Showing results for tags 'refuse truck'.
One of my favorite Eurobricks builds over the past couple of years was the Garbage Truck @steph77 completed in 2017. It's been a while since I have made a Garbage Truck, so after Thirdwigg Jr. Jr. (6) asked if I could make one, I jumped at the opportunity. I asked if he would be willing to test it as I built it. He said yes, so we were off. First, I wanted to make the truck fully manual with the following functions: Three axle, two steering Fake engine Removable garbage container Opening compactor Extractor plate Two stage compaction cycle Bin lift/tip Everything had to work smooth enough for a child to process the smallest of LEGO parts, particularly the 1x1 plate round. Nothing could get stuck in any movement, as this would frustrate a child (and me, frankly). Back in March, I finally figured out a little design that would be the first step of the compaction function. It wasn't perfect, but it was enough to proceed. The arch part at the bottom will be where the trash is dumped into the compactor. Back of the truck is to the right. I decided to model the truck after the Dennis Olympus garbage truck/bin lorry/refuse truck, in the colors represented by this stunning little build by Jonathan Elliot. So after another build session, I created this simple bodywork. I built a draft of the compactor, and put the two parts together and came up with this. Test one with Thirdwigg Jr. Jr. identified some problems with the compaction. Currently the bottom plate does not pull up far enough, so I'll need to turn the gear mechanism around. Here you can see how it processes from one gear on the side. It's not perfect yet, but I think I may be able to get there. See the video here. We'll see where this goes, but I like what I have so far. It's been almost a year since my last large project, the Ionos Sedan, so it's time for something bigger again. Questions, Comments, Laments, and Insults always welcome...
- 25 replies
- recycling
- garbage truck
(and 3 more)
Tagged with:
