murtaughf3 Posted June 12, 2017 Posted June 12, 2017 I was just curious if there is a source for rebuilding sets with different color combos. I'd like to make the Mini Cooper and the VW Bus but maybe in a different color. I know I can go there and search each piece I would need to replace to see if I can use that color but I just wasn't sure if something like this already existed weather it be a parts list or a list with the set and alternate color options. Quote
KamalMYafi Posted June 13, 2017 Posted June 13, 2017 You can simply do that using Rebrickable. Just go to the set you want to change the color, then there's a "Switch Colors" button. Sadly, you need to use the Pro plan. Quote
Boettner Builds Posted June 13, 2017 Posted June 13, 2017 The piece they use for the fender flair will be one of the limiting factors for the Mini Cooper... Quote
