@I_Igor
Yeah, but not only Technic as there are lots of other parts in odd colours. Check this guy on Flickr.
51 minutes ago, Juroen said:
No, that’s not possible. I’m looking for a part with a vertical offset of 0,5 plate
Headlight brick aka "Erling brick" put sideways for example. There are many ways (and parts) to build different types of offset with bricks. It mainly depends how restricted is your depth.
Edited by zux
9 hours ago, zux said:
@I_Igor
He has really interesting collection, I remember some ten years ago there were black differential 4L and black driving rings...but red rims are very interesting (even if I do not like red  color on crane 8421...)
On 8/14/2018 at 8:04 PM, pagicence said:
How about this for a part? I don't know for what it would be used for (maybe when 2 axles collide and they need to turn), or useful at all, but it looks kind of coll. And I know that there is exactly the same one with cross holes but I figure... why not?
Actually this does have some uses, for exmple it could fit onto a part that has a fixed pin in order to have a pinhole above it. It is harder to pull apart too as opposed to an axle. It also has uses when mounted to normal pins and you could add these to the ends of an axle then put beams on top of that part to add bracing, it also provides a stop on each end for the axle.
I know it's a bump, but has anyone notice yellow angle connector #2 on the 2019 set The Lego Movie 2 Emmet's Thricycle?
As far as I know, this is a new recolor, and personally a highly desired one :)
This one has yellow in year 2003.
Woo hoo!... Patience finally pays off. If you guys remember I said that I was building a custom White version of 42056.
In order to do so I had to use fake panels, but thankfully Lego have now released said panels as genuine Lego ?
Some other cool recolours have also been released in the 2019 sets.
Here are the panels in question
https://www.bricklink.com/v2/catalog/catalogitem.page?P=18944&idColor=4#T=C&C=4
https://www.bricklink.com/v2/catalog/catalogitem.page?P=24119&idColor=4#T=C&C=4
Edited by Richard Dower
24 minutes ago, Touc4nx said:
Hello, I had a question since I bought this set :
What is this part
Because I can't find it in my parts...
It only appeared in 42023 and the pullbacks 42026 and 42027 in 2014. In later versions it was replaced with a normal black worm gear. Apparently the bushings stressed too easily, which is apparent on the one I own from 42023.
16 minutes ago, Erik Leppen said:
Where? I haven't seen it on high-res images.
It looks to me at the bottom (behind lowest wheel) where trans orange small beacon light is placed, or it is liftarms 1 X 3 thick ?
Edited by I_Igor
Ok I didn't know, but I can't find where it should have been, even after looking at he instructions online  :sceptic:
It's used in the combo model, or at least it was before it was replaced.
8 hours ago, JonathanM said:
Unfortunately it's a 1x3 liftarm by the looks. Secured with I guess the 3L pin with 2L axle?
Unfortunately you could be right, but from angle in small image that I have it looks like it is 2 studs long ...
Interesting,  set 25219 has a large number of Technic parts in Reddish Brown, but what caught my eye was the large Technic steering wheel in White, Part #2741
Check out the part list:
https://www.bricklink.com/catalogItemInv.asp?S=75219-1
42088 has a lot of parts now in Orange colour:
https://www.bricklink.com/catalogItemInv.asp?S=42088-1
Part 32530 is now available in Yellow I'n set 60222
Wow!....more amazing news!...Part 6538c is finally available in White
https://www.bricklink.com/catalogItemIn.asp?P=6538c&colorID=1&in=A
This means I am officially only using 10 fake/clone parts of my White version of 42056...woo hoo!
6 hours ago, Jurss said:
There is this part in nontechnic set
https://brickset.com/sets/containing-part-6249327
6249327
It is called Pneumatic Connecting Piece,
Interesting, what will be the purpose for it?
Maybe just to connect this?
https://brickset.com/sets/containing-part-6248537
Edited, just saw the video review of the set and can see how it's being used now :blush:
Edited by allanp
