Showing results for tags 'rebel blockade runner'.
I’ve been working on updating the 10019 Rebel Blockade Runner, which so far has gone quite smoothly apart from the engine block on the back - I could really use some ideas for part substitutions. The original model has many rare parts on each engine: 33211 spoked wheel (long out of production), 2515 Wheel in Light gray (can be recoloured to pearl dark grey), 2903 wheel in dark red (unique), 3961 8x8 dish in light bluish gray (never made), 3934/3933 Wing 4x8 in white (hard to get in bulk). There were also stickers across multiple pieces to provide some additional detailing on the cylinder shells. I’m struggling with rebuilding this, and my attempts so far are shown below: Firstly, replacing the dark red wheel is a nightmare because of the limited number of parts available in that colour. I tried using 1x3 curved slopes (left) to build a circle, but the circle works out at something like 8.2 studs and you can’t sit the engine cylinders next to each other. I also experimented with a pentagon/circle technique I found online (middle) which kind of works but it’s awkward to mount on the cylinder, and I’m not sure how strongly I can attach the 2515 large wheel that forms the engine nozzle. My current preference (right) is for 4x4 round corner plates to build up the red stripe, but I don’t see how to mount the large wheel securely - any ideas? I’d also like to avoid the stickers on multiple pieces, by rotating the 8x8 cylinder 45 degrees - that way, the sticker should fit on just one shell. Problem is, all the turntables seem to spin freely - is there any compact way to lock lego bricks at a 45 degree angle?
- 14 replies
- rebel blockade runner
- ucs
(and 2 more)
Tagged with:
