Hi Everyone,
I would like to share my attempt at building a small, functional Willys Jeep.
It is RC controlled using a Control plus Hub, and two Control plus L motors, one for drive and one for steering. I tried to "hide"the hub in the back by camouflaging it as cargo that is strapped down using the motor wires :)
The Jeep has full suspension front and rear using live axles. It is four wheel drive, with differentials.
The biggest challenges where the axles, especially the front one. I wanted the pivot point to be as close to the wheel center as possible to be able to keep the body tight around the wheels, and a decent steering angle. That combined with the four wheel drive, and the width of a differential plus CV joints was limiting the options quite a bit. I ended up building hubs that fit inside the wheels:
The next challenge was to get both the drivetrain and steering to the axle. First I mounted the steering motor the other way around compared to the picture above and used U joints to the front axle, but there was way too much play in that solution. In the end I changed things and build the linkage as you can see in the picture, which works much better. The steering wheel also rotates while steering, but it uses a rubber band because there was no place for gears anymore :)
The rear axle was also a bit of a challenge because the differential had to fit below the hub, and I didn't want to move it even higher than it already is. In the end I just put the differential one stud lower than the wheels and used a pair of 8 tooth gears.
The model is a lot of fun to drive, it goes quite fast with the L motor and relatively low weight :)
I'm curious to hear what you think of it!
I like this a lot, it seems like a nice tight medium scale build! That drivetrain is super short, not sure anything shorter exists with all the joints and differentials properly included! I also like the steering linkage, I have been planning to try such a setup for a while. Does it have noticeable bump steer? Nice idea with the rubber band to route it to the steering wheel! On the rear, isn't the hub a bit heavy for those soft springs? It seems like it sits in a bit more in the back, although I guess the axle geometry is the same as the front.
Great little set, well done, I do like the way you used the wires as part of the final model and love the belly shot. Probably the only thing I don't care for is all the holes in the body work at the back. Good job and thanks for showing it to us.
Thanks! It does have some bump steer, but mostly because the hubs are not stiff enough / play in the system. I think the rear suspension is fine but the front should be softer :) As in, I really like the suspension from the Defender set, where the model really sinks a bit into the suspension when you put it on the ground. It does that in the rear but not in the front.
Yes that is a really good point. Do you think it would be nicer with some tiles on the sides? (I dont have them currently in the right color to try it, or maybe I could take some from the Defender...)
