Showing results for tags 'pu technic battery pack'.
Hi Everyone, We have been working on a project for 1.5 years to finally find a solution to the problem that LEGO does not offer: a rechargeable battery for the technical Powered UP HUB. Because LEGO is relatively slow to update its products in this area, we decided to give our unique battery, the “Phondly EnBo PU Battery Pack,” a chance. Over the past 4 months, we’ve developed our prototype to such a level that we thought it was time to introduce and launch a Kickstarter campaign to raise money for our first production line. The product itself is an integrated solution for 2-cell li-ion batteries, combined with an electronics that provides fast charging via the built-in USB-C connector, power-path management (for stationery models) and consistent output performance throughout the full capacity of the batteries. . The key features are: - lighter than 6 alkaline batteries with holder - constant 9V output voltage - Withstands high power consumption (tested for 5A demand) - power path management, where LEGO creations can be operated while the battery is charging using the power of the connected USB cable - there is a charge indicator LED (lit through the brand logo) - through LEGO or other third-party applications, inform you that the battery is low by turning off the voltage conversion before the batteries are completely discharged. - can be ordered with two types of cover for the old snap-in HUB or the new screw HUB (fully replaceable on the base box) - With the help of you (the sponsors), the appearance of the product will be similar to that of LEGO (better quality injection molded case made of ABS plastic) - the case design allows to tilt the battery out from the HUB We have so far financed the project 100% on our own, but unfortunately we do not have enough capital to finance the production, so we turned to the LEGO community to help us achieve our goal in a kickstarter campaign. As for kickstarter campaigns, you need to know that everything works on an all-or-nothing basis, meaning we only get the money we’ve raised during the campaign if we’ve reached or exceeded our goal. As a supporter of the campaign, if the goal is not met, you will not lose your prepaid money, the amount will not be deducted from your card at the end of the campaign. So if you want to be a part of this story and feel committed enough to help this product get into stores, please help us reach our minimum goal of € 60,000 or more by supporting us on kickstarter while choosing a a reward for yourself that you are happy with. On the other hand, if we don’t achieve our goal, we won’t get paid to continue working on this great product. Our Kickstarter Campaign page is: https://www.kickstarter.com/projects/phondly/enbo-pu
