Hi All,
Making nice track inclines that fit to the studs on a plate, can be a pain.. so if you have some OLD technic 'piston rods' in your collection (I have 50+.. :-), here is a solution:
17179083807_973d3154eb.jpgIMG_0517 by Marook, on Flickr
The flexibility here makes it easy to fix the tracks to the studs, even though they are not aligned due to the inclining angle.
Here with a mounted track:
17386538455_32d199eb63.jpgIMG_0521 by Marook, on Flickr
And here a bit longer up the track:
16764012304_3aa5b6e741.jpgIMG_0523 by Marook, on Flickr
There might be other bricks to use, if these piston rods is hard to find, but the basic idea is working right well, and with technic axels 12L it gives great stability.
Further stability can be added by 'locking' the track-connections with small plates..
Enjoy...
Great idea. You could probably replicate the same functionality of the old technic connectors with the new ones by inserting a half pin in the hole. Or replace them altogether and instead use a technic brick with an axle hole.
Yeah, I have been thinking about that as well. As long as the axle is able to move at the point where the cross-axle is, it's fine.
I thought it was 1 plate per track segment (16 studs) so that would be 2 per baseplate, but not as steep as what is pictured.
This is a great solution, but the grade is too steep. I think the typical recommendation is only one plate per baseplate.
2 plates = 2.8° incline, and as long as you keep under 3° you are fine.
And this support kan do any degree you like.. ;-)
I've found that light trains (like stock holiday train w/ 9v motor in engine) work OK with up to 1 brick per track segment, but that only works for trains less than 3 or 4 light cars long, and even then, it really struggles. This looks fine though.
Ok, enough rambling on now. :tongue:
Neat use of the old Technic parts! If only they came in the current grey to match... What are you planning to use these for?
Thanks.
Well, I was thinking of doing a ramp of some sorts for the first part of the incline, and wanted to have some flexible, but good, support for it, so I could decorate it later.
Since going back into LEGO trains about months ago, I've been playing with a lot of bridge layouts etc since my apartment is small, and it it has to be a bit fun, the tracks must cross over each other.. anf then it was fun to see what tricks all my old bricks go do ;-)
And then I just like to share my findings.. now that so many others share theirs.. ;-)
Edited by marook
