Showing results for tags 'torque distribution'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hello, I would like to show you a prototype of a torque distribution system for AWD cars. I made this because I am currently waiting for parts for my WRC car and when I thought about my next MOC I decided, that it should not be a rally car again, but still a motorsport vehicle and still have AWD, so i came across AWD touring cars. Among others, that also made it on the future moc list, the Nissan Skyline GTR R32 Group A came to my mind. Even though this car and especially its successors are a little "overhyped", it features an interesting AWD system, called ATTESA ETS. Basically it is a RWD drivetrain with a PTO to the front axle, connected by a multiplate clutch. This clutch is controlled by an ECU and steering, yaw, throttle and wheelspeed sensors. As I do not have any Mindstorms parts, I decided to use pneumatics to mimic the original system. How it works: The L-motor represents the normal RWD drivetrain as powersource. Yellow +o+ part represents front axle driveshaft. The differential is used as a clutch, when the diff housing is braked, torque will be transmitted to front axle. Braking is done by an 1x4 L-Beam that is pressed on an axle with a pinion gear. This pinion gear meshes with diff housing. Whenever the motor/driveshaft rotates, the pneumatic pumps are working, but the resistance is low, as long as the pneumatic valves do not seal the pneumatic system (air/pressure can escape). The valves are meant to be mechanical connected to throttle pedal and steering. When they are closed by throttle or steering input (or lack of it), the pressure increases and the cylinders press against the L-Beam. When pressure decreases again, the springs retract the cylinders. The pinion gear with friction pin is there for demonstration purpose (resistance at front axle). Video for demonstration: https://www.youtube.com/watch?v=rctAZeHzsLs Maybe the new 2h2018 pneumatic valves will be useful in this case (better implementation, more precise). Of course the playability of this feature will be limited, especially as I am planning to make the vehicle non RC, but a normal AWD would be too boring. I hope you like it, its not very advanced but a little different to the usual AWD systems arround.
