qwest70 Posted February 20, 2020 Posted February 20, 2020 (edited) Hello everybody! I want to do efficient gear. Tell me please, what can be improved here? Edited February 20, 2020 by qwest70 Quote
Touc4nx Posted February 20, 2020 Posted February 20, 2020 I might be wrong, but the two axle on the right in the first picture can't turn as there is two different gear ratios linked to it : 1:3 and 1.66:1 Quote
doug72 Posted February 20, 2020 Posted February 20, 2020 (edited) What are the inputs & outputs and what are you building ? Edited February 20, 2020 by Doug72 Quote
qwest70 Posted February 20, 2020 Author Posted February 20, 2020 (edited) 5 minutes ago, Doug72 said: What are the inputs & outputs and what are you building ? On first picture it is inputs, second - outputs. It will be something tractor 9 minutes ago, Touc4nx said: I might be wrong, but the two axle on the right in the first picture can't turn as there is two different gear ratios linked to it : 1:3 and 1.66:1 It is may be strange, but it is working Edited February 20, 2020 by qwest70 Quote
Lipko Posted February 20, 2020 Posted February 20, 2020 1 hour ago, qwest70 said: It is may be strange, but it is working How? Quote
Jurss Posted February 20, 2020 Posted February 20, 2020 (edited) If it is working (I can't imagine that), then why You need gears on both sides of that beam? Edited February 20, 2020 by Jurss Quote
doug72 Posted February 20, 2020 Posted February 20, 2020 (edited) On 2/20/2020 at 12:47 PM, Jurss said: If it is working (I can't imagine that), then why You need gears on both sides of that beam? I have just built this from the photos without the 12T double bevel gear and it does then rotate freely. Edited February 21, 2020 by Doug72 Quote
