of 3mm twine. The same basic construction can be adapted for use as a 6 stud wide mast top. The top mast is held together with a No. 4095 Umbrella Stand with the stopper wedged into the base of the No. 43888 Support (which is tapered internally) and run through a Technic stud pin, a headlight brick, and an upside down No. 14716 pillar. The other end of the top mast involves rigid tubing, Technic pins, No. 73535/62462 pin connectors, and a No. 87617 Friction Cylinder, but I haven't figured out the top of that size mast yet. Reveal hidden contents Mike O Quote
Yperio_Bricks Posted October 22, 2023 Posted October 22, 2023 Quite some advances technique Looking forward to see it with full rigging! Quote
