Ocelot Posted August 3, 2019 Posted August 3, 2019 Hi all, I have been controlling PF motors from a Raspberry Pi with no problems. Recently I acquired a PF servo motor. I know that the servo motor is powered on the 9V and GND rails, and the position commands are PWM via C1 and C2. What I need to know is the voltage of the PWM signals, which is difficult for me as I don't own the PF control blocks. So, if anyone has an oscilloscope and the PF control blocks, I would be very grateful if you could record the PWM frequency, voltage, and duty cycle passed to a servo motor. Apologies if this is already answered but I have tried searching and also read Philo's site; yet nowhere do I find the specs for the C1 and C2 signals. Quote
JopieK Posted August 3, 2019 Posted August 3, 2019 See this: So the motor voltage is 9V and as your Pi IO is 3.3V your control voltage should be 3.3V. That is why this guy uses that motor H-bridge: you send 3.3V PWM signals to it and it is translated to the 9V level by the mosfets inside it. Quote
David Lechner Posted August 3, 2019 Posted August 3, 2019 C1 and C2 are also 9V (battery voltage). On non-servo motors, C1 and C2 actually power the motor and the 9V and GND lines are not connected. Quote
Ocelot Posted August 3, 2019 Author Posted August 3, 2019 Thanks for the replies! I'll try C1 and C2 at 9V (it is quite strange to see control signals at the same voltage as the motor supply, but I guess it made sense with the modular PF system). Quote
JopieK Posted August 3, 2019 Posted August 3, 2019 For PF they only use four leads of course and want to make it very easy for kids wo connect. For NXT / EV3 this is entirely different, I guess it is also different for Boost / Powered Up / Spike where there are more leads available. Quote
Tcm0 Posted August 4, 2019 Posted August 4, 2019 C1 and C2 are not control signals in the classical sense - they are direct voltages to drive a motor. The servo just translates these voltage to positions. Quote
