Grimalkin Posted August 22, 2023 Posted August 22, 2023 (edited) I have a mind to try and moc ship cannons for a pirate ship. The reason for this is that the lego cannon that shoots 1 x 1 x 1 round pieces is out of scale. Beyond that, after modding the deck so that cannons can be stationed by the actual cannon housings, its a tight fit if eight cannons are mounted in position. I have seen moc videos, but I would like something larger than 1 x 1 in width. Ideally, I would like a piece that the 1 x 1 x 1 round would fit inside, like a scope if you will. Are there pieces like this? Thanks. Edited August 22, 2023 by Grimalkin Quote
Kivi Posted August 22, 2023 Posted August 22, 2023 One part that 1x1 round brick would fit inside is 2x2 barrell, but it is the same width as cannon base and consequently also wider than cannon tube itself. Do you plan to moc the entire cannon or do you only need the muzzle to be visible on the outside? In the latter case you can try with tires, this one may be the right size to fit around 1x1 round brick. Quote
1963maniac Posted August 22, 2023 Posted August 22, 2023 (edited) Bricklink shows this: Tile, Round 2 x 2 with Hole Item No: 15535 https://www.bricklink.com/v2/catalog/catalogitem.page?P=15535#T=C Edited August 23, 2023 by 1963maniac Quote
MAB Posted August 22, 2023 Posted August 22, 2023 There are various pieces slightly thinner, if you think about all the parts used to hold flick missiles. The 2L technic connector can make a reasonable cannon and is available in various metal like colours but won't fit a 1x1 round brick inside. Quote
Grimalkin Posted August 22, 2023 Author Posted August 22, 2023 4 hours ago, Kivi said: One part that 1x1 round brick would fit inside is 2x2 barrell, but it is the same width as cannon base and consequently also wider than cannon tube itself. Do you plan to moc the entire cannon or do you only need the muzzle to be visible on the outside? In the latter case you can try with tires, this one may be the right size to fit around 1x1 round brick. Yeah I saw a moc with that, thats more like a land based mortar. I would need something akin to 1 and 1/2 circumference. I do intend to moc the entire cannon, it may not be possible. This provides inspiration The one at 4:32 is closet but id like a little wider circumference. Quote
Mylenium Posted August 23, 2023 Posted August 23, 2023 On 8/22/2023 at 7:32 AM, Grimalkin said: Are there pieces like this? Nope. Only deco pieces like the barrel can be used that way, but they are meant to not be load-bearing. And that kind of seems to be the point: LEGO would likely never do such an element because of stability criteria. There's no way to add reinforcement ridges and such to such thin elements and that is most definitely the dealbreaker for your 1.25 x 1.25 barrel element you seem to be after. Mylenium Quote
Grimalkin Posted August 23, 2023 Author Posted August 23, 2023 7 hours ago, Mylenium said: Nope. Only deco pieces like the barrel can be used that way, but they are meant to not be load-bearing. And that kind of seems to be the point: LEGO would likely never do such an element because of stability criteria. There's no way to add reinforcement ridges and such to such thin elements and that is most definitely the dealbreaker for your 1.25 x 1.25 barrel element you seem to be after. Mylenium And there is no technic cylinder or anything that could achieve this? The problem I have with the cannon shooter is mostly lentgh, although I wish the diameter were a little thinner. Quote
Johnny1360 Posted August 23, 2023 Posted August 23, 2023 (edited) Maybe the fork tubes from 42130 BMW bike, they are very easy to disassemble, although they may be a bit large. I don't think any of the other fork tubes would be big enough but I do know they are all pretty easy to disassemble into their respective components. Edited August 23, 2023 by Johnny1360 Quote
