Hi everyone,
I am working on a moc (speed champion scaled vehicle) and I have run into an issue. I would like to attach the black tile to the structure so there is no gap between them. I have tried a few things but they ended up being illegal or left a gap. Hopefully some is able to help as I am getting a little frustrated haha
here is a picture: https://ibb.co/ZWNjXxx
  On 3/5/2021 at 11:36 AM, Trekkie99 said:
You could replace the dark grey 1x2 inverted bracket plate with a 1x1 version and then put a uninverted 1x1 bracket next to it connected to the brown jumper and the black tile.
Expand
It would still be difficult to attach the two 1x1 brackets together.
I would use a 1x1 brick with pin hole on its side, with the bottom facing to the left (as in the picture). On the bottom of that brick (left) you then put a 1x1 plate, followed by a pin with stud, followed by that cylinder you are already using.
Expand
The inverted 1x1 bracket is attached to the floor, connected to it is the brown jumper plate, connected to that is the uninverted 1x1 bracket, and finally connected to that is the black tile.
Expand
It's kinda hard to see, but I'm pretty sure the half cylinder is centered in the two-wide area on a 1x2 jumper plate
Expand
Thanks for that - will look into this soon, as right now I don’t have those pieces
Expand
Interesting idea, however how will the black tile connect?
  On 3/5/2021 at 9:23 PM, Lira_Bricks said:
Something like this:
04bqyo1
Where the right-most brick should be under the 1x1 brick, with the stud in the hole.
Expand
Very nice although i meant the black tile that goes on top. How would that connect?
