So I've been wanting to do something with this bionicle head which (to me) looks perfect for a droid. Tonight I whipped up this body:
As you can see the legs are still largely unfinished, and I'm not 100% happy with the hands, but I'll probably stick with it even though I'm not really thrilled with using that tired technique for the arm joints.
At first I thought the head begged for a large, armored, bulky body but this just sort of evolved and I really like it. Any thoughts?
Edited by Starwars4J
Personally, I think that instead of a droid, you should make this into a minifig Exo Toa from the Bionicle 2002 series. Just add a cannon on the right hand, bulk it up a bit (if possible) and complete the legs. Oh, and make a seperate head for when the ET is on auto-pilot.
And even if you don't want to do all that, it looks great. I really look forward to seeing the end result. X-D :-)
I like the hands. Actually, it looks like he's wearing one of theose frilly cuffs :-D ! No, seriously, I do like the hands.
I dunno, maybe (if possible) fill in the body. 1x1s or maybe a clip piece of some sort.
Well I see why you'd want the body filled up, but with the way it is now, it has hips. Just experimenting in some new articulation designs :-D
  • Eurobricks Emperor
Very smart design, I wouldn't be able to make something like this...
The title says "Multi-purpose droid ...".
Could you give a list of the things this droid can do :-P ?
Ah, I see. Is there another phone piece on the back, or just one on the front?
Yup, it wouldn't be stable otherwise, right now the joints are very strong
-Heavy Lifting
-Sparing
-Construction
-Guarding
-Light Lifting
-Navigation
-Homework :-P
I've finished the droid...though I was missing a few colors [sad] so if you see a part that looks out of place...yeah, it's going to get replaced. It's really articulated, with a lightsaber able to clip onto the back thigh. Onto the other thigh a yet-to-be-built large blaster will be clipped.
The droid is meant to be multi-purpose, so the weapons aren't a necessity. Anyway I guess I'm happy with how the legs turned out, I just wish I had the bley torsos on hand. I may or may not add onto the feet, it's already sorta tall, but I had to use those pieces to make it compact and able to take advantage of the hip joint.
Gallery when moderated
