I'm working on an open summer wagon. The prototype has an overhanging roof with a horizontal blue support running under it.
I've used jumpers on the end windows and on top of each vertical support to centre a 7w roof.
Then I've used jumpers to fill in the rest of the horizontal support between the windows.
Is there a better way to do this?
You can build a normal 6-wide roof + use plate with rail, that gives a nice 1/2 stud overhang on each side.
Red locomotive
Also I would reduce the number of blue roof supports....they are too dominating right now...
Edited by Selander
Spelling mistake. Picture inserted
Good ! Since you build digitally you could try plate with rail in blue color, and eliminate the layer of blue plates which is now on top of roof supports. It might give the roof a more elegant look.
3 hours ago, Tube Map Central said:
Would empty window frames work
They wouldn’t allow me to have the reddish brown tiled ledge
2 hours ago, High_Admiral said:
I would suggest panels
Which panels? What for?
I agree the bricks are too thick but I want to keep the brown ledge at the bottom of the opening.
For the roof supports, but now having looked in Studio, its come to my attention that there are no 1 wide panels. I was suggesting to use a 1 wide panel with the thinner side facing outwards, but that will no look good with a 2 wide panel
Edited by High_Admiral
The blue horizontal support should be directly above the vertical ones, set back below the white/grey roof.
18 minutes ago, High_Admiral said:
1 wide panel
Ah yes that would be good
You might consider building the sides in SNOT rather than stacked bricks for a thinner profile. Then your vertical supports could be as little as one plate thick.
