hello, i am considering building additions to and getting kings castle seige, i had a idea of using the snapes classroom set to build a wizards area and peices form the transfigure book set to build a great hall and wanted to know what people thought of that idea or what they would do to build things to add to king castle siege
Edited by valon
You're referring to 7094, presumably? I don't actually have the set - so take my advice with a pinch of salt - but it looks from the pictures as though you'd need to insert any additions into the heart of the construction. I don't know how easy it is to split the walls, but I would bisect the left-side wallway to insert a building in the middle there, sticking half in and half out of the walls, and increase the battlements along said walls. Not sure what sets would provide the right pieces - to be honest I think you're better off designing your expansion in Stud.io and Bricklinking the pieces you need. Buying an unrelated set is just going to leave you with parts you don't need or necessarily want, and if you're buying the set not for the set itself but for how it can help your expansion, it might be a waste of money.
the sets are 20 dollars, or less on ebay, whenever i deisgn something on that even if it is small, irt ends up costing to much and i do not but parts
1 minute ago, eldiano said:
Kingdoms would fit perfectly with your 7094 mod, but the harry potter classrooms would put it over the top!
with blue and not red ? i might build that, but i want to build a keep for the kingdoms castle to
