sonpham510 Posted September 15, 2021 Posted September 15, 2021 I am having a problem with 10261, after playing a lot and continuously, the track is no longer glossy, the train is not running smoothly, can I use any solution to solve this? i washed the rails with soap and it was back to normal, but after only 3 days its not working well again Quote
MAB Posted September 15, 2021 Posted September 15, 2021 Running plastic on plastic continuously is going to cause wear. If you want to run it continuously, maybe try spraying the track parts with a silicone spray designed for use on plastic curtain rails and similar. Quote
JopieK Posted September 15, 2021 Posted September 15, 2021 You could try some plastic grease? https://duckduckgo.com/?q=plastic+grease&ia=web Please do check that it is suitable for ABS. Quote
dr_spock Posted September 19, 2021 Posted September 19, 2021 Do you live in a dusty area or have pets? You can also try cleaning the wheels. Crud can build up on the wheels which can cause additional rolling resistance. Quote
ks6349 Posted September 19, 2021 Posted September 19, 2021 use soft damp cloth to wipe on the track, don't use any chemical cleanser. Quote
Vilhelm22 Posted September 19, 2021 Posted September 19, 2021 12 hours ago, ks6349 said: This set is retiring? Yes, as expected. We should get another fairground set next year though, as we’ve had 5 already. The ones I own are amazing. Quote
