I wanted to power static Mindstorm builds at shows/events through wall power instead of rechargable AA batteries. I was going to design my own AA battery adapters then I found these on Thingiverse. They came in STL files that can be 3D printed. You only need to print two per Mindstorm unit. They have a nice opening to feed the wires through.
AA Battery Eliminator by movotrab: https://www.thingiverse.com/thing:3160060
I had to make a small notch on the battery cover for the wires to come out.
From here you connect to a 9V DC wall adapter.
For High power models the leaving the rechargeable battery plugged in does not work.  I had a 5 NXT Pinball Machine.  4 were fine.  But the one on the flippers would die about 3 hours into a show.  So I kept a spare battery to swap in.
For most people, this is probably not an issues.  But for things that never stop the motors its something to think about.
