Service Notice / Slow Site speed due a DDoS attack ×
I am seeking the advice of some of you masters. I am working on a MOC and I need to connect a slope to an axle and have it go through a beam and be adjustable in and out. I also need the slope to be secured well to the axle. It seems that some new parts are out this year that would help, but I don't expect them to be available for quite some time. The beams must face holes up but a 90 degree twisted connection would work between t beams that are holes up.
Here is a link to one of the new beams 6321716 that would make life easier:
Here is my initial concept, however the slope is not secure in place and could easily be knocked off and the assembly is quite clunky. The only requirements are that the beams remain rigid and the slope is adjustable
https://i.imgur.com/a/UGGSSOI
Open to any ideas that may use some parts I don't have yet.
Thank You
Not really good. The slope would need to be locked in at the top, anyway. At one stuf wide only this is never ever going to have any devent stability to begin with. Whatever you have in mind will require a radically different approach, but since you haven't actually explained what you are trying to achieve, it's impossible to advise.
Mylenium
Does it have to be a 1x wide slope? As there are better technic bricks with axle holes that will hold the axle more securely plus you can use an axle with a stop end to stop it pulling out.
Mylenium
I kind of wanted to keep it top secret until I get it working (I understand this isn't beneficial), but it will be my entry for the GBC in Virginia this year.
I did eventually realize that #4 axle connectors also serve a similar purpose
The design must be 1 stud wide because a GBC ball runs perfectly using studded technic beams in a 3x4 configuration and it needs to fit inside the gaps on the sides. I will share some pictures, I promise let me get it running first.
 https://imgur.com/a/FyQMjSr
Edited by ngen33r
