SteamSewnEmpire Posted August 28, 2020 Posted August 28, 2020 (edited) Edited August 28, 2020 by SteamSewnEmpire Quote
zephyr1934 Posted August 29, 2020 Posted August 29, 2020 Looking top notch, as usual. Lots of clever parts usage everywhere (will there be frog legs for dinner?). I assume the rear of the oil bunker will be using 2x2 triangle tiles rather than the corner tiles shown here, no? On the heavyweight cars, for the RPO there has got to be a way to make the doors only one brick deep. I suppose the easiest way would be to do what you do only with the 1x1 brackets (especially since you do not have to worry about color availability), but presumably like the triangle tiles those are not in LDD. It would also be nice if on the top of the door windows you had a plate set back 1/2 stud to frame out the window and match the door below. The roof of the heavyweights seems too tall to my eye, by maybe two plates 16 hours ago, SteamSewnEmpire said: Quote
SteamSewnEmpire Posted August 31, 2020 Author Posted August 31, 2020 On 8/29/2020 at 7:55 AM, zephyr1934 said: Looking top notch, as usual. Lots of clever parts usage everywhere (will there be frog legs for dinner?). I assume the rear of the oil bunker will be using 2x2 triangle tiles rather than the corner tiles shown here, no? On the heavyweight cars, for the RPO there has got to be a way to make the doors only one brick deep. I suppose the easiest way would be to do what you do only with the 1x1 brackets (especially since you do not have to worry about color availability), but presumably like the triangle tiles those are not in LDD. It would also be nice if on the top of the door windows you had a plate set back 1/2 stud to frame out the window and match the door below. The roof of the heavyweights seems too tall to my eye, by maybe two plates Pretty sure the only way to get the doors 1 stud wide would be using the newer 1x1 brackets. Unfortunately, they don't come in dark green. Quote
Craig Strader Posted April 26, 2021 Posted April 26, 2021 (edited) How long are the coaches in studs? Edited April 26, 2021 by Craig Strader Grammar Quote
Toastie Posted April 27, 2021 Posted April 27, 2021 About 73 studs? Just count the x4s and x3s and add the snotted plates at both ends = about 73 + 2 Magnets = 77ish? I believe the original developer will not respond, looking at his "Banned Outlaws" rank ... Best Thorsten Quote
