tabicat Posted April 19, 2020 Posted April 19, 2020 Hi everyone! I've had my European 12v train set in storage for a couple decades and decided to break them out. I don't have any pictures of my original layout, so I'm starting from scratch, but I do have a 4'x8' surface on which to build. The problem is that I'm not feeling very creative and I'm struggling with a track layout that doesn't look boring. So far, I've come up with this. As you can see, I'm going to have to cut some tracks in half to make it all fit, but my concern is mostly that it looks boring. So I was hoping some of you could post pictures of your 12v tracks for inspiration. Quote
Andy Glascott Posted April 20, 2020 Posted April 20, 2020 Welcome on board! Great to see some more 12v stuff appearing, I have some old layout and on my computer that we’re on an 8 by 4 space, I’ll dig them out later and share them. With all those points/switches you could probably have a couple of running loops so that trains pass each other in opposite directions. Quote
Andy Glascott Posted April 20, 2020 Posted April 20, 2020 (edited) As promised, here are a couple of older drafts. I built the one on the right, it was the bottom layer of a 3 level layout to make the most of the 8x4 space I had at the time. BB Layouts by andyglascott, on Flickr If you haven't found it, Bluebrick is a great piece of software for designing layouts, I've been using it for years. (Thanks @Alban Nanty) Edited April 20, 2020 by Andy Glascott Added Bluebrick link Quote
LEGO Train 12 Volts Posted April 20, 2020 Posted April 20, 2020 This is the first layout that came to my mind, it can be tightened or shortened. It allows you to run 3 trains simultaneously and have 2 parked. Switch points are 4 right and 4 left. The intersection gives some movement to the layout. You can put the double level crossing on the south side and a single level crossing inside to reach the inner part of the circuit. Quote
tabicat Posted April 20, 2020 Author Posted April 20, 2020 Thanks, that gives me some ideas. I don't think that big layout will fit in a 4x8, but I think I can modify it. It didn't occur to me to use the crossing at an angle. Quote
LEGO Train 12 Volts Posted April 21, 2020 Posted April 21, 2020 23 hours ago, tabicat said: It didn't occur to me to use the crossing at an angle. Of course ...I had forgotten Quote
