RPABLOM Posted February 4, 2016 Posted February 4, 2016 Hi guys, i have a Little problema with my servo motor: Ive bought it to buil big models but last week i was building and the motor get “stuck” When i turn 90 degrees to the left it automatically come back to the center, even if i keep presing to the limit. But when i turn to the right, it get stuck at 90 degree and i have to press to the left to it come back to the center again I hope you understand, because english is not my native. I can upload a video tomorrow Its cracked? Can i fix it? Its normal? How to changue it? Waiting or ur coments regards Quote
syclone Posted February 4, 2016 Posted February 4, 2016 (edited) Contact LEGO Customer Service if you bought it from TLG. If you bought it from somewhere else you will need to buy another motor because TLG only refunds parts bought from them. Edited February 4, 2016 by LXF Quote
MaxSupercars Posted February 4, 2016 Posted February 4, 2016 This happend to me on 3 servos! The common known problem. Contact Lego customer service they send you new one... Max Quote
Damndog Posted February 4, 2016 Posted February 4, 2016 This exact same thing has happened to one of mine it sometimes fixes itself then goes back to not working properly Quote
doug72 Posted February 5, 2016 Posted February 5, 2016 (edited) Check that the connector block is making proper contact and then try again with the connector coupled directly to the battery box and use battery switch both ways to see if OK or not. If still not working "gently" ease out each connector in the plug and try again - I find this often fixes the issue with PF componants apparently failing. Edited February 5, 2016 by Doug72 Quote
Oliver 79 Posted February 5, 2016 Posted February 5, 2016 On 2/4/2016 at 9:27 PM, LXF said: Contact LEGO Customer Service if you bought it from TLG. If you bought it from somewhere else you will need to buy another motor because TLG only refunds parts bought from them. I contacted lego about mine when a similar problem happened. They didn't ask any questions about where it was from. They just sent a new one and asked if I could send the old one back. Gotta love lego customer service! Quote
syclone Posted February 6, 2016 Posted February 6, 2016 On 2/5/2016 at 9:20 AM, Oliver 79 said: I contacted lego about mine when a similar problem happened. They didn't ask any questions about where it was from. They just sent a new one and asked if I could send the old one back. Gotta love lego customer service! I had a broken m-motor and they sent me a new one but then when I dismantled the old failing one I discovered that the wire was broken and fixed it.Now I have 3 m-motors.Yes I also love it Quote
Winter Terapy Posted February 18, 2017 Posted February 18, 2017 I've had the same problem, here is the solution, in another thread: Quote
