Instruction V-8 Engine 32-Valve Lego Technic
instructions: https://yadi.sk/d/P6II1vIEyBNT4
Implemented:
1. 8 Cylinder, 4 strokes, 32 Valve Engine
2.  Valve Working close to the real Engine.
3. Intake and Exhaust Systems
4. Ignition system (spark ignition)
5. Supply system
6. Attachments Equipment
7. Oil Pump
8. Engine Support Cushions
9. The Belt Tensioners, and Other stuff
Subscribe to the Shannel
https://goo.gl/rmEAjx
24 minutes ago, WvG_853 said:
Thanks! Will you publish them on Rebrickable? Makes it easier to find the necessary pieces ...
Yes, the instruction is already pending)
Very well done, thanks for sharing! IMO every car enthusiast has to have this on his shelf! Cutting pieces can hurt (especially the purists "clean" Lego souls) and hopefully everybody will be careful and not blame you for cutting some fingers off :grin: ... But there is no other way around to make these fantastic camshafts :thumbup:.
Did you build it after a specific real model?
Thank you for your review volume) had to go to such non-standard solutions. I make a Formula 1 car, but there will v-6 turbo )
