I'm making a pistol from lego technic but rather than using unreliable rubber bands, I want to use springs which are placed over axles.
The parts which need springs are:
The firing pin
The magazine
And The latch, which keeps the firing pin pulled back, (the trigger releases it).
The problem I have is, although I have seen stepper mechanisms such as in the lego technic porshe gearbox, those are rotary, not linear.
I would need a linear mechanism in order to lock the firing pin when the slide is pulled back (I.E when  the firing pin spring is compressed).
Is there a way this can be done in lego technic?
Here is a diagram of the slide and firing pin. The grey parts are the firing pin and (simulated) spring and the black parts are the slide.
Edited by SNIPE
