Hi, i am a new member from Ireland, this is my 1st post so hello everyone. I am trying to automate a prototype i am designing for industry so thought i could find some help here. Thanks in advance.
I need to achieve the following, please let me know if this is achievable with lego technic.
Once a switch is made a motor will then start and travel a set linear distance of between 20-300mm then return and stop. The motor would likely need to be clutched in case of any resistance, the motor speed would also need to be variable. I have seen rack and pinion which looks the best option, the switches, motor, gearing, power supply involved i`m not sure about.
I  am very new to technic so forgive me for being a novice.
thanks
Hi,
yes, that's all no problem, and you mentioned the most important things:
rack, pinion, clutch.
Here it is, without clutch!
I built that as as small demonstration some months ago.
But where ist the clutch (that I formerly used in all my models)?
It's in the software. Set the motor to max power (not speed!)  say about 20% and start it, let in run as long it returns back his speed(!).
On the end, two things happen: Power cannot increase due the motor stalled, an motor as a sensor returns a speed of 0, then the programm stops the motor.
And here you see it with a mechanical clutch (the white gear on the left motor at 0:40)
But you need any program running....
Do have some programmable parts?
Is it acceptable to have a smartdevice or PC running the programming while model in use? Or should it be "standalone"?
Edited by Lok24
