Hello all! I'm going to show you several of my small chassis. I started working on them about year ago and during this time several options appeared.
All of them use PF L motors with buwizz.
Let's start with first one:
This chassis use 2 PF L motors with gear ratito 3:1.
Originally designed for drifting, causing the differentials to be locked.
If you don't own RC Buggy Motor this is a good option to try drifting.
If you are interested, there is an instruction: https://rebrickable.com/mocs/MOC-51807/NoExist/lite-drift-chassis-with-buwizz/#details
Second one:
This one was designed for usual cars.
Total gear ratito 2,5:1.
The chassis handles well because it has 2 diffs.
If you are interested in this chassis - soon will be finished instruction.
Third one:
This chassid was also designed for drifting.
This one has much more power, but requires Buwizz 3.0 or 2 Buwizz 2.0
Here is 4 PF L motors with total gear ratito about 5:1.
If you want to play with this chassis without body - you can try do it with 1 Buwizz 2.0.
And again, if you are interested in this, soon will be an instruction.
Write what do you think or share your chassis:)
Edited by NoEXIST
18 minutes ago, chlego said:
Cool! What is the wheelbase of the 2nd one? (distance between both middles of the wheels
Thanks! I make all chassis with a wheelbase of 21 studs (along with the axle that holds the wheel)
1 hour ago, syclone said:
Good looking chassis. Great way to secure the servo with quarter pins :thumbup: (on the second one)
This was an interesting find for me, they are easy to install
34 minutes ago, Seasider said:
Looking forward to the instructions for chassis 2 & 3 might have to have a play with these. I’ve only got Sbrick though
It won't be so fast with Sbrick, but i think that's enough.
28 minutes ago, Mechbuilds said:
So happy to have you here on eurobricks!
Your chassis is amazing!
Will you make a larger chassis with a suspension or keep perfecting the old chassis?
Thanks!
I had attempts to assemble a chassis on 49.5x20mm and 56x28mm ZR wheels, but so far i have not come up with a layout that suits me.
Another problem is the insufficient power of Buwizz 2.0 (in Ludicrous mode) to control 4L motors or 2 Buggy motors with load:/
This problem can be solved with Buwizz 3.0, but unfortunately it costs money. xD
Instructions for the second of 3 chassis on Rebrickable!
https://rebrickable.com/mocs/MOC-70387/NoExist/awd-2l-unlocked-differentials/#details
More photo: https://bricksafe.com/pages/NoExist/awd-2l-unlocked-differentials-
