[MOC] V8 32 VALVE ENGINE LEGO TECHNIC PART 1
Hello everybody! I hasten to introduce you to a new job, V - shaped 8 cylinder 32 valve engine Lego Technic. This is the first part of the video. All the fun ahead. On this basis, you can do a lot of other engines v- shaped circuit or row. Instruction will be paid. Next proe plan to do on its base V - shaped 6-cylinder turbo engine for the installation of a new car bolid
Formula-1.
Implemented :
1. 8 Cylinder 32 Valve Engine
2. Valve Working close to the real Engine.
3. Intake and Exhaust Systems
4. Ignition system (spark ignition)
5. Supply system
6. Attachments Equipment
7. Oil Pump
8. Engine Support Cushions
9. The Belt Tensioners, and Other stuff
YouTube Channel  Subscribe to the Shannel
Foto:
29193840073_67410a17d6_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay
Zubov, on Flickr
29193840953_a238271e1d_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29820158435_be45ec47cc_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29820159585_a650cc7697_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29193844903_cae8d1cdcb_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29527334070_143fc1a9fe_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29784368536_d3b7aa9f4b_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29784376236_9fe5886635_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29784381906_7d709533ca_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29193858763_6e948032bb_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29820175065_618da5ffc0_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
29192427484_16f8d2029b_c.jpgMOC V8 32 VALVE ENGINE LEGO TECHNIC PART 1 by Nikolay Zubov, on Flickr
Edited by Nikolay
You managed an unbelievable amount of real engine's deatils both in looks and working. :thumbup: I never seen such a realistically functional one, in this relative small scale. My favourite parts are the working valves, for sure. I hope we will se one day this built in a (large :classic: ) car. Keep up the good work!
Indeed it's as exciting as Barman's version. I'm counting the number of liftarms i'd need to make a vehicle big enough to house it :)
49 minutes ago, 2LegoOrNot2Lego... said:
Impressive build!
No complaint, just checking: is it just me who sees only a bunch of URL code instead of clickable links? :classic:
Nope
Thank you so much:classic: I tried to make it believable. In the second video you can see how everything is arranged, on the channel youtube. I will continue to work. Respect your work Porche! It's incredible! :blush:
On 21.09.2016 at 3:41 AM, dhc6twinotter said:
Fantastic looking motor! Is it a two-stroke motor, or do you have some additional hidden gears to make the cams spin half the speed of the crank?
Thank you) 4 stroke. In the second video on the channel, you can see how things work.
On 21.09.2016 at 4:45 AM, Edwin Korstanje said:
Great masterpiece of design. :thumbup:
It's remember me at Barman V8.
Thank you) I'm sorry, bad memory, remind yourself? :blush:
Thank you! I will be glad if you are inspired to build great cars)
On 23.09.2016 at 2:47 PM, 2LegoOrNot2Lego... said:
Impressive build!
Thank you) Now everything works!
2 hours ago, afol1969 said:
Excellent build! And so realistic:thumbup: Are there any instructions for it?
Greetings
Alex
Thank you! Instructions to do during the week. She appears on rebrickable. :classic:
Edited by Nikolay
