First of all, I'm completetly new here and my english isn't perfect.
In the future I will start building an LPE powered car that is inspired by nicjasno and his E30. I'm not sure if I will model an existing car or create a new one, but it will be around the same size of his car.
The gearbox is one thing that I just can't get over. I don't even care about how many gears it has, I mainly need reverse, because that is the only way of going backwards with an LPE car. It has to be RC controlled of course, which is easy to implement in a 1+r, but harder with more gears. The most important thing that it has to feature - smoothness and rigidity. If it isn't compact, then that's not a big deal. It will be powered by an Inline 4 LPE which revs up to 5000 rpm, so downgearing is needed as well.
The other elements of the car aren't built right now because of the lacking parts, but I want to have the blueprints of the main elements of the car before I start building it. I know that I will have enough problems when I will build it, so I try to plan as much as possible before.
If you have seen or have built something like this in the past, please share it with me!
3 minutes ago, Aventador2004 said:
Use the idea of a reverse / foward gearbox in the Porsche. D. N. R.
What do you exactly mean by D. N. R.?
Also you have topic Gearbox collection tread so you can always scroll through.
Good luck
Edited by I_Igor
