Hi,
I recently joined the Eurobrick and bought a 4564 used set. The overall condition was great but, windscreen was a bit foggy.
I did some research and found that Pledge with Future shine is effective for polishing the transparent LEGO parts.
But I was told that this product is no more available in UK but there is a Pledge Klear Multi-surface wax floor shine is on the market.
Is there anyone who has tried this product? or is there any good material or similar product to polish the clear parts of Lego?
Thank you!
Edited by jaesroe
Thank you. The condition of my windscreen seems a bit foggy as there are some scratches. Then I just need #1? or even need #2?
Edited by jaesroe
Be forewarned.... not all trans-clear parts in older LEGO sets was as sparklingly clear as they are today. Over the last 50 years TLG kept tampering with the formula for trans-clear parts. During the 1980s the 1x6x3 trans-clear windscreens and 2x2x2 trans-clear smooth steep slopes were foggy even in mint condition.
Not sure if your train had any of these foggy parts in trans-clear (because other trans-clear parts were perfectly clear)... but you might be making things worse if the part was originally sold that way.
Here's an image from my Unofficial LEGO Sets/Parts Collectors Guide showing (from right to left) how LEGO trans-clear 2x4 bricks evolved over the last 55 years....
Edited by LEGO Historian
Thanks for your response. Lego historian. mine is 4564 so I assume the original condition might be better than this one. Since this set was released in 1994, I think the level of transparency was might be far left or second from left. So, would it be still risky to try Novus ?
  On 4/29/2015 at 11:44 PM, jaesroe said:
Thank you, then I will try NOVUS..But still not so sure whether I should start from #2 or #1 first...
Logically you should just start with 1. What do you have to lose? If it is too fine, go to 2, then back to 1.
Edited by legoman666
Thank you! I will
