Hello. I got a 1x1 brick with holes on all sides. I put a lightsaber blade through it and now it's stuck. Is there an easy way to remove it? Im worried i will break it
Thanks
Edited by legosamsonite
Grab a piece of foam rubber or even a tea towel, use this inside the jaws of pliers to pull the bar out. The soft material will protect the parts from damage, but allow a grip on it still.
You can try to push it out as far as it can go by pushing the brick down on the light sabre blade. That should give you more length of blade to grab and less blade to pull out of the two holes.
